Metal Gear Solid - Twin Snakes
Nexxi
Har hørt litt rundt på P-MGS.
Omi:
Its a much easier process to just:
Remodel the polygons
Change the Controls
Adapt the MGS2 Engine for Gamecube
Adding the Shadow Moses map.
Compared to:
Writing a whole new engine
Plus the whole other malarky of the porting process...
Its cheaper, easier, and more sensible to use a currently existing engine if they feel they can get the same performance from it if they were to do their own engine.
Of course, the TTS engine is optimized for gamecube, plus various other differences so it isnt a carbon copy of the MGS2 engine, but I'm sure the programming fundamentals and structure of the MGS2 engine was more than enough to work with TTS without a hitch...
OK, vi tar begge feil:
Jonny: We know it’s a remake of the original, with the graphics and gameplay of Metal Gear Solid 2, right?
Denis: That’s correct.
Jonny: OK.
Denis: Well the graphics, actually, the graphics we’ve done a little bit more with… we’ve got a unified pipeline, we’ve got all different textures, bump-mapping, shine-mapping, all that stuff’s in there too. It’s not the “same” graphics as Metal Gear Solid 2 so much, but they’re upgraded graphics.
Jonny: So would you say they’re upgraded from the original Metal Gear Solid?
Denis: Oh yeah! Definitely, oh yeah.
Jonny: But not upgraded from Metal Gear Solid 2 graphics?
Denis: Uh, I guess it depends on what you mean by that question. It’s not… the engines are similar, but it’s obviously not the same technology, it’s running on the Cube. The Cube’s got some enhancements over the PlayStation 2, things that we can do that they can’t. That’s the best way to describe it. Does that answer your question?
Jonny: Yeah.
Denis: OK.
Jonny: What is the engine that it’s running on? Is this something that you guys made yourselves?
Denis: It’s a combination of some of our technology, and some of Konami’s technology.
Jonny: OK, so it’s not like a port of the PS2 engine, or something like that?
Denis: Uh, no… not really.
Planet Gamecube
Han hadde visst ikke sovet noe særlig før dette intervjuet, så det forklarer den litt rotete måten han sier ting på. :D
Endret av Niskivara
Hmm.
La oss si det sånn, siden vi ikke kommer noen vei: TTS bruker ikke den eksakt samme motoren. De bruker en motor med de samme basiske kodingene som MGS2 motoren hadde. (Gameplay er bl.a. veldig likt)
Motoren er også optimert for GC, noe som gjør at den er mer presis, funker bedre, en smule bedre grafikk og så videre.
Planet MGS
Ta en titt og meld deg inn på forumet! :yes:
Hmm.
Planet MGS
Jeg har tatt en titt.
De folkene på forumet bare gjetter. Hvis grafikkmotoren hadde vært bygget oppå MGS 2 motoren hadde Dyack sagt det. Men det han sier er at det er ny teknologi, med litt av Konamis kode i(Ikke spesifikt MGS 2 koden), litt av SK's kode i, og ikke en "port" av grafikken.
Og grafikken blir ikke en smule bedre enn MGS2, den blir mye bedre(Har du sjekket ut skyggeleggingen på figurene?).
Gameplayet er det samme som MGS 2, men med et par oppgraderinger. Fysikk og AI også.
Det å bruke MGS 2 grafikk motoren og "porte" den over til Gamecube hadde nok vært vanskelig. Bare se hvordan det gikk med MGS:Substance på X-box. X-boxen greide ikke å kjøre spillet ordentlig.
Skal se om jeg melder meg inn på forumet etterhvert..... :)
