Intel 12 serie Alder Lake cpu
Nizzen
2 hours ago, BadCat said:
Det var i livestreamen til ASUS de nevnte høydeforskjell. Hva skal du med en CPU med 228W max power draw til medieavspiling? Det må være 10 ganger overkill. Selv 11400 støtter det som trengs av hardware decode, inkludert AV1, for den som vet å skru det på.
Spiller jo "It takes two" med minsten på den. Den har ett 3070 kort og ett par xbox kontrollere også. Bra alternativ til PS5/XBOX :)
Hadde vi bare kjøpt det vi trengte her i verden så hadde det blitt kjedelig. Er jo litt hobby dette her. Lego for voksne :)
Endret av magnusavr
Litt bakgrunns-info ifra Igors:
https://www.igorslab.de/en/intel-alder-lake-gaming-performance-benchmarks-why-am-i-in-720p-again-with-an-amd-radeon-rx-6900xt-instead-of-a-nvidia-rtx-a6000-fair/
From my point of view it is not irresponsible to create such benchmarks at a very early stage and also to use them as an internal comparison and orientation, but it is well known that the Ryzen CPUs under Windows 11 had to accept performance losses of up to 15% compared to Windows 10. But then a deliberate publication of false benchmark results is all the more questionable. I’ve remeasured some things with a completely updated system (Windows patches, AMD chipset drivers, motherboard BIOS) and can really only shake my head.
I won’t mention any numbers here for reasons, but it’s definitely the case that the picture has changed visibly in some cases. To produce such a silly slide that is reasonably up-to-date, you don’t even need a whole working day for benchmarking a single CPU and the necessary correction in PowerPoint. For a company with Intel’s resources, all this is actually a piece of cake, but quite obviously not wanted by the marketing department.
Ser ikke ut som om Intel har lært ifra principled technologies flausa
Endret av Ola Norman
bruker-540634 skrev (2 timer siden):
Får litt 2600k vibe av denne lanseringen, bortsett ifra at prisene har gått til himmels.
Er nok nærmere første generasjon Core, det første tegnet på at Intel har våknet opp.
Foveros vil komme om et par år, da får vi virkelig se høye kjernetall fra Intel på desktop
  • Innsiktsfullt 2
