Gjest Slettet-404071
https://www.businessinsider.com/china-economy-outlook-low-growth-long-covid-rebound-xi-jinping-2023-8
China's economy is trapped in a downward spiral that authoritarian regimes are doomed to repeat
"Economic development in authoritarian regimes tends to follow a predictable pattern: a period of growth as the regime allows politically compliant businesses to thrive, fed by public largess," he said, pointing to Russia, Venezuela, and Turkey as other examples.
"But once the regime has secured support, it begins to intervene in the economy in increasingly arbitrary ways. Eventually, in the face of uncertainty and fear, households and small businesses start to prefer cash savings to illiquid investment; as a result, growth persistently declines."
"Despite the West's growing tensions with Beijing, China's economic woes aren't necessarily good news for its rivals either, Posen said."
"When another global recession hits, China's growth will not help revive demand abroad as it did last time. Western officials should adjust their expectations downward, but they should not celebrate too much," he wrote.
Endret av Brother Ursus
  • Innsiktsfullt 2
19 hours ago, Brother Ursus said:
Spørs om det ikke snart blir en 250K achievement unlock for Taurus og ATACMS :)
La oss håpe det. Og så får vi krysse fingrene for at det blir sendt Taurus og ATACMS i stort nok antall til at UA ikke trenger spinke og spare på cruise missilene, men kan benytte de aktivt til å ta ut viktige mål. Og vi trenger fortgang i forsendelsen, samt jevnlig påfyll fremover.
Endret av bojangles
  • Liker 7
Stenger Nigers luftrom
Kuppmakerne i Niger har stengt luftrommet etter at den vestafrikanske samarbeidsorganisasjonen Ecowas har truet med militærmakt hvis de ikke trekker seg.
Ecowas hadde gitt juntaen frist til midnatt natt til mandag med å trekke seg og gi makten tilbake til den avsatte president Mohamed Bazoum.
Ecowas har ikke nevnt noe om når et eventuelt angrep kan skje, men hevder å ha alle ressurser som trengs for å gjennomføre en militærintervensjon.
Så langt har det ikke kommet signaler om at juntaen vil gi makten tilbake til presidenten. (NTB)
Ser ut til at temperaturen stiger i Niger også. Det hevdes at Russland og Wagner i hvert fall delvis står bak. Organisasjonen for økonomisk samarbeid mellom Vest-Afrikanske stater, muligens støttet av USA og Frankrike, truer militærintervensjon.
EDIT: Nigeria leder ECOWAS, og truer med militærintervensjon. Flere andre afrikanske militærdiktaturer truer med å behandle et angrep på Niger som et angrep på dem. Ser ut til at kampen mellom demokratier og autokratier kanskje tilspisser seg i andre deler av verden.
  • Innsiktsfullt 2
Jeg kommer til tråden for å lese oppdateringer om krigen, ikke å lese krangler om banale detaljer i norsk språk. Ta diskusjonen i direktemeldinger hvis den må tas.
Nå, når vi er på trådens tema; hvor påvirket vil krigføringen være av høst / vinter? Er det til fordel for Russland eller Ukraina, eller ingen? Virker som det er motstridende meldinger på nettet avhengig av hvem man hører på.
Endret av The Very End
  • Innsiktsfullt 1
  • Hjerte 1
Det vil bli vanskeligere for Ukraina å gjennomføre offensiver, så på den måten er det en fordel for Russland.
Og jo lengre Russland får holdt på frontlinjene jo mer får de befestet de, så det er også en fordel for Russland.
Samtidig går det tid, og tid vil jeg si er i Ukrainas favør. Russlands militærmakt forvitrer, ettersom de taper utstyr som kun kan erstattes med eldre dårligere utstyr, og bruker opp mer og mer av missilene sine, uten noen realistisk tanke for hvordan de kan erstattes.
På den andre siden får Ukraina mer og mer moderne vestlig utstyr, og vestens ammunisjonsfabrikker ramper fortløpende opp.
