Jesper Karsrud Skrevet 7. januar 2004 Del Skrevet 7. januar 2004 Se på denne koden: <HTML> <HEAD> <TITLE>VegiBoys</TITLE> <META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=iso-8859-1"> <!-- ImageReady Preload Script (VegiBoys.psd) --> <script TYPE="text/javascript"> <!-- function newImage(arg) { if (document.images) { rslt = new Image(); rslt.src = arg; return rslt; } } function changeImages() { if (document.images && (preloadFlag == true)) { for (var i=0; i<changeImages.arguments.length; i+=2) { document[changeImages.arguments[i]].src = changeImages.arguments[i+1]; } } } var preloadFlag = false; function preloadImages() { if (document.images) { About_Us_over = newImage("images/About-Us-over.gif"); The_Crew_over = newImage("images/The-Crew-over.gif"); FAQ_over = newImage("images/FAQ-over.gif"); Downloads_over = newImage("images/Downloads-over.gif"); preloadFlag = true; } } // --> </SCRIPT> <!-- End Preload Script --> <csscriptdict import> <script type="text/javascript" src="GeneratedItems/CSScriptLib.js"></script> </csscriptdict> <csactiondict> <script type="text/javascript"><!-- var preloadFlag = true; // --></script> </csactiondict> </HEAD> <BODY BGCOLOR=#000000 LEFTMARGIN=0 TOPMARGIN=0 MARGINWIDTH=0 MARGINHEIGHT=0> <div align="center"><font color="#00CCFF" face="Verdana, Arial, Helvetica, sans-serif"></font> <TABLE WIDTH=750 BORDER=0 CELLPADDING=0 CELLSPACING=0> <TR> <TD COLSPAN=9><font face="Arial,Helvetica,Geneva,Swiss,SunSans-Regular"><IMG SRC="images/VB-header.gif" WIDTH=750 HEIGHT=120 ALT=""></font></TD> </TR> <TR> <TD><IMG SRC="images/Left-buttonline.gif" WIDTH=80 HEIGHT=36 ALT=""></TD> <TD><A HREF="aboutus.html" ONMOUSEOVER="changeImages('About_Us', 'images/About-Us-over.gif'); return true;" ONMOUSEOUT="changeImages('About_Us', 'images/About-Us.gif'); return true;"><IMG NAME="About_Us" SRC="images/About-Us.gif" WIDTH=131 HEIGHT=36 BORDER=0 ALT=""></A></TD> <TD><IMG SRC="images/Buttonline-A%26T.gif" WIDTH=21 HEIGHT=36 ALT=""></TD> <TD><A HREF="thecrew.html" ONMOUSEOVER="changeImages('The_Crew', 'images/The-Crew-over.gif'); return true;" ONMOUSEOUT="changeImages('The_Crew', 'images/The-Crew.gif'); return true;"><IMG NAME="The_Crew" SRC="images/The-Crew.gif" WIDTH=130 HEIGHT=36 BORDER=0 ALT=""></A></TD> <TD><IMG SRC="images/Buttonline-T%26F.gif" WIDTH=23 HEIGHT=36 ALT=""></TD> <TD><A HREF="faq.html" ONMOUSEOVER="changeImages('FAQ', 'images/FAQ-over.gif'); return true;" ONMOUSEOUT="changeImages('FAQ', 'images/FAQ.gif'); return true;"><IMG NAME="FAQ" SRC="images/FAQ.gif" WIDTH=131 HEIGHT=36 BORDER=0 ALT=""></A></TD> <TD><IMG SRC="images/Buttonline-F%26D.gif" WIDTH=21 HEIGHT=36 ALT=""></TD> <TD><A HREF="downloads.html" ONMOUSEOVER="changeImages('Downloads', 'images/Downloads-over.gif'); return true;" ONMOUSEOUT="changeImages('Downloads', 'images/Downloads.gif'); return true;"><IMG NAME="Downloads" SRC="images/Downloads.gif" WIDTH=132 HEIGHT=36 BORDER=0 ALT=""></A></TD> <TD><IMG SRC="images/Right-buttonline.gif" WIDTH=81 HEIGHT=36 ALT=""></TD> </TR> <TR background="images/Main.gif"> <TD height="494" COLSPAN=9> <div align="center"><font color="#0099FF" size="2" face="Arial, Helvetica, sans-serif">Hi, and welcome to VegiBoys.com!</font></div> </TD> </TR> </TABLE> </div> </BODY> </HTML> når jeg tar preview på dette i IE, så kommer ikke bakgrunnsbildet opp, men teksten står der! hva er det som er galt her mon tro? På forhånd takk! Lenke til kommentar
flodhest Skrevet 7. januar 2004 Del Skrevet 7. januar 2004 Mulig jeg kommer med et veldig dumt svar nå, men er du sikker på at du har lastet opp bildet? Og lagt det i riktig mappe? Har gjort den samme feilen selv nemlig. Lenke til kommentar
Jesper Karsrud Skrevet 7. januar 2004 Forfatter Del Skrevet 7. januar 2004 Dette er bare fedig generert kode fra DW... og ja, bildet ligger i samme mappe som alle de andre bildene,så jeg skjønner liksom ikke helt hva som er galt! og det er litt irriterende, fordi jeg skulle gjerne fått lagt den ut på nettet snart, slik at jeg kan vise dere den! Lenke til kommentar
haugsand Skrevet 7. januar 2004 Del Skrevet 7. januar 2004 Lager DW virkelig så inkompetent kode? Du kan prøve å sette inn bakgrunnsbilde ved hjelp av css istedet, søk på egenskapen "background" på w3c.org. Lenke til kommentar
Jesper Karsrud Skrevet 7. januar 2004 Forfatter Del Skrevet 7. januar 2004 nei... det kan være at den ser så rar ut fordi jeg hadde den innom GoLive også... men jeg tror kanskje jeg skal slette hele filen og legge den inn på nytt... kan jo være der problemet ligger?? jeg vet ikke... ser ut til at jeg blir nødt til å lære meg html på nytt, og css i tillegg gitt! Lenke til kommentar
Jesper Karsrud Skrevet 7. januar 2004 Forfatter Del Skrevet 7. januar 2004 Ingen som har noen ideer? har prøvd å bare kjøre siden i DW, men det hjalp heller ikke.... har gjort det likt som denne tutorialen, og der funker jo alt! Lenke til kommentar
Arve Systad Skrevet 7. januar 2004 Del Skrevet 7. januar 2004 Lager DW virkelig så inkompetent kode? Du kan prøve å sette inn bakgrunnsbilde ved hjelp av css istedet, søk på egenskapen "background" på w3c.org. nei, DW lager heilt fin kode heilt til du begynner å angi masse font properties, og legge inn store script osv osv.. Lenke til kommentar
kvikks Skrevet 7. januar 2004 Del Skrevet 7. januar 2004 Lager DW virkelig så inkompetent kode? Du kan prøve å sette inn bakgrunnsbilde ved hjelp av css istedet, søk på egenskapen "background" på w3c.org. nei, DW lager heilt fin kode heilt til du begynner å angi masse font properties, og legge inn store script osv osv.. Jeps, det stemmer koden er stort sett bra... Men NotePad må brukes for finpuss. Uansett: Lær deg CSS og XHTML da slipper du dette, da angir du alt i CSS... Bakgrunner, fonter etc.. Genialt med CSS på tagger. Lenke til kommentar
