Cowboystrekk Skrevet 8. juni 2022 Del Skrevet 8. juni 2022 Kjipt at prisene på DDR5 er så høye. 2x8 4800 koster 1500,- (og kan vell max klokkes til 5600). 2x16 koster 2k for 4800-5200, mens 6400 som de fleste som bygger nok vil ha koster 4600+. Du får et sett 2x8 B-die for 1200,- og et 2x16 B-die for 2300,-. Lenke til kommentar
guttorm Skrevet 8. juni 2022 Del Skrevet 8. juni 2022 Det er snakk om 20% pris dropp i det siste, så vi får se an utviklingen. Lenke til kommentar
Ola Norman Skrevet 9. juni 2022 Del Skrevet 9. juni 2022 (endret) AMD confirms Zen CPU architecture roadmap, Zen4 and Zen5 with V-Cache by 2024 The company confirmed today it will deploy both Zen4 and Zen5 architecture by 2024. The new CPU architecture also includes Zen4 and Zen5 equipped with V-Cache technology (interestingly, not listed as 3D). The Zen4 architecture based on 5nm and 4nm process technology will feature three different microarchitectures: Zen4, Zen4 V-Cache and Zen4c. The company did not clarify which of those architectures will make its way to consumer products specifically. Mark Pepermaster also confirmed that Zen4 architecture has IPC between 8% to 10%, while offering over 15% ST performance. The new architecture offer over 25% better performance per watt and 35% overall performance improvement over Zen3 architecture. This claim is based on Cinebench benchmark. Furthermore, Pepermaster revealed that consumer Zen4 products will launch before the data-center (Genoa) series. By 2024, AMD also plans to launch Zen5 architecture based on 4nm and 3nm process node. This architecture will also span across three sub-architectures: Zen5, Zen5 V-Cache and Zen5c. The new architecture will see improved performance and efficiency over Zen4. It will also see further optimization in AI and MI applications. This could suggest AMD will be adding more acceleration for more numerical formats used by different AI algorithms. Endret 9. juni 2022 av Ola Norman 3 Lenke til kommentar
Ola Norman Skrevet 9. juni 2022 Del Skrevet 9. juni 2022 ^^ Så om vi går ut ifra at Cinebench er blant verste tilfelle (low end of the scale) med tanke på "IPC" økning for Zen3 til Zen4, ref dette bildet: (Cinebench r20 ST er +13% mens geomean er 19%) Zen3 fmax 5050mhz VS Zen4 fmax 5850mhz = ~15% høyere clockspeed ST Performance base(Zen3) x 1.10 IPC x øket klokkehastighet med 15% = minimum ~26% høyere ytelse i ST performance i Cinebnench R23 I spill kan man sikkert fort få +20% eller mer IPC med tanke på dobling av L2 cache som Cinebench ikke bryr seg om. ST Performance base(Zen3) x 1.2 IPC x øket klokkehastighet med 15% = ~38% høyere ytelse i ST performance i "spill". På toppen av dette kommer økningen ifra DDR4 vs DDR5 med forhåpentligvis mye høyere infinity fabric clock som har begrenset Zen3 ytelsen i spill (latency) Lenke til kommentar
Cowboystrekk Skrevet 10. juni 2022 Del Skrevet 10. juni 2022 Ola Norman skrev (8 timer siden): ^^ Så om vi går ut ifra at Cinebench er blant verste tilfelle (low end of the scale) med tanke på "IPC" økning for Zen3 til Zen4, ref dette bildet: (Cinebench r20 ST er +13% mens geomean er 19%) Zen3 fmax 5050mhz VS Zen4 fmax 5850mhz = ~15% høyere clockspeed ST Performance base(Zen3) x 1.10 IPC x øket klokkehastighet med 15% = minimum ~26% høyere ytelse i ST performance i Cinebnench R23 I spill kan man sikkert fort få +20% eller mer IPC med tanke på dobling av L2 cache som Cinebench ikke bryr seg om. ST