djtesla87 Skrevet 12. januar 2004 Del Skrevet 12. januar 2004 Hei jeg har problemer med å få installert lydkortet mitt Jeg har et integrert AC97 lydkort og Kjører nyeste version av Fedora Fedora finner noen lyd drivere men disse virker ikke Hvordan får jeg installert driverene Har prøvd en hel haug men det funker ikke 1: jeg unzippa kilde koden 2: Terminal 3: cd /root/alsa-driver-0.9.4/ 4: ./configure checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable cc found in $PATH 5: Jeg skriver make make dep make[1]: Entering directory `/root/Desktop/alsa-driver-0.9.4' make[2]: Entering directory `/root/Desktop/alsa-driver-0.9.4/support' Makefile:27: /usr/src/linux-2.4.18-27_1tle/alsa-driver-0.9.4/Rules.make: Ingen slik fil eller filkatalog make[2]: *** No rule to make target `/usr/src/linux-2.4.18-27_1tle/alsa-driver-0.9.4/Rules.make'. Stop. make[2]: Leaving directory `/root/Desktop/alsa-driver-0.9.4/support' make[1]: *** [dep] Error 1 make[1]: Leaving directory `/root/Desktop/alsa-driver-0.9.4' make: *** [include/sndversions.h] Error 2 6: Jeg skriver make install rm -rf /lib/modules/2.4.18-27_1tle/kernel/sound make[1]: Entering directory `/root/Desktop/alsa-driver-0.9.4/support' Makefile:27: /usr/src/linux-2.4.18-27_1tle/alsa-driver-0.9.4/Rules.make: Ingen slik fil eller filkatalog make[1]: *** No rule to make target `/usr/src/linux-2.4.18-27_1tle/alsa-driver-0.9.4/Rules.make'. Stop. make[1]: Leaving directory `/root/Desktop/alsa-driver-0.9.4/support' make: *** [install-modules] Error 1 7: jeg sriver ./snddevices Creating /dev/mixer?... done Creating /dev/sequencer... done Creating /dev/midi?... done Creating /dev/dsp?... done Creating /dev/audio?... done Creating /dev/sndstat... done Creating /dev/music... done Creating /dev/dmmidi?... done Creating /dev/dmfm?... done Creating /dev/amixer?... done Creating /dev/adsp?... done Creating /dev/amidi?... done Creating /dev/admmidi?... done create symbolic link `/dev/mixer' to `/dev/mixer0' create symbolic link `/dev/midi' to `/dev/midi0' create symbolic link `/dev/dsp' to `/dev/dsp0' create symbolic link `/dev/audio' to `/dev/audio0' create symbolic link `/dev/sequencer2' to `/dev/music' create symbolic link `/dev/adsp' to `/dev/adsp0' create symbolic link `/dev/amidi' to `/dev/amidi0' rm: cannot remove `/dev/snd': Er en filkatalog Creating /dev/snd/control?... done Creating /dev/snd/seq... done Creating /dev/snd/timer... done Creating /dev/snd/hw??... done Creating /dev/snd/midi??... done Creating /dev/snd/pcm??p... done Creating /dev/snd/pcm??c... done ALSA loader devices Creating /dev/aload?... done Creating /dev/aloadSEQ... done Jeg rebooter men d funker ikke HVa skal jeg gjøre? eller hva gjør jeg feil Lenke til kommentar
objorkum Skrevet 12. januar 2004 Del Skrevet 12. januar 2004 checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable cc found in $PATH Du har ingen compiler som kan utføre make så det er ikke rart det ikke går. En error i ./configure betyr at resten ikke vil funke. Du må installerte en compiler. Bruk pakkesystemet og søk på gcc. Jeg bruker SuSE 9.0 og bare skrive gcc i YaST og den finner compileren. Lenke til kommentar
djtesla87 Skrevet 12. januar 2004 Forfatter Del Skrevet 12. januar 2004 kan du forklare litt nermere? hvor finner jeg en compiler Bruk pakkesystemet og søk på gcc. Hva mener du med dette? jeg er nesten 100% NOOB når det gjelder Linux Lenke til kommentar
djtesla87 Skrevet 12. januar 2004 Forfatter Del Skrevet 12. januar 2004 jeg har så vidt fått lyd i maskina Men det fungerer lang fra rikitg jeg får opp følgende hele tiden: sox: Sound card appears to only support 2 channels. Overriding format sox: Unable to set audio speed to 11025 (set to 48000) sox: Sound card appears to only support 2 channels. Overriding format sox: Unable to set audio speed to 11025 (set to 48000) sox: Sound card appears to only support 2 channels. Overriding format sox: Unable to set audio speed to 11025 (set to 48000) sox: Sound card appears to only support 2 channels. Overriding format sox: Unable to set audio speed to 11025 (set to 48000) Lenke til kommentar
sim Skrevet 12. januar 2004 Del Skrevet 12. januar 2004 Virker nesten som Fedora installen din har gått shaiten. Den finner ikke gcc en gang Lenke til kommentar
