Nizzen Skrevet 18. juli 2022 Del Skrevet 18. juli 2022 (endret) Ser ut som en greie cpuer til gaming Min fps får tydeligvis et løft fra mere cache. Nei det er ikke bare cpufrekvens som gjør det. Dette er nok heller ikke 4.9ghz all core vs 5.5ghz all core som det liksom ser ut til. https://www.guru3d.com/news-story/minimum-framerates-of-games-evaluated-on-an-engineering-sample-of-intels-core-i9-13900k-have-improved,2.html Luft Minnekjøler til DDR5/DDr4 https://www.aliexpress.com/item/1005003723202202.html Tips: Bytte ut med Noctua vifter lga 1700 frame anti bending https://go.skimresources.com/?id=130832X1600954&isjs=1&jv=15.2.4-stackpath&sref=https%3A%2F%2Fwww.overclock.net%2Fthreads%2Foverclocking-adl-12900k-etc-results-bins-and-discussion.1794706%2Fpage-342%23post-29022563&url=https%3A%2F%2Fwww.aliexpress.com%2Fpremium%2Flga1700-bracket.html%3Fd%3Dy%26origin%3Dy%26catId%3D0%26initiative_id%3DAS_20220820190723%26SearchText%3Dlga1700%20bracket%26spm%3Da2g0o.detail.1000002.0&xs=1&xtz=-120&xuuid=2c8a7411e0f8d96605160d45116b2a32&xjsf=other_click__contextmenu [-1] Mem oc : Do you have Round Trip Latency on fast boot - off mrc fast boot - off VDDQ training - on Round Trip Latency - on SenseAmp Offset Training - off Turn Around Timing Training - off DIMM DFE Training - off MCH Fullcheck - off UnderVolt Protection - on ----- For RFC/RFCpb choose from: 480/390 512/416 544/442 576/468 608/494 640/520 672/546 704/572 736/598 DDR5 water block https://www.aliexpress.com/item/1005004494126969.html?spm=a2g0o.productlist.0.0.28a95d83foJOHN&algo_pvid=69bc65a6-fa5c-4e96-877f-726195599132&algo_exp_id=69bc65a6-fa5c-4e96-877f-726195599132-1&pdp_ext_f={"sku_id"%3A"12000029353610664"}&pdp_npi=2%40dis!NOK!537.4!537.4!!!!!%40210318c916706892614844475e8d17!12000029353610664!sea&curPageLogUid=EUTg17wobQMb https://www.aliexpress.com/item/1005004705017150.html?spm=a2g0o.ppclist.product.354.28detaxItaxIUt&pdp_npi=2%40dis!USD!US %2445.99!%2443.69!!!!!%402103309e16706890605487634e4b9c!12000030167085499!btf&_t=pvid%3A440c65ed-c256-442d-a952-99be48ace519&afTraceInfo=1005004705017150__pc__pcBridgePPC__xxxxxx__1670689060&gatewayAdapt=4itemAdapt ------- Lavere v-core: VCCIN (Input voltage) to 1.86v and Core PLL to 0.975v. MSI beta bioser: https://drive.google.com/drive/folders/1IgmJA8uOay0-SE9hHI-XKjU1tMp4TPLg?fbclid=IwAR2d2g3WFa32RfoyCUMu9Ss1tAq5-98czfqDFJPd_T3oBntRyTlfZf1eoaY Og her https://drive.google.com/drive/folders/1IgmJA8uOay0-SE9hHI-XKjU1tMp4TPLg?fbclid=IwAR0Rkg6-_Rc9631GwFHFVEgh3cCt4e1mt3xnSZ1x542MKVgQd4ytD-nU3Y8 A Dies to try ODT 40/120/240/48/48 --------- DDR5 help RTP = 12, 14 ,15 , 17 , 18 , 20 , 21 , 23, 24 Tras = RTP + RCD (min floor) trefi = 256 * 1024/(1-8) - 1 . 131071 which is 256*1024/2 - 1 works 99% of the time on DDR5 with decent cooling. CWL = TCL - 2 (auto will do the math for you) Leave TWRRDsg/dg auto and change TWTRL/S instead. TWTRL = 32 | TWTRS = 8 , TWTRL = 26 | TWTRS = 6 , TWTRL = 16 | TWTRS = 4 (16/4 is the min floor) [ U can use other values too ] RRDL = 8 (min floor) RRDS = 8 ( always ) FAW = 32 ( always ) TRDRDsg = min floor 8 TWRWRsg = min floor 16 TRDRDdg = 8 ( always ) TWRWRdg = 8 ( always ) TCKE = 8 (min floor) tWRPRE = tCWL + tWR + 7 (for DDR5 2N) tWRPDEN = tCWL + tWR + 8 (for DDR5 2N) You can change TWR and leave TWRPRE/PDEN auto(ASUS 0904/0031 bios+ / EVGA board will follow the above math, dont know abt others) , manually changing TWRPRE and PDEN will override TWR value. DDR5 documentations use multiples of 6 for TWR values. i don't know how valid it is, u can take it for what u will. stick with even numbers for DDR5 Apex z790 0066 bios. Last Bianbao oktober 2023 https://www.overclock.net/attachments/rog-maximus-z790-apex-asus-0066-mod-2023-10-06-zip-txt.2632608/ Endret 12. februar 2024 av Nizzen 2 Lenke til kommentar
