Gjest Slettet-404071
https://www.theguardian.com/world/article/2024/may/27/putin-patience-snapped-insiders-marvel-at-russia-military-purge
‘Putin’s patience snapped’: Insiders marvel at Russia’s military purge
Under new defence minister Andrei Belousov, FSB is tackling corruption aggressively with serious implications for Ukraine
“The FSB finally got their teeth in the defence ministry and general staff,” said Capt John Foreman, the UK’s former defence attache to Moscow, who said he believed the arrests could continue after “Putin’s patience had finally snapped”.
“Shoigu and Gerasimov provided a buffer, but now Putin decided he had to do something,” he said. “Shoigu kept the FSB largely away from the ministry throughout his tenure, there were very few arrests. Once the FSB has their teeth in you, who knows how far they will go.”
Throughout the war in Ukraine, Shoigu and Gerasimov have come under fire from pro-war advocates for the military’s setbacks and their failure to eradicate pervasive corruption within the armed forces. Last summer, this dissatisfaction reached its peak when Yevgeny Prigozhin, the founder of the Wagner paramilitary group, initiated an unsuccessful rebellion against the military’s leaders.
  • Liker 3
  • Innsiktsfullt 5
Brother Ursus skrev (16 minutter siden):
Disse M74 APAM klaseladninger har en ildpåsettelsesmekanisme, men dette opptaket er litt for ekstremt - skulle tro det var benyttet termitt/napalm/WP i klaseladningene som hadde falt ned. Ser ikke tegn etter ødeleggelser på opptaket, men det var definitivt et militært anlegg på hjul man så. Og vi vet at brannområdet er langt mye større enn hva opptaket viser, som ikke er mer enn få dusin meter - når det er flere hundre meter omkrets.
  • Liker 4
  • Innsiktsfullt 1
Jeg tenkte det kunne være flybensin eller andre kjemikalier.
bojangles skrev (8 timer siden):
Zelenskyj uttalte tidliger i uken at noe var på gang mtp flyforbudssone for vest-ukraina. Da regner jeg med at dersom det stemmer er det kanskje NATO skvadroner som flyr fra Polen og patruljer luftrommet?
Kommer noe slikt på plass kan det frigjøre ressurser for Ukraina slik at de kan fokusere mer styrker og våpen i fronten. Og kanskje kan styrker Frankrike og de baltiske landene stå ved grensen mot belarus? Om en da får et par F-16 skvadroner på vingene er situasjonen kraftig forbedret for Ukraina, både sivilt men også militært. En No Flight Zone over vestlige Ukraina kan kanskje også frigjøre noe luftvern?
Om dette skulle vise seg å være aktuelt så er det gjerne for å sikre at F-16 skal kunne operere fra tilstrekkelig beskyttede baser uten at man trenger å trekke ressurser vekk fra fronten og fra beskyttelsen av byer og andre viktige objekter.
Den dagen det blir kjent at F-16 er operativ hos det ukrainske flyvåpenet vil russerne trolig sette mye inn på å slå de ut. De vet at et tokt med F-16 nok er i stand til å presse russiske flystyrker langt tilbake inn i Russland, samt at F-16 har CAS kapasiteter som de russiske flyene ikke har på andre fly enn Su-25. Det betyr at man både kan beskytte de gjenværende ukrainske Su-25, og man kan i noen grad erstatte kapasitetene de tapte Su-25 stod for.
Men; det hele avhenger av hvilke våpen man leverer sammen med flyene. Jeg hadde ønsket at de fikk AIM-120C (aller helst D, men denne er vel ikke så veldig utbredt enda), og i en verden der julenissen finnes hadde det vært fint å fått kamptestet de nye AIM-260 som har over 200 km rekkevidde.
Det europeiske METEOR-missilet er klart å foretrekke som alternativ til AIM-120, men jeg tror ikke den er klargjort for F-16, dessverre. Dog hadde det vært en hyggelig overraskelse å fått dette demonstrert i Ukraina da det etter min er et missil som er AIM-120 langt overlegent.
  • Liker 6
  • Innsiktsfullt 3
Quote
Russiske ballonger ved grensa mot Finland
Russland har begynt å bruke overvåkingsballonger for å følge med på grensa mot Finland.
Ballongene, også omtalt som luftskip, ble omtalt i russiske medier forrige uke, ifølge den finske kringkasteren Yle. Farkostene skulle angivelig tas i bruk for å overvåke utlendinger som prøver å ta seg over grensa til Finland.
