Intel 12 serie Alder Lake cpu
Nizzen
Det blir vel mangel på disse brikkene også. Lurt å forhåndsbestille/kjøpe fra dag 1. Helst noen minutter før bestillingene offisielt starter. Bestilte ASUS 3080 strix OC, tre minutter før salget startet, altså 14:57 i september i fjor. Var heldig å få kortet noen måneder senere.
Bare en måned igjen nå, så er det fullt kaos :green:
eat crab, get it! 😅
Intel Core i9-12900K samples are already available on the Chinese black market for 700 USD
What was happening on closed forums for a few weeks now, has now spread to public platforms. Intel 12th Gen Core CPUs are now available on the black market, as discovered by @yuuki_ans.
Intel Alder Lake engineering samples, Source: Taobabo
Intel supplies thousands of engineering samples prior to each launch to system integrators, OEMs, and motherboard makers. Eventually, a number of those chips are offered on the black market. This is not really happening unbeknownst to Intel, the company is well aware of the CPUs being sold before launch. However, the CPU maker does not usually intervene or track the sources of these samples unless it is offered alongside next-gen motherboards. In such a case, people purchasing those samples may cause a lot of trouble for Intel, by becoming the main root for leaks.
Intel Core i9-12900K ES2, Source: Taobabo
The samples being sold on Taobao second-hand market are supposedly Core i9-12900K, although the sellers do note that those chips are not displayed as such. It is said that those are ES2 which means second-gen engineering samples, which are distributed months ahead of qualification and review samples. Those samples usually do not represent the final state of the processor, as they may contain minor hardware bugs and lower frequencies compared to retail units. Still, they may work and may be of interest to some enthusiasts.
There are quite a few samples on sale, but they usually cost 4500 CNY, which is 700 USD. The final price of Core i9-12900K is not known yet but should be less than that. In any case, we do not recommend buying this CPU, considering the fact that the series will on preorder next month.
Endret av Ola Norman
DDR 5 max overklokka = CL50  @ 8000MT/sec 🤣
 50/(4*10^9/s) = 12.5 ns latency
(jeg poster dette på en pc med kalkulert ~6.8 ns latency)
Intel Alder Lake with overclocked DDR5 memory to 8000 MT/s
Store spørsmålet er om Gear4 var nødvendig eller om dette er mulig @ Gear2 ..
Vent nå litt, siden det står uncore frequency = 2002mhz, betyr det at dette er gear4?
Uncore på halve ddr hastigheten betyr tydeligvis gear 2 etter hva jeg leser på andre forum..
Men jeg ser også noen som skriver dette:
Sitat
This should be probably LN2 . DDR 5 6200mhz needs 1.5v , Now for 8000Mhz , DDR5 needs at least 1.75v
Kanskje litt relevant for Alder lake med tanke at windows11 er veldig sterkt anbefalt for next gen intel
Windows 11 & 10: Benchmarks for VBS performance loss including HVCI
The system requirements of Windows 11 , which have been significantly increased by Microsoft, are intended in particular to increase the security of the new operating system. In addition to the required TPM, this is also ensured by the virtualization-based security (VBS) integrated in Windows. UL Benchmarks sees performance losses, ComputerBase has measured it.
VBS from Windows 10 becomes an issue in Windows 11
Virtualization-based Security (VBS) is already integrated in Windows 10, but is deactivated by default. With Windows 11, Microsoft now officially wants to work with OEMs to ensure that VBS is activated ex works.
According to UL Benchmarks , the developers behind 3DMark or PCMark, VBS is also active when Windows 11 is not installed as an update from Windows 10, but on an empty drive - and this would also affect many enthusiasts.
https://www.notebookcheck.net/Intel-issues-list-with-DDR5-4800-RAM-modules-validated-for-the-Alder-Lake-platform.568959.0.html
"We already know that Alder Lake supports DDR5-6400 and even DDR5-8000 specs thanks to the Gear 2 and Gear 4 modes that lower the memory controller speeds. Intel probably did not want to test overclocked modules as these appear to introduce increased latencies that may affect certain workloads."
Så hva er best av DDR5-4800 gear 1 og DDR5-6400 gear 2?
Noen som har peiling?
Jeg vet når jeg har testet det ;)
Latency er fortsatt KING i gaming, derfor vinner Gear 1 over Gear 2 med Rocketlake. Samme med Zen 3. 1:1 mem infinity fabric er KING i gaming.
Endret av Nizzen
Nizzen skrev (5 minutter siden):
Hvis DDR5-6400 ikke kan kjøres i 1:1 (gear 1), som jeg tolker fra teksten jeg siterte lenger oppe, da er DDR5-4800 gear 1 bedre enn DDR5-6400 gear 2, ikke sant? Har ikke vært borti disse gear-greiene før. Men her kan det jo virke som at DDR5-4800 er veien å gå.
Robotix skrev (På 9.10.2021 den 19.05):
Helt i starten inntil ddr5 specen har modnet litt, får man nok best spill ytelse med Alder lake + ddr4.
48 minutes ago, Ola Norman said:
AIDA64 FPU -> CPU package power = 257W med cpu temp rapportert til 108 grader
Slik går det med noobs som får ES....
Ingen nyttig info. H*n hadde vel løs 1150 kjøler på, siden det ikke er ute s1700 feste enda :)
Elsker at du prøver å poste masse "negativt" om den nye generasjonen. Nesten som om du er redd for at du må oppgradere til Alder Lake :p
Endret av Nizzen
Nizzen skrev (På 9.10.2021 den 18.52):
Enkelte spill får bedre ytelse i gear 2/IF 2:1, men du må drygent høyt opp i frekvens da, typ 4500+. Likte egentlig Zen/Zen+ og Skylake 5-10th sin tilnærming bedre hvor du bare hadde gear 1 å forholde deg til :) skulle ønske Zen 2 og 3 samt Rocket lake hadde kjørt tvungen sync og så får ram makse ut på 3700-4200. Gear 4 høres skikkelig kjipt ut.
Cowboystrekk skrev (8 minutter siden):
Ja og med drygt høy frekvens så øker prisen deretter også, og det man oppnår er kanskje bittelitte grann bedre resultat enn DDR5-4800. Ikke sikkert at DDR5-6400 er nok, har lest en plass at DDR5-7200 er maks på gear 2.
Men enkelte av ASUS hovedkortene ifølge lekkasjer, støtter maks DDR5-6000 - DDR5-6400. Det blir spennende å se om de dyrere kortene kanskje støtter DDR5-7200+
https://optocrypto.com/asus-z690-motherboard-ddr5-memory-overclocking-capability-blows-up-to-6400mhz/
"According to the leak, the Z690 F-GAMING motherboard will support maximum OC speeds of 6400, while the PRIME-A will be limited to 6000. For models with DDR4 memory, this value reaches 5333."