Nizzen Skrevet 18. juli 2022 Forfatter Del Skrevet 18. juli 2022 (endret) Blir gøy å teste Raptor Lake med 7000mhz + ddr5 mot Amd 7 serie cpuer Håper Amd får fart på ddr5 fra dag 1! Endret 27. august 2024 av Nizzen Lenke til kommentar
Nizzen Skrevet 24. juli 2022 Forfatter Del Skrevet 24. juli 2022 Bianbao spesial bioser for Apex https://bianbao.dev/post/category/test-bios Lenke til kommentar
NoBo Skrevet 26. juli 2022 Del Skrevet 26. juli 2022 Sitat DDR5 memory could deliver a 20% performance improvement for Raptor Lake chips if the latest benchmarks prove to be accurate. What you need to know Alleged Intel Raptor Lake CPU benchmarks by Sweclockers(via PC Gamer) show a major performance increase when the new processors are used with DDR5 memory modules. The benchmark results show a 20% increase when a 13th Gen Intel chip is used with DDR5 when compared to the same processor paired with DDR4. As with all benchmarks that come out before a piece of hardware is released, these figures need to be approached with healthy skepticism. … If the benchmarks are accurate when Intel's next generation of chips roll out, PC owners will likely race to pick up the best DDR5 RAMmodules. According to the benchmarks, a PC with an Intel Core i7 13700K got a multi-core score of 16,452 when using DDR4 and 19,811 with a DDR5 module. Single-core scores were almost identical across the PCs (2090 for DDR4 and 2069 for DDR5). Kilde. Ekspander Er vel ikke noen direkte overraskelse men kan bli interessant å se om det stemmer (og om man kanskje ser enda bedre tall 🤞). Lenke til kommentar
Nizzen Skrevet 26. juli 2022 Forfatter Del Skrevet 26. juli 2022 NoBo skrev (På 26.7.2022 den 19.12): Er vel ikke noen direkte overraskelse men kan bli interessant å se om det stemmer (og om man kanskje ser enda bedre tall 🤞). Ekspander Du skal få servert deilige tall når man kjører 7000mhz + c30 tweaked. Gled deg Lenke til kommentar
Phantom Software Skrevet 26. juli 2022 Del Skrevet 26. juli 2022 Har du vurdert x3D-serien til AMD for caching og gaming, @Nizzen? Kun 5800x3D som finnes per nå, men håper det kommer flere varianter i 7xxx-serien. Lenke til kommentar
Nizzen Skrevet 26. juli 2022 Forfatter Del Skrevet 26. juli 2022 Phantom Software skrev (På 26.7.2022 den 21.43): Har du vurdert x3D-serien til AMD for caching og gaming, @Nizzen? Kun 5800x3D som finnes per nå, men håper det kommer flere varianter i 7xxx-serien. Ekspander Nei, fordi jeg har 5950x og 12900k. Nedgradering på alt annet enn gaming for 5950x, og lite slår 12900k med 7000mhz ddr5. 7000 serie amd med 3d cache kan bli gøy Må jo testes. Lenke til kommentar
Phantom Software Skrevet 26. juli 2022 Del Skrevet 26. juli 2022 Drømmer om 7950x3D da så kanskje jeg kan komme meg bort fra Threadripper, men stopper nok på 7900x3D, om de utvider serien noe fra sist. Lenke til kommentar
Nizzen Skrevet 27. juli 2022 Forfatter Del Skrevet 27. juli 2022 (endret) Phantom Software skrev (På 26.7.2022 den 22.43): Drømmer om 7950x3D da så kanskje jeg kan komme meg bort fra Threadripper, men stopper nok på 7900x3D, om de utvider serien noe fra sist. Ekspander Drømmer du om 7950x3d er du i feil tråd. Jeg drømmer om 8000mhz Ddr5 på Raptor Lake Endret 27. juli 2022 av Nizzen 1 Lenke til kommentar
