Cowboystrekk Skrevet 25. august 2022 Del Skrevet 25. august 2022 Softis12 skrev (7 timer siden): Hvis vi skal basere oss på AM4 dagene så har de jo støttet den socketen i 5 år nå. Bare et tips, om du driver litt med overklokkbetc, få tak i et HK med bare 2 minnespor, jeg tror ikke du vil angre om noen år 1 Lenke til kommentar
Ola Norman Skrevet 25. august 2022 Del Skrevet 25. august 2022 (endret) Ny dag, nye leaks ? AMD Ryzen 7700X/7600X rumored Cinebench R23 scores are in Greymon claims that in single-core test, Ryzen 5 7600X scores 19XX points, while Ryzen 7 7700X up to 20XX range. Multicore benchmark result were not revealed. If only ST cores were to be considered, 7600X would score around Core i7-12700K, while 7700X reaches i9-12900K performance. But again, those are only single-core tests, which may go higher or lower as AMD implements further optimizations and leakers get their hands on final silicon. Those wondering why we have not seen CPU-Z leaks featuring Ryzen 7000 CPUs yet, is actually simple. In its current state, Ryzen CPUs reportedly have problem fishing the full benchmark. This might be solved soon as AMD releases an updated BIOS, however for now there are CPU-Z scores available. AMD 7000-series CPUs either do not run the benchmark in full (stuck at 80%) or show lower performance gains compared to Cinebench. In any case, it is probably better to wait for someone to verify this issue with the latest BIOS or using different samples. Interestingly, there are no benchmark results for Ryzen 9 series 7900X/7950X yet, however the mid-range series are already in many hands. Some of those CPUs even ended up on auction sites. AMD will unveil the Ryzen 7000 series next week. The company will most likely end the speculation by sharing official performance figures and hopefully prices for each of the four expected SKUs. *edit* Dette er vistnok 7600x manuelt overklokka til 5.6ghz allcore Endret 25. august 2022 av Ola Norman 1 Lenke til kommentar
Ola Norman Skrevet 25. august 2022 Del Skrevet 25. august 2022 (endret) Da har vi følgende: 7600x = 19xx ST og 151xx MT 7700x = 20xx ST og 198xx MT Ser ut som om det legges opp til en god fight mellom 13900k(32t) vs 7950x(32t) 13700k(24t) vs 7900x(24t) 13600k(20t) vs 7700x(16t) 13400(16) vs 7600x (12t) Kan muligens se ut som om det er på low-end intel blir å gjøre det best denne generasjonen, om man kun spiller Cinebench (bestcase for e-core) Endret 25. august 2022 av Ola Norman 1 Lenke til kommentar
Nizzen Skrevet 26. august 2022 Del Skrevet 26. august 2022 https://www.twitch.tv/amd Lenke til kommentar
Ola Norman Skrevet 27. august 2022 Del Skrevet 27. august 2022 (endret) Stock 7600X scorer 2032 ST poeng i Geekbench5 ifølge ryktet under 1613 * 1.26 = 2032 Endret 27. august 2022 av Ola Norman 1 Lenke til kommentar
Nizzen Skrevet 27. august 2022 Del Skrevet 27. august 2022 (endret) 6 hours ago, Ola Norman said: Stock 7600X scorer 2032 ST poeng i Geekbench5 ifølge ryktet under 1613 * 1.26 = 2032 Jeg er mere interresert hvor høyt man klarer å få ytelsen på disse billigste cpuene. Det har nok mest si med minneytelsen. På minnet alene, så kan denne scoren bli 200 poeng høyere. Kan fort bli en vinner i gaming 12900k @ standard 5.3ghz og litt tweaket ddr5 minne gir ca 2150 poeng i singlecore ytelse i GB 5. Endret 27. august 2022 av Nizzen Lenke til kommentar
Softis12 Skrevet 28. august 2022 Del Skrevet 28. august 2022 Da var den store dagen her Må si jeg personlig gleder meg, selv om streamen begynner litt sent :P Lenke til kommentar
