Rimeligste smart røykvarsler?
Hva er den rimeligste røykvarsleren med smart funksjonalitet som er brukbar?
Har i dag 8 stk "dumme" varslere som er serikoblet, og skulle vel gjerne hatt noe med smart funksjonalitet i alle rom, men det blir nok alt for kostbart.
En mulighet er kanskje å komplementere de opprinnelige varslerne med en smart varsler i hver etasje?
Gjest Slettet+6132
03/08/2021
I bought 2 of those. Here are a few pointers: + alarm is very loud. that's good. + both connected seamlessly to wifi and to BlitzWolf app. + this does not support Google Home and the unit will not appear as a device on Google Home. + it comes with a very good 3M double sided tape to stick to the ceiling. I used it and it holds. + it also has a small kit for drilling into ceiling if you prefer. + battery level is shown on the app. useful. overall BlitzWolf support is great. I recommend their products.
