Kalle Klo Skrevet 17. september 2022 Del Skrevet 17. september 2022 1 hour ago, 6RCURCGB said: Hehe, det var dagens. Hør med de du kjenner om de vil samsvarserklære batteriet iht. 2014/35/EU. Teknisk dokumentasjon må etableres og sendes tilsynsmyndighetene (DSB) hvis/når de ber om den. "2. Technical documentation The manufacturer shall establish the technical documentation. The documentation shall make it possible to assess the electrical equipment’s conformity to the relevant requirements, and shall include an adequate analysis and assessment of the risk(s). The technical documentation shall specify the applicable requirements and cover, as far as relevant for the assessment, the design, manufacture and operation of the electrical equipment. The technical documentation shall, where applicable, contain at least the following elements: (a) a general description of the electrical equipment; (b) conceptual design and manufacturing drawings and schemes of components, sub-assemblies, circuits, etc.; (c) descriptions and explanations necessary for the understanding of those drawings and schemes and the operation of the electrical equipment; (d) a list of the harmonised standards applied in full or in part the references of which have been published in the Official Journal of the European Union or international or national standards referred to in Articles 13 and 14 and, where those harmonised standards or international or national standards have not been applied, descriptions of the solutions adopted to meet the safety objectives of this Directive, including a list of other relevant technical specifications applied. In the event of partly applied harmonised standards or international or national standards referred to in Articles 13 and 14, the technical documentation shall specify the parts which have been applied; (e) results of design calculations made, examinations carried out, etc.; and (f) test reports." Det der gjelder hvis du skal selge det som et produkt. Er ingenting som hindrer deg i å snekre sammen noe elektronisk til eget bruk. Lenke til kommentar
6RCURCGB Skrevet 17. september 2022 Del Skrevet 17. september 2022 2 minutes ago, Kalle Klo said: Det der gjelder hvis du skal selge det som et produkt. Er ingenting som hindrer deg i å snekre sammen noe elektronisk til eget bruk. Å koble det til nasjonens strømnett faller vel utenfor "eget bruk"...... Lenke til kommentar
Kalle Klo Skrevet 17. september 2022 Del Skrevet 17. september 2022 (endret) 5 minutes ago, 6RCURCGB said: Å koble det til nasjonens strømnett faller vel utenfor "eget bruk"...... Det er intet hellig med strømnettet, nei (så lenge du kobler dingsen på innsiden av sikringsskapet ditt, vel å merke). Er radioamatører som bygger sitt eget utstyr, og det går ikke på batterier. Ingenting i veien for å lage din egen strømforsyning heller, men brenner du ned huset ditt, eller dreper noen, så må du ta konsekvensene av det. Endret 17. september 2022 av Kalle Klo Skriveleif Lenke til kommentar
Simen1 Skrevet 17. september 2022 Del Skrevet 17. september 2022 Kalle Klo skrev (5 timer siden): Jo, denne helga er vill, så spørs det hvor mange andre tilsvarende vi får. Man regner ca. 1000 ladesykler som levetiden på et Li-ion batteri, så må regne degradering av cellene også. Enda verre hvis det er brukte batterier med mange sykler på seg allerede. Det er ikke altid at batterier taper seg gradvis heller, har hatt en del tilfeller med laptop og mobil-batterier som plutselig eser i volum og dør mer eller mindre på flekken. Blir fort dyrt å få kvalifisert personell på plass for å bytte enkeltceller i en stor batteripakke. Et alternativ er å bruke pengene til å kjøpe solceller i stedet, så kan du selge kraft tilbake til nettet i stedet når du har tilovers. Tipper det blir fasiten en stund, og så kommer batterier når det blir så mye solceller at pris blir latterlig lav når solen skinner ordentlig. Artikkelen åpner med at Enova må støtte energilagring .. og er en snikreklame for Eatons hjemmebatteri, men det er ikke dermed sagt at batteri er den eneste måten å lagre energi på. Batteri er en relativt dyr måte å lagre energi på, til husbruk i et land som trenger varme store deler av året (den delen vi bruker mye strøm). Batteri er fancy, dyrt og flott, men den mest lønnsomme løsninga er nok langt kjedeligere.. varmtvannstank for å lagre varme på døgnbasis. En vanlig 200L tank kan lagre opp mot 23 kWh for noen få tusenlapper. En vifteradiator, noen rør og en sirkulasjonspumpe koster heller ikke veldig mye. Lenke til kommentar
N8591NB4 Skrevet 18. september 2022 Del Skrevet 18. september 2022 kremt skrev (På 15.9.2022 den 22.35): Hvis folk betaler for strømmen sin selv må de da kunne bestemme hva de bruker den til også. Om det er matlaging, varmekabler, sauna, jacuzzi eller varme i oppkjørsel med elkassett. Du må ha forvekslet nedward med meg når du siterer meg på forbud mot elkjel. Kjøpt strøm er kjøpt til hva kjøperen selv ønsker selvsagt. Lenke til kommentar