Ola Norman Skrevet 28. august 2022 Del Skrevet 28. august 2022 (endret) Viste vel dette allerede, men sikkert greit å få bekreftet.. AMD Ryzen 9 7950X Zen4 CPU “F-max” frequency reportedly goes up to 5.85 GHz fmax på 7950x er 5850mhz på samme måte som fmax for 5950x er 5050mhz (derfor fleste oppnår 5050mhz på 5950x selv om boost spec kun sier "4900mhz") Endret 28. august 2022 av Ola Norman 1 Lenke til kommentar
leifeinar Skrevet 28. august 2022 Del Skrevet 28. august 2022 (endret) klokken når, norsk tid der er det stream i morgen? Endret 28. august 2022 av leifeinar Lenke til kommentar
TheKims Skrevet 28. august 2022 Del Skrevet 28. august 2022 leifeinar skrev (6 minutter siden): klokken når, norsk tid der er det stream i morgen? The event is set to kick off on August 29th at 7pm ET (23:00 UTC) Så kl 01:00 i natt. 1 Lenke til kommentar
Ola Norman Skrevet 28. august 2022 Del Skrevet 28. august 2022 (endret) Jeg mener streamen starter 01.00 natt til Tirsdag (norsk tid) Altså om ~33 timer ifra nå Endret 28. august 2022 av Ola Norman Lenke til kommentar
TheKims Skrevet 28. august 2022 Del Skrevet 28. august 2022 https://www.anandtech.com/show/17534/amd-sets-ryzen-7000-reveal-livestream-for-august-29th Blir ikke det i natt, eller er jeg helt på bærtur? Tidssoner er ikke bare bare Lenke til kommentar
Softis12 Skrevet 28. august 2022 Del Skrevet 28. august 2022 Må ærlig si at jeg var nok litt for tidlig jeg også :P 23:00 utc 29 august er tirsdag 30 august kl 0100 hos oss Lenke til kommentar
Nizzen Skrevet 29. august 2022 Del Skrevet 29. august 2022 On 8/28/2022 at 4:22 PM, Softis12 said: Må ærlig si at jeg var nok litt for tidlig jeg også 😛 23:00 utc 29 august er tirsdag 30 august kl 0100 hos oss Får kose meg med youtube til kaffen i morgen tidelig da Det gledes å få litt mere info! Lenke til kommentar
Nizzen Skrevet 29. august 2022 Del Skrevet 29. august 2022 Hvis dette stemmer, så er det epic fail... "AMD Ryzen 7000 "Zen 4" CPUs Hit Retail Shelves on 15th September But You Won't Be Able To Buy an X670 Motherboard Till 27th of September" Lenke til kommentar
Ola Norman Skrevet 29. august 2022 Del Skrevet 29. august 2022 Nizzen skrev (6 timer siden): Hvis dette stemmer, så er det epic fail... "AMD Ryzen 7000 "Zen 4" CPUs Hit Retail Shelves on 15th September But You Won't Be Able To Buy an X670 Motherboard Till 27th of September" Ikke tro på alt ifra WCCFTECH.. 😝 CPUene lanseres som først leaka 27.09 AMD Ryzen 7000 “Zen4” desktop series launch September 27th, Ryzen 9 7950X for 699 USD Offisielle slides Lenke til kommentar
Nizzen Skrevet 29. august 2022 Del Skrevet 29. august 2022 (endret) Denne sier vel det meste om gamingytelsen: Tror 7 serien før 3d kommer, skal slite med å holde følge med ddr5 tweaket 12900k og 13900k. Endret 29. august 2022 av Nizzen Lenke til kommentar
Ola Norman Skrevet 29. august 2022 Del Skrevet 29. august 2022 Live stream sendes her Lenke til kommentar
Softis12 Skrevet 29. august 2022 Del Skrevet 29. august 2022 Bare å bli med de andre 5000 som venter Lenke til kommentar
Simen1 Skrevet 29. august 2022 Del Skrevet 29. august 2022 Wow! Så mye økt TDP i hver klasse? x600X og x700X øker fra 65 til 105W (+62%) x900X og x950X øker fra 105 til 170W (+62%) Var det dette krympingen til 5-6 mn skulle gjøre? Dere som lurer på hvor etterfølgeren til 5800X er.. den er jo rett foran øynene deres på plansjen der. Den heter 7700X. 8 kjerner, samme TDP, nesten samme pris. Det er derimot 5700X som ikke får noen arvtaker på hverken 65W eller 8 kjerner. Der avspises man med samme pris på 299$, 2 færre kjerner, men likevel hele 105W TDP. Der ut som en generasjon man bør hoppe over. 1 1 Lenke til kommentar