Den finske grensevakten sa først til Yle at de ikke hadde sett noen ballonger, men mandag meldte kringkasteren at farkostene var observert. Oberst Mikko Lehmus fortalte at russerne bruker ulike typer luftfartøyer til overvåking, nå også ballonger.
Ifølge Lehmus er det snakk om ballonger som er festet til bakken med tau så de holder seg på ett sted. Han påpeker at det ikke finnes noe forbud mot å følge med på naboland fra eget territorium.
Ballonger er jo veldig godt egnet til dette, vi så jo hvordan Kinas "værballonger" fikk kartlagt og filmet det meste av det de ønsket i USA. russerne ser ut til å starte med ankrede ballonger. Vi får følge godt med om noen disse krysser våre grenser også bare gjøre det en gjør mot fremmede farkoster som responderer til anrop.
  • Liker 3
28 minutes ago, bojangles said:
Store tap for russland siste døgn. Både av menn og maskiner. Mye russisk panser gikk tapt, 48 artilleri og 1 MLRS, 21 tanks, 40 pansrede personell kjøretøy samt 46 kjøretøy.
Jeg krysser fingrene for for en stor økning av antall Bradleys i Ukraina. Både fordi de fungerer kjempebra for Ukraina, de har taklet selv direkte treff uten at mannskapet har tatt sin død av det og fordi Bradley's har tatt ut alt av av russisk panser, alt fra T5x til T-90.
Det er ekstreme tilstander ved russiske sykehus i Belgorod nå også. De tar enorme tap også på nordflanken.
USA skal sende i hvert fall 100 Bradley til i første omgang, samt fler M109 og andre ting.
Jeg vil ikke si at stridsvognen er død - det er det mange som har gjort tidligere - men når de så enkelt kan tas ut av små droner og ATGM med ekstremt overlegen mobilitet og rekkevidde så er det lite vits i å investere mye penger i dem.
NATO-kravet til stridsvognsbataljon er tåpelig. I stedet for å kjøpe en ny Leo-bataljon, burde Norge ha brukt de pengene på fleksible og modifiserbare IFV'er som CV90 og Stryker-lignende kjøretøy med ATGM og droner og antiluftskyts og andre ting.
Endret av Brother Ursus
  • Liker 7
Sitat
Is Putin a threat to Eastern Europe?
Putin is a huge threat to Eastern Europe — that’s why Baltic and most Eastern European countries are the biggest supporters of Ukraine’s fight against the Russian invasion.
If Putin’s plans were limited to Ukraine, he wouldn’t have tried to blackmail NATO, demanding the alliance to withdraw to pre-1997 borders in December 2021.
The pompous ultimatum was made by Putin, so he could use it as a formal pretext to invade all other countries of the Eastern Europe and Baltics that became NATO members after the collapse of the USSR.
https://qr.ae/pscTPv
  • Liker 3
  • Innsiktsfullt 3
Gjest Slettet-ZwZXKsIXQp
Mannen med ljåen skrev (46 minutter siden):
Nå ser det ut som de første F16-flyene er i ferd med å bli operative i Ukraina:
https://www.forsvaretsforum.no/danmark-luft-materiell/ukraina-kan-fa-forste-f-16-til-sommeren/370716?noLog=1
Hva dette får å si for en nå ganske fastlåst artilleriduell, blir spennende.
Er Russland forberedt eller lukker de øynene og skjelver i buksene ? Et par nedskutte F16 vil ha en stor propagandaeffekt for Putin. Hvis Russland lider store tap, vil dette bli en fjær i hatten for Ukraina og vestlig teknologi. Teknologien er jo bare rundt 50 år gammel…..
Sitat
A Ukraine pilot says flying 'awesome' F-16s is like upgrading from an old Nokia to an iPhone
A Ukrainian pilot with the call sign "Moonfish" training to fly F-16s said it was like upgrading from a Nokia to an iPhone.
He said the jets were "awesome", "much easier to fly" for pilots and had more complex electronic systems than Soviet-made jets, were more "agile" than the MiG he flew before, and he added: "It feels like the jet wants you to fly it more aggressively."
"Moonfish," is one of six being trained to use the fighter jets at the Skrysdtrup base in Denmark.
https://qr.ae/pscNFt
  • Liker 3
  • Innsiktsfullt 1
  • Hjerte 3
  • Hvem er aktive   1 medlem