Phantom Software Skrevet 27. juli 2022 Del Skrevet 27. juli 2022 Woops, greit nok! :) Har to system nå - Intel for gaming, Threadripper som workstation. Hadde bare vært fint å slå sammen ved neste oppgradering Lenke til kommentar
Ola Norman Skrevet 28. juli 2022 Del Skrevet 28. juli 2022 (endret) Tja, vet ikke helt hva man skal si.. Intel Core i7-13700K and Core i5-13600K tested, higher performance with higher power consumption 13900k = ~12900KS 13700k = ~12900k 13600k = ~12700K Håper bare dem tilpasser prisene... Men ryktene sier at Intel blir å øke cpu prisene med pluss ~20% denne generasjon 🥴 Endret 28. juli 2022 av Ola Norman Lenke til kommentar
Nizzen Skrevet 28. juli 2022 Forfatter Del Skrevet 28. juli 2022 Ola Norman skrev (På 28.7.2022 den 18.41): Tja, vet ikke helt hva man skal si.. Intel Core i7-13700K and Core i5-13600K tested, higher performance with higher power consumption Ekspander Blir sikkert mye dårligere enn Alder Lake 1 Lenke til kommentar
Ola Norman Skrevet 28. juli 2022 Del Skrevet 28. juli 2022 Nizzen skrev (På 28.7.2022 den 18.45): Blir sikkert mye dårligere enn Alder Lake Ekspander Dårligere blir det vel neppe, men det kan se ut som om det blir ganske så likt det som allerede er til salgs 😝 Lenke til kommentar
Ola Norman Skrevet 31. juli 2022 Del Skrevet 31. juli 2022 (endret) Intel Core i5-13600K and i7-13700K pre-production samples have been tested in games Sitat While average framerate has only increased by 7 to 12% at FHD resolution, the minimum framerates certainly did improve for all resolution. This is a 11% to 14% improvement for FHD. The same improvement for minimum FPS was observed in 13900K test from the same reviewer. Ekspander ^^ 13900k = ~12900KS 13700k = ~12900k 13600k = ~12700K Endret 31. juli 2022 av Ola Norman 1 Lenke til kommentar
Ola Norman Skrevet 3. august 2022 Del Skrevet 3. august 2022 (endret) Live action: https://www.bilibili.com/video/BV1ka411Z74F Endret 3. august 2022 av Ola Norman Lenke til kommentar
Nizzen Skrevet 4. august 2022 Forfatter Del Skrevet 4. august 2022 Ola Norman skrev (På 3.8.2022 den 21.40): Live action: https://www.bilibili.com/video/BV1ka411Z74F Ekspander Romtemperatur 29 grader står det også. Dette er jo virkelig lovende med 5.6ghz på 13700k. Dette betyr at den er iskald under gaming Lenke til kommentar
Ola Norman Skrevet 4. august 2022 Del Skrevet 4. august 2022 Nizzen skrev (På 4.8.2022 den 6.38): Romtemperatur 29 grader står det også. Dette er jo virkelig lovende med 5.6ghz på 13700k. Dette betyr at den er iskald under gaming Ekspander Synes også dette ser lovende ut, men 29grader ambient er det nok neppe.. CPU idle nede i 25 eller 21 grader alt etter hvordan sensor man skal stole på -> kan tyde på ambient alt ifra 20 til 16 grader Lenke til kommentar
Nizzen Skrevet 4. august 2022 Forfatter Del Skrevet 4. august 2022 Ola Norman skrev (På 4.8.2022 den 6.47): Synes også dette ser lovende ut, men 29grader ambient er det nok neppe.. CPU idle nede i 25 eller 21 grader alt etter hvordan sensor man skal stole på -> kan tyde på ambient alt ifra 20 til 16 grader Ekspander Jeg bare leste hva som stod i teksten. Kan godt være at sensorene er feil også med "ikke oppdatert" hwinfo. Hvem vet Blir spennende å se iallefall. Dette virker som en fin forskjell fra Alder Lake. 5.6ghz med Alder Lake er det ikke mange som klarer med AIO. Lenke til kommentar
leifeinar Skrevet 4. august 2022 Del Skrevet 4. august 2022 HWinfo trenger vel litt oppdatering. Eller noe fancy kjøling? Fantastisk at AMD kom igang å lage litt konkurranse, bare vinn vinn for oss 😊 Lenke til kommentar