Jeg tenker at om Ukraina ikke klarer frigjøre store områder i år, så vil det fortsatt ikke være enkelt neste sommer, ettersom det vil være enda flere minefelt. Men innen neste sommer kan f.eks siste rest av Ka-52 være skutt ned, slik at det på noen måter blir enklere. Helikoptrene har spilt en stor rolle denne sommeren i å vanskeliggjøre en offensiv.
Vi får bare se. Som sagt, jeg tror tiden er på Ukrainas side, så om den suksessfulle frigjøringen av de okkuperte områdene kommer i år, neste år eller året etter får vi bare se.
(Åpenbart, for Ukraina har det enorm betydning når det skjer. Det er en enorm kostnad ved å være i krig, og for de som lever under okkupasjon må det være forferdelig.)
Endret av Espen Hugaas Andersen
  • Innsiktsfullt 3
Nå er dette et diskusjonsforum, ikke en nyhetstjeneste.
Fra førstepost:
"Hold deg til tema. Denne tråden er for løpende diskusjon og nyhetsoppdateringer rundt utviklingen av konflikten. Ønsker du å diskutere andre forhold, så anbefaler vi at du oppretter en ny tråd. Avsporinger blir fjernet, og brukere som bryter dette kan bli utestengt uten forvarsel."
  • Liker 6
  • Innsiktsfullt 2
  • Hjerte 1
Jeg kikket litt på situasjonen med Ka-52, og Russland startet krigen med 133 stk. Ser man på Oryx er det bekreftet 38 tapt, så Russland har maksimalt 95 stk, pluss det de kan ha produsert siden krigens start.
Men så er det også slik at mange tap vil ikke dokumenteres. De vil falle ned i ulendt terreng, kanskje dypt inne i Russiske områder, eller klare å komme seg tilbake til flybasen, men kreve år med reparasjoner, eller være ureparerbar.
Oryx har dokumentert 100 tapte helikopter, Ukraina påstår å ha skutt ned 311 helikopter. Dette er nok det maksimale forholdstallet man kan forvente, 1:3, men antar vi et mer forsiktig forholdstall på 1:2, så antar vi altså ytterligere 38 tapt men ikke dokumentert, slik at Russland sitter igjen med 57 stk.
Dette er heller ikke den styrken Russland vil faktisk klare å holde i drift til enhver tid. Det tar på å fly oppdrag etter oppdrag, og det må fortløpende gjennomføres vedlikehold.
Jeg ville tro Russland klarer å holde omtrent halvparten av flåten i drift, altså kan de ha rundt 28 Ka-52 i drift til enhver tid. Ikke alle vil være i Ukraina.
Dette er fortsatt en betydelig styrke, men det er ikke noe tvil om at antallet begynner å nærme seg et nivå der de slutter få betydning for krigen. Gi det et år til, så kan man forvente at man er der.
  • Liker 5
  • Innsiktsfullt 1
  • Hjerte 1
sedsberg skrev (15 minutter siden):
Russerne bryr seg ikke, og bryter alt av lover og konvensjoner som om det holder på å gå av mote. Og det kommer de til å fortsette med så lenge det ikke får konsekvenser for de.
Ja, det er lite til ingen respekt for internasjonal lover bortsett fra når de iblant beskylder Ukraina og andre for å bryte dem, gjerne i sammenheng med egne brudd. Det ekstra bisarre er at Putin studerte internasjonal lov med hovedfagsoppgave i folkerett ved universitet i Leningrad. Riktignok med tema handel, men likevel er det fortellende om han og Kremls makabre mangel på moral og forskrudde verdenssyn i forsøk på å legitimere sine handlinger.
Endret av Snikpellik
  • Liker 4
  • Innsiktsfullt 4
  • Hjerte 1
6 minutes ago, Brother Ursus said:
Dette skal være en oversikt fra en tysk avis. Hva Tyskland har lovet Ukraina, kontra hva de har levert.
Da foretrekker jeg den norske utgaven, hvor ting bare dukker opp, før man innrømmer det.
Jeg kunne ikke få dette til å stemme, men det kan stemme når det står at det gjelder Mai-pakken. Altså mye utstyr lovet tidligere enn Mai er levert.
  • Innsiktsfullt 1
