Krigen mellom Israel og Hamas
Melding lagt til av Uderzo,
Vennligst ikke post politiske memes, det har kun en negativ effekt på diskursen, gjentagelser kan føre til advarsler.
Israelis have shared information about hospital explosion with the US, officials say
Israel has shared information about the explosion at the Al-Ahli Baptist Hospital in Gaza with the United States, Israeli officials say.
US intelligence officials are working to understand what happened at the hospital.
Palestinian officials have accused Israel of carrying out an airstrike that killed hundreds of people in the hospital. Israel has blamed Palestinian Islamic Jihad for a failed rocket launch that hit the hospital.
IDF may share intelligence proving Israel not responsible for Gaza hospital bombing, spokesperson says
A spokesperson for the Israel Defense Forces said it might share intelligence or raw data with the world to prove that Israel is not responsible for the attack on the Al-Ahli Baptist Hospital in Gaza as Israel claims.
IDF spokesperson Lt. Col. Jonathan Conricus said “maybe" when pushed about releasing more information.
“We’re in the progress of declassifying. I cannot promise yet that we will but maybe because of the importance and because what is at stake here that may happen,” Conricus said.
When asked if the IDF was 100% certain that it was not an IDF missile strike that hit the hospital in Gaza, Conricus said he is “as certain as anybody in war can be with millions of pieces of information flying around."
"But after a very serious review, I can say that is the information that we have now we are confident and the information that we have says this was a failed launch by Islamic Jihad," he said.
In response to a question about if there were IDF missile strikes in the vicinity or blocks within the hospital in Gaza, Conricus said: “Not as far as I’m aware.”
  • Innsiktsfullt 5
Israelerne hadde i dagene i forveien reagert på at store menneskemengder samlet seg i hospitaler hvor det også var observert militante nærvær, og den 14. oktober var en bombe sendt mot Palestinaplassen like ved Baptisthospitalet, da skulle rundt 6,000 ha dratt dit. Etter bombenedslaget forlot de fleste sivilistene området, men det var ikke nok - i 16. oktober forlangte IDF at alle hospitaler må evakueres og det var antydet at det gjelder sivilister, ikke pasienter og pårørende - hospitaler skal ikke fungere som tilfluktsentre, da dette vil umuliggjør medisinsk virksomhet.
Omlagt 1,000 sivilister var i hospitalområdet. Ifølge pålitelige opplysninger fra en legesjef som ikke leker propagandist som andre leger som villige sto fram med drepte barn, var over 350 skadde ført ut av katastrofestedet. 200 døde ser ut til være det faktiske minimumstallet fordi meget mange hadde blitt brent i hjel. 500 døde er ikke urimelig; men det er definitivt ikke "800" som det nylig er sagt. Alt dette i et lite område på bare 50 m i diameter. Der hadde folk følt seg trygt fordi parkeringsplassen med hagene lå i midten med store omkringliggende bygninger som kunne beskytte dem mot våpennedslag rett i nærheten, som sett den 14. oktober.
Hospitaler er ikke ment å være tilfluktssteder i krigstid fordi dette ikke bare hemme den viktige assistansen for legehjelp, men også muliggjøre kompromittering spesielt hvis det er statsløse militante organisasjoner som ikke har et tydelig skille mellom det sivile og det militære, i bildet.
  • Innsiktsfullt 7
1 hour ago, Snikpellik said:
De første meldingene om eksplosjonen kom rundt 19:20. Alle videoene Israel og IDF delte (og senere har slettet) har en timestamp mellom 19:59 og 20:00.
De første meldingene kom faktisk rundt 19:10, noe som stemmer overens med denne videoen delt av Israel. Det er også videoen GeoConfirmed har brukt til å lokalisere sykehuset.
Den andre videoen er en time senere, så forklaringen kan rett og slett være ulike tidssoner. Men om  Hamas/Jihadgruppen klarte å skyte seg selv igjen 1 time senere, som førte til at Israel viste feil video, så styrker ikke det deres sak.
Endret av Camlon
  • Liker 3
  • Innsiktsfullt 4
Jeg har sett M-302 raketter eksplodert i den syriske borgerkrigen, disse er meget kraftige saker og kan sammenlignes med en 250kg Mk 82 bombe. Men disse er ingenting mot de store IRAM-rakettene som kan sammenlignes med 500kgs eller 1-tonns bomber i destruktivitet, hele bystrøk i Damaskus og Aleppo var ødelagt med IRAM-raketter.
  • Innsiktsfullt 5
Brother Ursus skrev (6 minutter siden):
For mange videoer til å poste nå...
Det plinger hele tiden her, det er angrep på ambassader og annet over hele midtøsten, og også andre steder.
Verken USA eller Israel har ambassader i Iran, men det meldes om store folkemengder og demonstrasjoner foran ambassadene til England og Frankrike i Tehran nå.
Endret av 0laf
  • Innsiktsfullt 1
Kakkelfant skrev (6 minutter siden):
Video som visstnok skal vise missilet skutt opp av Hamas falle ned I gaza
Det er aktuelt to separate hendelser; den første kl. 18.59 da en enslig rakett var oppskutt, knapt 20 sekunder senere hendt eksplosjonen i Baptisthospitalet - kl. 19.10 kom den første meldingen om nedslaget ut på eteren.
Ved kl. 19.50, om jeg husker riktig, ble det sendt ut en rekke raketter som sett på det andre opptaket her, og den ene falt av og krasjet et sted i Gazastripen. IDF blandet de to sammen ved en feil og skaper forvirring.
  • Innsiktsfullt 2
JK22 skrev (12 minutter siden):
Jeg leste et par steder at en av videoene enten ikke var ekte, altså at den fra noe helt annet, eller at det var noe feil med tiden på den, men er usikker? Det var vel derfor den ble fjernet fra flere steder.
Videoen som er fra Al-Jazeera sitt team skal være bekreftet så vidt jeg forstår, og IDF har angivelig mer informasjon også, som de altså foreløpig er usikre på om de vil publisere, men har delt med amerikanerne.
Det meldes om store demonstrasjoner i Jordan og Egypt også. Jordansk politi skal ha brukt tåregass for å fjerne demonstranter som forsøkte å komme seg inn i USAs ambassade.
Endret av 0laf
  • Liker 3
IDF hevder de har egne opptak fra droner av angrepet på sykehuset, at de har sjekket med sine radarsystemer, som fanger opp det meste, og at de i tillegg har elektronisk kommunikasjon mellom Hamas osv. hvor det snakkes om en rakett som feilet og falt ned i Gaza.
IDF hevder på CNN at de vil offentliggjøre all informasjon innen kort tid.
  • Liker 3
  • Innsiktsfullt 2
