siDDis Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Eg leste nettopp at det fantes FM kort som gjør at du kan sende radio signaler frå pcen din. Dei har ca 500-1000m range. Problemet er, kor kan eg få tak i sånt? Lenke til kommentar
supersnus Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 har du en link til hvor du leste det.(inntresert) Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 amd henri richard interview FiringSquad: Earlier you said that you actually build your own gaming rigs. Can you tell us a little about your PC/building experience, and your current gaming system? Henri Richard: Sure. Yeah so I always build my own systems I like to plan my builds, I like to select components. I typically, you know I?m blessed with many connections within the industry so I work with partners, that, you know, if they need beta testers?[i?m there] But my configuration today is, well I have two configurations. I have a water cooled Athlon XP 3200+. I?m using the Koolance water-cooling system. On that system I?ve got an NVIDIA GeForce FX 5900 and 2GB of memory and there?s two 250GB Maxtor Serial ATA hard drives. So that?s my XP 3200 and I just finished putting together an Athlon 64 FX 51 that?s in a Thermaltake box. It?s not water-cooled but it?s a very cool box, with seven thermostatically controlled fans, very low RPM fans. In that one I?ve got an NVIDIA 5950, the latest one, and also dual 250GB Maxtor drives and 4GB of memory and I just purchased the latest Sound Blaster ZS, the Audigy 2 ZS. I have to confess that I haven?t been fortunate to, well I?ve been on the road for two weeks so I haven?t had the chance to actually setup the system and install the software that I want on it yet. But I like to test. I like, well my systems are constantly in a state of evolution. I have seven different platforms at home that I keep rotating. I also have a home server that I run 24/7 that I use as a gaming server. I also fitted it with an FM radio emitter. That?s my own private radio station without any advertisements on it that?s basically using Winamp and scanning a database of MP3 files that I made out of my CD collection of over 12,000 titles. FiringSquad: Wow that?s pretty impressive Henri Richard: Yeah, it?s great. I?m surprised, you know that FM card is like $150 bucks and I?m surprised that there aren?t more people that use that because every time I talk to friends or people in the industry about it they think it?s a cool idea because a lot of people don?t want advertisements when you listen to the radio and it?s [inaudible] and it?s doing 50 milliwatts. You know it gives me basically, the range is about half a mile from my house and it gets great reception, it?s really cool. I expect that one of these days it will be a standard feature in multimedia PCs. Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 var litt usikker på dei, stod lite om rekkevidde Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 http://www.pcs-electronics.com/en/products...trans#Pci%20max Trenger eg å sei meir =) Sånn skal bestillas Lenke til kommentar
snole Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 (endret) Det PCI MAX kortet så lovende ut. Med en 5 eller 10 Watts booster kan du nok sende LANGT. Må nok nevne at et slikt kort er forbudt i Norge. Du må søke om sendekonsesjon (og det vil du aldri få) for å sende Radio/TV signaler i lufta. Endret 6. januar 2004 av snole Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 hæ? er sånt forbudt?!??! går ikkje ann å bli meir forbudt her enn i usa Lenke til kommentar
snole Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Joda, det er forbudt. Og skal du sende musikk, skal du egentlig betale Tono pr sang du sender. Slik at artisten tjener på at sangen blir "offentliggjort". Lenke til kommentar
snole Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Se her. Andre enn Norsk rikskringkasting må ha konsesjon for å drive kringkasting eller lokalkringkasting som formidles via senderanlegg som er konsesjonspliktige etter § 2-2. Utsending av enkle meldinger krever ikke konsesjon. § 2-2. Anlegg for kringkasting og videresending av kringkasting Opprettelse eller drift av trådløse, bakkebaserte senderanlegg som hovedsakelig vil bli benyttet til kringkasting eller nærkringkasting eller videresending av kringkasting eller nærkringkasting krever konsesjon fra departementet eller den departementet bestemmer. Konsesjon gis i forbindelse med tildeling av frekvenskapasitet i medhold av lov 23. juni 1995 nr. 39 om telekommunikasjon (teleloven). Pluss en hel del mere svada, for de som gidder å lese. Poenget er at det er forbudt å ha sin egen FM-sender, med mindre du har søkt om, og fått konsesjon. Problemet er at kravene til utstyret er så strenge at det skal MYE til for å få den konsesjonen. Radioutstyr er slik at hvis du sender en frekvens, så oppstår det en speilfrekvens på 1/2 av og 2x den frekvensen du sender på. Og på hver speilfrekvens blir det nye speilfrekvenser osv osv. Kravene er at utstyret skal være så bra at du eliminerer disse speilfrekvensene, slik at du ikke forstyrrer andre stasjoner og annen radiotrafikk. Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 jaja, eg gir meg ikkje så lett. Staten burde ijallefall tilatt at nokre frekvenser blei brukt av alle heilt fritt. Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 korleis kan eg forstyrre andre radiostajoner når rekkevidden når så vidt bilen i garasjen? altså 30-50 meter? Lenke til kommentar
snole Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 jaja, eg gir meg ikkje så lett. Staten burde ijallefall tilatt at nokre frekvenser blei brukt av alle heilt fritt. Det gjør de jo, på en måte. Men ikke i FM båndet beregnet for kringkastning. Det er frekvensbånd som benyttes av babysittere, trådløse tlf'er og trådløse datanettverk. Men utstyret som skal benyttes på de frekvensområdene i Norge skal være godkjent for bruk i Norge. (For å forsikre seg om at en billig trådløs telefon lagd/kjøpt i ytre Mongolia, ikke slår ut sambandet til sykebiler f.eks). Lenke til kommentar
snole Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 korleis kan eg forstyrre andre radiostajoner når rekkevidden når så vidt bilen i garasjen? altså 30-50 meter? Hvis det er snakk om ekstremt kort rekkevidde, så er vel reglene litt annerledes. Jobbet i radio/tv-verksted før, og de fleste verksted er utstyrt med FM-modulator for å kunne teste radioer og slikt. Men de har max 30-50 meter rekkevidde, og var ikke konsesjonspliktig. Det artige med de var at man kunne slenge en ekstra forsterker på utgangen av de, og sende radio en del lengre. Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 Greit =) Men å sende i AM nettet(krever visstnok anna utsyr enn det eg fant) Er det regler for det? Finnes det andre nett? Kor lang ca er maks rekkevidde for konsensjon krav? Lenke til kommentar
Flames Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Hvor får man tak i slike "boostere", slik at man kan sende litt lengre enn vanlig? Lenke til kommentar
Flames Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Den "PCI MAX ULTRA" var jo veldig dyr forresten.. Og skal man ha en booster på 5w så koster det deg ytterlige 300$. Blir ikke slikt solgt i Norge ? Lenke til kommentar
siDDis Skrevet 6. januar 2004 Forfatter Del Skrevet 6. januar 2004 trur den ikkje er så dyr når ein prioriterer lydkvalitet Lenke til kommentar
Flames Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Vel.. 300.00 USD = 2,011.64 NOK, og det virker litt dyrt for meg da.. Lenke til kommentar
snole Skrevet 6. januar 2004 Del Skrevet 6. januar 2004 Ville sendt en mail til noen som kan svare deg på det gitt. Hvis du bare ønsker å kunne sende FM innen huset ditt/eiendommen din, for å kunne høre musikk fra PC'en p åsoverommet eller i garasjen, så forklarer du det slik. Da får du et svar som sikkert er mere forklarende enn mitt. Lenke til kommentar
