Sitat
Daylight revealed “little and beautiful” eruption
“We can see the fissures that opened yesterday and then the lava flows running out. We flew over in the dark last night, but when people see it with the mountains and valley for comparison, then it is somewhat smaller than expected when flown over yesterday,” says Björn Oddsson, geophysicist with the civil protection department. He was among the people who flew over the eruption this morning.
The force of the lava flow has reduced and the reported hundred-metre-tall fountains of lava at the beginning of the eruption are no longer visible. There is little or no ash production, and minimal gas emissions. The eruption is “little and beautiful,” according to the civil protection department.
"This is very well contained in this valley where the fissure has opened and should not cause further danger, if that does not change,” says Björn. “It can’t change much unless the lava flow increases a lot, but if it does gather some more force, it will still be in this very small valley it is in and it will more likely get thicker than spread over a wider area.”
Björn says it cannot be ruled out that another fissure opens in a different location, so scientists are still monitoring the Reykjanes peninsula very closely.
It is still not clear how long the eruption will last, but a decision was already taken this morning to lower the civil protection alert level from emergency down to danger.
“It is on the scale of one to two kilometres, not much longer than that, the lava flows and fissure. It is that small and is much smaller than the beginning of the Fimmvörðuháls eruption was in its day,” Björn says.
He says it is impossible to say if the eruption will last a few more hours, days or weeks. It is not stopping at this time, however, and appears fairly stable.
Civil protection police chief Víðir Reynisson told RÚV TV this lunchtime that the roads closest to the eruption are closed but that the Reykjanes peninsula is not closed generally—though he advises people to stay away from the volcano because the ground is slippery, there is rain and fog in the area, and the most dangerous thing, the potentially poisonous gas, is invisible.
https://www.ruv.is/frett/2021/03/20/daylight-revealed-little-and-beautiful-eruption
Simen1 skrev (5 minutter siden):
Jeg sitter og ser på live kameraet fra RUV via NRK. Det virker ikke som det er geologer/forskere, men skuelystne som går for nært. RUV fraråder folk å gå nært.
Sitat
Pop og se utbruddet hjemme Víðir Reynisson, politimester, advarte om turer til utbruddsstedene på grunn av været, lange turer, vanskelige forhold og risikoen for gassforurensning. "Jeg oppfordrer folk til å komme inn og se det hjemme." Hvis folk derimot går, må det være godt utstyrt, og det anbefales at folk går fra vest, med vinden bak seg. Meteorolog Elín Björk Jónasdóttir påpekte at været blir verre og folk vil trolig ha femten meter per sekund i armene på vei tilbake. Magnús Tumi Guðmundsson, geofysiker, påpekte at utbruddet er i en depresjon og gass kan akkumuleres der. "I en lukket depresjon, hvis det er rolig, er det bare en dødsfelle." Lav risiko for gassforurensning i bebygde områder Meteorolog Elín Björk Jónasdóttir sa på et sivilforsvarsinformasjonsmøte at rundt 30 kilo gass trolig vil komme ut med utbruddet per sekund, ikke 160 kilo som man først trodde. Det er lite sannsynlig at gassforurensning utgjør en fare for bosetninger, i det minste de neste dagene. Folk som er veldig sårbare for luftforurensning, må kanskje være forsiktige. Været vender seg mot sørvestlig kjedelig vær på utbruddsstedene. Elín Björk sa at hun ikke anbefalte folk å jobbe seks til syv timer for å komme til utbruddsstedene. Både på grunn av været og mørket etter hvert, men også på grunn av risikoen for gassforurensning nær utbruddsstedene. Derfor vil det ikke være tilrådelig å være der uten gassmåler.
https://www.ruv.is/frett/2021/03/18/helstu-tidindi-eldgos-hafid-i-fagradalsfjalli
Pc Lynet skrev (44 minutter siden):
Er veiene i området stengt? Det er visst bare 3,2 km i luftlinje fra nærmeste vei (vei 427) så det burde være mulig å gå på en halvtimes tid selv om det er litt steinete. Det er fra sør-vest.
Simen1 skrev (19 timer siden):
De er nok sperret av siden folk flest går 6 timer fra den blå lagune.
Sitat
Mange mennesker på farten på utbruddsstedene Seksti biler er parkert på Grindavíkurvegur vest for avkjøringen til Den blå lagune. De fleste er sannsynligvis på vei til Geldingadalur, men de som skal til utbruddsstedene oppfordres til å forberede seg godt og være forsiktige.
Mange som våger seg litt vel nært synes jeg.
Sitat
Politimesteren på Suðurnes har bestemt seg for å stenge et lite område ved siden av utbruddssprøyten i Geldingadalur. Denne avgjørelsen er basert på en resolusjon fra Scientific Council, som gjorde oppmerksom på at det store krateret kunne gå i stykker og lavastrømmen raskt kunne endre retning. Det er også en risiko for at et nytt utbruddssprekk åpner seg nær krateret, noe som skjedde i utbruddet på Fimmvörðuháls i 2010. Det lukkede området er merket med rødt på det vedlagte bildet. Videre blir oppmerksomhet rettet mot andre farer som kan oppstå rundt utbruddsstedene: Nye sprekker kan åpne seg i umiddelbar nærhet av vulkanene uten varsel. Glødende lava kan falle fra lavakanten og det oppstår et raskt og plutselig utbrudd der nye lavatunger bryter ut av lavakanten i høye hastigheter som er vanskelige å unngå på løp. Kratere er nå blitt mange meter høye og kan være ustabile, de kan gå i stykker og en stor og plutselig lavastrøm fra dem tar en ny retning. Eksplosjoner kan oppstå der lava strømmer over vannlagt jord og blåser lava i alle retninger. Lava strømmer inn i en lukket fordypning og livstruende gasser kan akkumuleres i fordypninger som kan være dødelige. Risikoen øker når vinden avtar. I tillegg forutsier Meteorologisk kontor dårlig vær det neste døgnet, og turister må være veldig godt rustet hvis de skal gå opp til utbruddsstedene. Været forverres betraktelig om natten med sterk vind, sludd eller snø. Politimesteren på Suðurnes Úlfar Lúðvíksson
