Feil ved posting i forum programmer.no
Jeg får ikke postet, følgende feilmelding kommer opp:
Warning: Can't create a new thread (errno 11). If you are not out of available memory, you can consult the manual for a possible OS-dependent bug in /home/forum_new/sources/Drivers/mySQL.php on line 65
Warning: MySQL Connection Failed: Can't create a new thread (errno 11). If you are not out of available memory, you can consult the manual for a possible OS-dependent bug in /home/forum_new/sources/Drivers/mySQL.php on line 65
Warning: Supplied argument is not a valid MySQL-Link resource in /home/forum_new/sources/Drivers/mySQL.php on line 68
ERROR: Cannot find database invision
Warning: Supplied argument is not a valid MySQL-Link resource in /home/forum_new/sources/Drivers/mySQL.php on line 101
There appears to be an error with the Forum database.
You can try to refresh the page by clicking here, if this does not fix the error, you can contact the board administrator by clicking here
Error Returned
mySQL query error: SELECT id, member_id, running_time, location FROM ippbe_sessions WHERE id='4132734f599460f5cfb077138b008d50' and ip_address='62.179.100.98'
mySQL error: Can't create a new thread (errno 11). If you are not out of available memory, you can consult the manual for a possible OS-dependent bug
mySQL error code:
Date: Sunday 04th of January 2004 09:46:03 PM
We apologise for any inconvenience
