Intel 12 serie Alder Lake cpu
Nizzen
Når man har litt ekstra plass å innrede som nerderom er det ikke dumt i det hele tatt å kjøpe kontormøbler fra bedrifter som selger disse for en billig penge når de flytter, fusjonerer eller legger ned. Har selv flere ganger vurdert å kjøpe både kontorstol, pult og skap/hyller i slike tilfeller på egen jobb.
Dette er møbler som gjerne holder i nesten evig tid.
Før i tiden var det også standard med strietapet oppå gips som man ser på bildet. Det var faktisk et byggkrav og man måtte legge det oppå gipsplatene. I nyere tid har mange sparklet oppå dette for å skjule strietapeten men i rom som ikke er hverdagsrom vil man fortsatt se denne mange steder.
Men back to topic 😛
Endret av Theo343
https://www.igorslab.de/en/intel-deactivated-avx-512-on-alder-lake-but-fully-questionable-interpretation-of-efficiency-news-editorial/
Intel completely disables AVX-512 on Alder Lake after all – Questionable interpretation of “efficiency”
Intel is now set to disable “AVX-512” completely on all Alder Lake CPUs with an upcoming microcode update in new BIOS releases. Mainboard manufacturers were able to make the supposedly disabled instruction set available at launch, which resulted in a significant performance increase for the P-cores of the new CPUs. Now Intel is tightening the noose completely after all and, according to our sources, has instructed motherboard manufacturers to completely disable the “unsupported” feature.
Just in time for the launch of the new smaller CPU SKUs and motherboard chipsets at CES next week, all existing Z690 motherboards are supposed to completely disable the AVX-512 instruction set via a BIOS update. So far, we can only speculate about the motives. However, it would be logical that Intel would want to artificially create a sales argument for upcoming workstation and server products. This is because applications in the enterprise sector in particular often benefit the most from the acceleration provided by the AVX-512 instruction set. Actually completely capable “consumer” hardware should, if Intel has its way, no longer be a valid option here. To protect our sources, we do not wish to name them.
Så går vi tilbake i tid:
https://www.anandtech.com/show/17047/the-intel-12th-gen-core-i912900k-review-hybrid-performance-brings-hybrid-complexity/2
Hva sier dette oss?
Ja ganske lite :p
Vi har allerede muligheten for å "injekte" avx 512 igjen i nyere bioser, for de som absoulutt MÅ ha avx 512 med E-cores (fattig kjernene) disablet.
Ja dette er virkelig for de spesiellt interreserte. Om noen egentlig 😅
Nizzen skrev (7 minutter siden):
Hva sier dette oss?
Ja ganske lite :p
For topp plassering her er avx512 helt nødvendig:
Punish it with y-cruncher
rev21
Og sånn som jeg leser den nyheten, Intel blir å fjerne muligheten helt for alle med nyere bioser..  Begynner å ligne litt på agesa dette, som enkelte liker å kritisere 😆
Endret av Ola Norman
https://videocardz.com/newz/intel-teases-core-i9-12900ks-cpu-with-boost-clock-up-to-5-5-ghz
Intel Core i9-12900KS up to 5.5 GHz boost clock?
The company has just posted a mysterious picture on its social media, claiming that the 12th Gen Core (Alder Lake) CPUs are already topping the ‘best CPU’ lists and are already available. However, this is not the final word, as Intel teases ‘a next stop’ at 5.5 GHz.
In other words, this might be the first tease of the upcoming factory binned chip which we mentioned last month. The company is working on a Core i9-12900KS CPU with all Performance-core boost frequency at 5.2 GHz. This is exactly what we said in our article and this is exactly what the HWINFO screenshot posted by Intel appears to show.
Furthermore, we learn that the highest boost clock of the 12900KS would be 5.5 GHz, which is a single-core frequency. Overall, this should be the fastest Alder Lake-S CPU that will be set to compete against the upcoming AMD Ryzen 6000 CPU series with 3D V-Cache.
Så dette er +200mhz overall? (tror dere de bruker skjult chiller under bordet når de demo'er denne chipen også? 😂)
5.5ghz / 5.3ghz = en teoretisk økning på ~3.7%.. Vet ikje helt hvor mye dette har  å si i praksis, er nok mer å hente på å tune rammen.. Satser på at IMC også er bedre binna på disse 😇
Men en ting er iallefall sikkert, virker som om Intel er redd for "Zen3 v-$" som vi får mer info om imorgen klokken 16.00 🤣
Virker mere som du har VELDIG lyst på Alder Lake, så mye du skriver om det 🤭
Ola Norman skrev (2 timer siden):
Tipper det er +100 MHz for selve CPUen, samt +200 MHz med TVB i to steg (sikkert noe sånt som 55C og 75C).
Stock 12900K booster ikke høyere enn 5.2 GHz forresten
