Jeg har såvidt begynt på assembly og lager noen svært enkle programmer nå i begynnelsen.
Jeg tenkte jeg skulle prøve å la en asm fil hente prosedyrene sine i en annen asm fil, men får ikke dette til å funke. Begge filene assembles helt fint, men når jeg skal linke dem går det galt og jeg får denne feilmeldingen:
Microsoft (R) Incremental Linker Version 5.12.8087
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
LINK: error : Segment reference in fixup record
eat.obj : fatal error LNK1123: failure during conversion to COFF: file invalid or corrupt
De to *.asm filene mine ser slik ut, eat.asm skal hente noen prosedyrer fra vidlib.asm, og vidlib.asm får noen verdier fra eat.asm, dette er skrevet for en 8086 CPU:
Eat.asm:
MyStack SEGMENT STACK
DB 512 DUP (?)
MyStack ENDS
MyData SEGMENT PUBLIC
PUBLIC CRLF,LRXY
Eat1 DB "Eat at Joe's...",'$'
Eat2 DB "...some other string",'$'
CRLF DB 0AH,0DH,'$'
LRXY DW 184FH    ;18H = 24D; 4FH = 79D
TextPos DW ?
MyData ENDS
MyCode SEGMENT PUBLIC
EXTRN GotoXY:PROC,Write:PROC,Writeln:PROC,ClrScr:PROC
assume CS:MyCode,DS:MyData
Start:
Main PROC
mov AX,MyData
mov DS,AX
call ClrScr
mov TextPos,0914H;0914H = X @ 20, Y @ 9
mov DX,TextPos
call GotoXY
lea DX,Eat1
call write
mov DX,Textpos
mov DH,10
call GotoXY
lea DX,Eat2
call writeln
mov AH,4CH
mov AL,0
int 21H
Main ENDP
MyCode ENDS
END Start
Vidlib.asm:
EXTRN CRLF:BYTE,LRXY:WORD
MyData ENDS
PUBLIC Write,Writeln,GotoXY,ClrScr
;GOTOXY  --  Positions the hardware cursor to X,Y
;  1 Entry point:
;  GotoXY:
;   caller must pass:
;   DL: X value   These are both 0-based; i.e., they
;   DH: Y value   assume a screen 24x79 not 25x80
;   Action: Moves the hardware cursor to the X,Y position
;      loaded into DL and DH
GotoXY PROC
mov AH,02H ;Select VIDEO service 2: Position cursor
mov BH,0   ;Stay with display page 0
int 10H    ;Call VIDEO
ret
GotoXY ENDP
;Write: Displays information on the screen via DOS service
;   9H: Print string
Write PROC
mov AH,09H ;select DOS service 9: Print string
int 21H    ;call DOS
ret
Write ENDP
;Writeln: Displays information on the screen via DOS service
;     9H: Print string and issues a newline
Writeln PROC
call Write
lea DX,CRLF;load address of newline into DS:DX
call write
ret
Writeln ENDP
;ClrScr: Clears the entire screen to blanks with 07H as the
;    display attribute
ClrScr PROC
mov CX,0   ;Upper-left corner of full screen
mov DX,LRXY;load lower-right XY coordinates into DX
mov AL,0   ;0 specifies clear entire region
mov BH,07H ;Secify "normal" attribute for blanked line(s)
mov AH,06H ;Select VIDEO service 6: initialize/scroll
int 10H    ;call VIDEO
ret
ClrScr ENDP
MyCode ENDS
END
Når jeg skal linke de to *.obj filene bruker jeg kommandoen "link eat.obj vidlib.obj", er det her feilen ligger og ikke i kildekoden?