Performance base(Zen3) x 1.2 IPC x øket klokkehastighet med 15% = ~38% høyere ytelse i ST performance i "spill". På toppen av dette kommer økningen ifra DDR4 vs DDR5 med forhåpentligvis mye høyere infinity fabric clock som har begrenset Zen3 ytelsen i spill (latency) Et stort spørsmål blir om IF kan kjøre 1:1 eller om det blir som Alder lake med 1:2/gear 2. Får de til førstnevnte kan latency bli rå, blir det som Alder lake blir ikke latency noen høydare. Håper det blir flere 2 dimm hk å velge i. Lenke til kommentar
Simen1 Skrevet 10. juni 2022 Del Skrevet 10. juni 2022 (endret) Bør ikke tråden hete Zen 4 i stedet for Ryzen 4? Zen 4 er kodenavnet Ryzen 4 finnes vel ikke? Kun Ryzen 3, 5, 7 og 9? Endret 10. juni 2022 av Simen1 Lenke til kommentar
Dragonlove Skrevet 10. juni 2022 Del Skrevet 10. juni 2022 Simen1 skrev (1 time siden): Bør ikke tråden hete Zen 4 i stedet for Ryzen 4? Zen 4 er kodenavnet Ryzen 4 finnes vel ikke? Kun Ryzen 3, 5 og 7? Helt enig, den andre tråden heter vel Zen3 Lenke til kommentar
Simen1 Skrevet 10. juni 2022 Del Skrevet 10. juni 2022 Eventuelt kan tråden hete Zen 4 - AMD Ryzen 7000-serien Lenke til kommentar
Jarmo Skrevet 10. juni 2022 Forfatter Del Skrevet 10. juni 2022 (endret) Simen1 skrev (4 timer siden): Bør ikke tråden hete Zen 4 i stedet for Ryzen 4? Zen 4 er kodenavnet Ryzen 4 finnes vel ikke? Kun Ryzen 3, 5, 7 og 9? Fixed. Endret 10. juni 2022 av Jarmo 1 5 Lenke til kommentar
Slaps Skrevet 11. juni 2022 Del Skrevet 11. juni 2022 Kanskje Zen 4 med V-Cache ikke blir så avhengig av raske DDR5 minnebrikker. Litt som vi ser nå med 5800X3D. Lenke til kommentar
bshagen Skrevet 11. juni 2022 Del Skrevet 11. juni 2022 Slaps skrev (15 minutter siden): Kanskje Zen 4 med V-Cache ikke blir så avhengig av raske DDR5 minnebrikker. Litt som vi ser nå med 5800X3D. Håper den dukker opp i år i alle fall Lenke til kommentar
Slaps Skrevet 12. juni 2022 Del Skrevet 12. juni 2022 (endret) 22 hours ago, bshagen said: Håper den dukker opp i år i alle fall Ja det var det da. Jeg tror ikke det. Det ryktes som Q4 2022 lansering for Zen 4 (uten V-Cache). Det er nok litt avhengig om Raptor Lake slår Zen 4 eller ikke EDIT: Og det er kanskje også avhengig av DDR5 prisene/Salget av Zen 4. Zen 4 med V-cache kan være et grep for å gjøre AM5-platformen mer attraktiv Endret 12. juni 2022 av Slaps Lenke til kommentar
Cowboystrekk Skrevet 12. juni 2022 Del Skrevet 12. juni 2022 Slaps skrev (14 minutter siden): Ja det var det da. Jeg tror ikke det. Det ryktes som Q4 2022 lansering for Zen 4 (uten V-Cache). Det er nok litt avhengig om Raptor Lake slår Zen 4 eller ikke EDIT: Og det er kanskje også avhengig av DDR5 prisene/Salget av Zen 4. For å gjøre AM5-platformen mer attraktiv Mer cache ser ut til å gjøre plattformen mindre latency sensitiv, men båndbredde ser fremdeles ut til å gi et ytelsesløft så høy frekvens vil fremdeles hjelpe. Lenke til kommentar
Ola Norman Skrevet 22. juni 2022 Del Skrevet 22. juni 2022 Mulig Zen4 med vcache blir lansert allerede iløpet av året ifølge nye "rykter" 1 Lenke til kommentar
Ola Norman Skrevet 24. juni 2022 Del Skrevet 24. juni 2022 AMD Ryzen 7000X3D Gaming CPUs with 100MB of Cache in Mass Production, Launching this Year [Rumor] Sitat AMD may release these chips with fully unlocked multipliers as well considering that BCLK overclocking has been widespread but thermal issues may persist as 5nm dies will be much harder to cool. According to whispers on Twitter (Kepler_L2), the 3D V-Cache version of Genoa (Genoa-X) is also in mass production and may launch along with the vanilla SKUs later this year. 1 Lenke til kommentar