djtesla87 Skrevet 12. januar 2004 Forfatter Del Skrevet 12. januar 2004 så du anbefaler å reinstalllere? jeg drev å kødda inne i en modul fil pasta inn noen koder kanskje derfor alt fucker seg etter at jeg gjorde den modifikasjonen så kom det lyd noen steder men den nevnte feilmeldinga begynte å komme hele tiden Virker nesten som Fedora installen din har gått shaiten. Den finner ikke gcc en gang Lenke til kommentar
sim Skrevet 12. januar 2004 Del Skrevet 12. januar 2004 En skikkelig god gammaldags reinstall hadde nok gjort saken noe bedre. Vil jeg tro iallefall. Lenke til kommentar
djtesla87 Skrevet 12. januar 2004 Forfatter Del Skrevet 12. januar 2004 men når jeg først er i gang er det noen spes distrubsjoner du anbefaler? Lenke til kommentar
sim Skrevet 12. januar 2004 Del Skrevet 12. januar 2004 Fedora er nok bra for deg den. Hadde du vært litt mer erfaren hadde jeg selvfølgelig anbefalt gentoo, men jeg tror ikke du kommer til å overleve. Jeg hadde mistet tolmodiheten med en gang. Gå for Fedora du. Kjør en ny install, og prøv å få det til på ny, helst uten å ødelegge for gcc . Lenke til kommentar
djtesla87 Skrevet 12. januar 2004 Forfatter Del Skrevet 12. januar 2004 gcc har ikke vært på maskina i det heletatt den komandoen har ikke fungert i det heletatt Hva tror du om suse 9.0??? Lenke til kommentar
sim Skrevet 12. januar 2004 Del Skrevet 12. januar 2004 gcc har nok vært på maskina vil jeg tro. SuSE 9.0 er nok også ypperlig. Du kan bruke guiden til MarcelSB som du finner her på forumet . Jeg prøvde Suse 8.2 i sommer, det var sånn halvveis første gang med linux, og ALT virka omtrent, lyd og alt. Så prøv deg litt frem, så finner du nok frem til noe du liker. Lenke til kommentar
djtesla87 Skrevet 12. januar 2004 Forfatter Del Skrevet 12. januar 2004 jeg fant en distro jeg likte. men den var såpass ukjent så det var vanskelig å finne programmer som funka. fikk høre at den skulle være temmelig lik debian men det viste seg å være feil Lycoris Desktop/LX Lenke til kommentar
sim Skrevet 13. januar 2004 Del Skrevet 13. januar 2004 Gjør et forsøk på SuSE 9.0 også da God natt, sov gått, nå kaster jeg hånklet iallefall. Lenke til kommentar
slime mold Skrevet 13. januar 2004 Del Skrevet 13. januar 2004 gcc har ikke vært på maskina i det heletattden komandoen har ikke fungert i det heletatt Det kunne du ha fikset med kommandoen 'yum install gcc'. Lenke til kommentar
djtesla87 Skrevet 13. januar 2004 Forfatter Del Skrevet 13. januar 2004 Har nå reinstallert men ennå ikke noe gcc får forsatt denne: checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable cc found in $PATH Prøvde også det du sa SLIME MOLD: Det kunne du ha fikset med kommandoen 'yum install gcc'. Lenke til kommentar
djtesla87 Skrevet 13. januar 2004 Forfatter Del Skrevet 13. januar 2004 (endret) når jeg prøver "yum install gcc" får jeg slik pg den stopper der [root@217-171-145 alsadrivere]# yum install gcc Gathering header information file(s) from server(s) Server: Fedora Core 1 - i386 - Base NY INFO: Den Gikk foresten videre nå Endret 13. januar 2004 av djtesla87 Lenke til kommentar
djtesla87 Skrevet 13. januar 2004 Forfatter Del Skrevet 13. januar 2004 Nå lot jeg denne komandoen stå i hele natt men få forsatt denne meldinga checking for gcc... no checking for cc... no checking for cc... no checking for cl... no configure: error: no acceptable cc found in $PATH Hva kan være galt hvis jeg snart ikke får det til reinstallerer jeg MS Suckdows XP i det miste greier jeg å bruke det 100½ nå har jeg sitti å plundra i linux i 3 dager uten å komme noen vei trenger noen tips som hjelper nå Lenke til kommentar
djtesla87 Skrevet 13. januar 2004 Forfatter Del Skrevet 13. januar 2004 har nå kommet et lite steg videre [root@217-171-145 alsadrivere]# ./configure checking for gcc... gcc checking for C compiler default output... configure: error: C compiler cannot create executables Lenke til kommentar
djtesla87 Skrevet 13. januar 2004 Forfatter Del Skrevet 13. januar 2004 nå prøver jeg å få installert gcc på nytt men får en feilmelding: pakkene ble ikke funnet: Pakkene som ikke kan finnes er cpp libgcc Lenke til kommentar
