ADSL Provider in Oslo
Hello.
NextGentel - www.ngt.no
Tele2 - www.tele2.no
Bluecom - www.bluecom.no
They are all good alternatives, but I would put my money on NextGentel as they offer the best bandwidth/cost ratio.
Tele2 comes second in my opinion, because of the simple fact that they're cheaper than Bluecom. Bluecom may be better in the way that they're said to deliver the speeds you pay for all the time, Tele2 does this MOST of the time.
Hope this helps you, and that you understood my english :blush:
EDIT: Since you're in Oslo I would chech www.firstmile.no first.
Endret av Xibit
  • 8 år senere...
For å oppdatere tråden litt for nye lesere kan det være greit å vite at de leverandørene som nevnt før i tråden er borte nå. Tele2 sluttet å leverer bredbånd for en 3-4 år siden, og UPC er vel borte for godt. Det finnes mange som kan levere bredbånd i oslo til private, deriblant Nextgentel, Broadnet, Telenor, Get m.fl. Sjekk hos alle sammen, så finner du det beste tilbudet. Tror forresten det er Broadnet som er billigst. Se selv her. En grei oversikt over ADSL og VDSL tilbud i Norge.
Så en engelsk versjon:
To update this post for new readers I would like to point out that the providers mentioned above are all gone now. Tele2 does exist though, but they don't provide broadband anymore. UPC seems to be gone for good. But there are many providers for broadband in Oslo. Check out the links above, and you will see the different available offers in Norways capital.