OC-Freak Skrevet 24. juni 2022 Del Skrevet 24. juni 2022 Hvorfor blir ikke zen 4 lansert med bare V-cache modeller for topp SKU's? Eneste ulempen med V-cache er vel høyere varmeutvikling og høyere produksjonskostnad. Men for entusiastmodellene er vel dette en liten pris å betale for mye bedre ytelse. Eneste grunnen jeg kan se ellers er for å lansere dette senere, f.eks q2 2023 for å hele tiden kunne gi markedet "noe nytt", mens neste generasjon utvikles. Lenke til kommentar
Dragonlove Skrevet 24. juni 2022 Del Skrevet 24. juni 2022 OC-Freak skrev (2 timer siden): Hvorfor blir ikke zen 4 lansert med bare V-cache modeller for topp SKU's? Eneste ulempen med V-cache er vel høyere varmeutvikling og høyere produksjonskostnad. Men for entusiastmodellene er vel dette en liten pris å betale for mye bedre ytelse. Eneste grunnen jeg kan se ellers er for å lansere dette senere, f.eks q2 2023 for å hele tiden kunne gi markedet "noe nytt", mens neste generasjon utvikles. Som vanlig så er det nok for å melke oss forbrukere for mest mulig penger, nylig kommer jo PCI 5 mens de allerede nå er begynnt å jobbe med PCI 7, er jo akkurat som Telenor også det, før i tida når vi hadde Isdn mens de satt på fiber teknologi allerede da. 1 Lenke til kommentar
Slaps Skrevet 27. juli 2022 Del Skrevet 27. juli 2022 Quote The cat is now out of the bag, the upcoming Ryzen 7000 SKUs have now been confirmed by … AMD. The company has tagged seemingly unrelated Ryzen marketing resource file for Ryzen PRO CPU with four Ryzen 7000 CPUs: Ryzen 9 7950X Ryzen 9 7900X Ryzen 7 7700X Ryzen 5 7600X Those are the only Ryzen 7000 CPUs listed in the library, and there is no sign of the Ryzen 7 7800X or Ryzen 3 7000 series yet. https://videocardz.com/newz/amd-confirms-ryzen-9-7950x-7900x-ryzen-7-7700x-and-ryzen-5-7600x-processors Ikke så spennende kanskje. Vi vet fortsatt ikke ytelsen. 3 Lenke til kommentar
FrihetensRegn Skrevet 27. juli 2022 Del Skrevet 27. juli 2022 Det lover veldig bra sett i forhold til det AMD lovet i sitt første seminar om Zen 4. Jeg håper bare at de fortsatt er like effektive som det Zen 3 er. En stock 5950X bruker omtrent halvparten så mye strøm som en stock 12900K under load (kilde: GamersNexus) Lenke til kommentar
Simen1 Skrevet 27. juli 2022 Del Skrevet 27. juli 2022 (endret) Jeg fant ikke enkelt fram til antall watt på de to på GamersNexus, men jeg vil bare minne om at strøm er dyrt i store deler av Europa for tida. Hvis vi raskt regner 3 kr/kWh i gjennomsnitt, 100 watt forskjell og i snitt 4 timer gaming på full load hver dag og ingen sekundær bruk av varmen, så vil stock 12900K koste 438 kr mer i strøm hvert år enn stock 5950X. Det er et enkelt å tilpasse regnestykket til sitt bruk, men jeg tror det er få som gjør det eller tenker over det. Men i serverparker og tungregnemaskiner er strøm en såpass stor kostand at det regnes alltid med, fra før man kjøper maskinene. I noen tilfeler spesifiserer de ned maskinvaren til lavere TDP for å få ned totalkostnaden over tid. Klarer de å spare 200W per U i en tungregnemaskin med 20 stk 42U, som kjører 24/7 så snakker vi om nesten 1,5 millioner kWh i årlig besparelse. Det blir fort penger når strømmen koster 3 kr/kWh og levetiden er 5 år. Endret 27. juli 2022 av Simen1 Lenke til kommentar
