VW Transporter problem med aut.gir
holok
Jupp,
Sitat
This code basically means that the programminging the PCM/ECM (powertrain/engine control module) has failed. This can be a more serious code and may also be refered to as "ECM Internal Circuit Malfunction".
Og:
Sitat
Although generic, the specific repair steps may vary depending on make/model.
Read more at: https://www.obd-codes.com/p0607
Copyright OBD-Codes.com
Sitat
P0607 could be caused by one or more of the following:
  • Loose ground terminal on PCM/ECM
  • Dead or defective (12V main) battery
  • An open or short in the power or ground circuit
  • Loose or corroded battery terminals
  • Failed PCM/ECM.
Sitat
The first thing to check is the battery, check the voltage, inspect for loose/corroded terminals, etc., do a load test on it too. Also inspect the grounds/wiring at the PCM. If that's good the other common fixes for a P0607 Control Module Performance DTC seem to be either replace the PCM or update (re-flash) the PCM with updated software.
Så er TS heldig så er årsaken ‘bare’ dårlig kontakt et sted eller så enkelt som et dårlig batteri men i verste fall at kontrollenheten (PCM) er defekt.
On 11/18/2022 at 9:33 PM, holok said:
Feilkoden som kommer opp på MaxiDas diagnose er P060700. Sier den noe??
P0607 heter "Control Module Performance Implausible" på VW.
Sjekk at girkassemodulen har god strømtilførsel og jording. Sjekk oljenivået på girkassa.
Når ble girkasseoljen byttet sist?
Var det ingen andre feilkoder?
Endret av mobile999
