Dennis99 Skrevet 6. august 2021 Del Skrevet 6. august 2021 https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=https://www.googleadservices.com/pagead/aclk?sa=L&ai=DChcSEwiZjtT7qJzyAhXMIK0GHepkBwwYABAGGgJwdg&ei=piANYZyPFsSl1QGdqLu4Bw&ohost=www.google.com&cid=CAESQOD2IrvGQGhegWkWfzScOgayFYUbGPPL-DZ4Hrx9uiWOn2SKwkdTnjTKhHTyrth4V67YuLkf-inu8Q80ST-97dc&sig=AOD64_0GN_0Evu-qlawP-JROHoiqsYRKdA&ctype=5&q=&sqi=2&ved=2ahUKEwic-sn7qJzyAhXEUjUKHR3UDncQ9aACegQIARBc&adurl=Funker geforce gtx 1070 i hovedkortet her. https://www.komplett.no/product/1184447/datautstyr/pc-komponenter/pc-i-deleroppgradering/oppgradering/oppgraderingspakke-core-i5-11600k-z590?channable=00808169640031313834343437c7&gclid=Cj0KCQjwu7OIBhCsARIsALxCUaNZTBBBaUKDPTXCAnFaG9KXkjuTLcfczaaHTue8tq7dCdLqjQBIPHQaAmpaEALw_wcB&gclsrc=aw.ds Det heter Asus Prime z-590-p. Tenker å kjøpe hele oppgraderingspakken. Lenke til kommentar
kjeLL// Skrevet 15. august 2021 Del Skrevet 15. august 2021 velkommen til forumet. svaret er ja. Lenke til kommentar
PaladinNO Skrevet 15. august 2021 Del Skrevet 15. august 2021 Heisann, det var en ekstremt lang link! https://www.komplett.no/product/1184447/ Jepp, et GTX 1070 fungerer utmerket med den pakken der. Lenke til kommentar
bruker-540634 Skrevet 15. august 2021 Del Skrevet 15. august 2021 (endret) Hvis du plusser på en tusenlapp så får du bedre hovedkort og minne med dette oppsettet: https://prisguiden.no/produkt/asus-tuf-gaming-z590-plus-wifi-490583 https://prisguiden.no/produkt/intel-core-i5-11600k-498945 https://prisguiden.no/produkt/g-skill-trident-z-rgb-ddr4-3200mhz-cl14-16gb-2x8-gb-304757 Hvis du uansett må ha wifi adapter så blir prisen omtrent det samme da det allerede er intrigert i hovedkort. Kjører samme minnet selv på 3600mhz cl14 på 1,475v. Kan lett komme over 4000+ med høyere spenning. Endret 15. august 2021 av bruker-540634 Lenke til kommentar
