BadCat Skrevet 29. april 2021 Del Skrevet 29. april 2021 (endret) 50 MH/s på 3060 Ti, hvor tar du det fra? De fleste greier 63+ Det er 26% fra virkeligheten. Da kan man like gjerne påstå at en hundrekroneseddel er verdt 79,36 kroner selv om alle vet at den er verdt 100. Det er like nært virkeligheten. Endret 29. april 2021 av BadCat Lenke til kommentar
isa Skrevet 29. april 2021 Del Skrevet 29. april 2021 (endret) Quote To all Ethereum miners: plan conservatively for an end to mining EOY 2021. Please help us relay this info: @etherchain_org @sparkpool_eth @f2pool_official @SpiderPool_com @hiveonofficial @nanopool_org @BitsBeTrippin @pool2miners @MiningPoolHub cc. @TimBeiko, ETH R&D Discord https://mobile.twitter.com/trent_vanepps/status/1387837123756240898 Endret 29. april 2021 av isa Lenke til kommentar
isa Skrevet 29. april 2021 Del Skrevet 29. april 2021 "The merge is basically the #1 priority for everyone after the forks that are in progress (Altair and London). I think 6 months from now is a pretty optimistic timeline, 6 months after London/Altair (which are due in ~July) seems possible, but I definitely would not make that a "final timeline": we barely have those for the current forks that are being planned. We mentioned a few times that the merge could happen sooner if there was a strong push (e.g. a miner attack) and I still think that's true, but we're just not in a spot where we need to drop absolutely everything and ship it now." Samme karen noen minutter før Lenke til kommentar
isa Skrevet 29. april 2021 Del Skrevet 29. april 2021 (endret) Quote "No. Ideally this year but absolutely no commitments on timing and unlikely to be ready by October." "We've been over this so many times I'm not sure how to say it anymore. There is no one who can be a "credible source". No one has definitive control over Ethereum like that. I think there is still a greater than 50% probability of the merge in 2021, if anything it's looks more likely than it was previously. You will never get a firm commitment of when things are due in Ethereum, that's just not how decentralised governance works." - Adrian Sutton Endret 29. april 2021 av isa Lenke til kommentar
kremt Skrevet 29. april 2021 Del Skrevet 29. april 2021 Sliter med post når jeg går fra 3 til 4 kort, hk sier det er feil med cmos eller usb device. Kan det være doa riser? Lenke til kommentar
N o r e n g Skrevet 29. april 2021 Del Skrevet 29. april 2021 BadCat skrev (43 minutter siden): 50 MH/s på 3060 Ti, hvor tar du det fra? De fleste greier 63+ Det er 26% fra virkeligheten. Da kan man like gjerne påstå at en hundrekroneseddel er verdt 79,36 kroner selv om alle vet at den er verdt 100. Det er like nært virkeligheten. Poenget gikk deg imidlertid hus forbi skjønner jeg... Lenke til kommentar
major_stuen Skrevet 30. april 2021 Del Skrevet 30. april 2021 mozaix skrev (13 timer siden): Jeg brukte "Thermal Grizzly Minus 8". Temperaturen lå på ~92C til å begynne med, da med +875 på memory og powerlimit låst på 700mV. Fikk da ca 96,5MH/s. Ca tre uker senere var temp på ~100C igjen. Jeg har deretter redusert oc på minnet til +255, og nå vaker memory junction rundt 96-98C hvor det ligger i dag. Frister egentlig ikke å ta fra hverandre kortet for å se hvor svette thermal padsene er, men jeg må vel gjøre det snart hvis dette fortsetter ... Edit: Kan legge til at jeg kjører fan på 68% Merkelig at temp skal stige såpass på tre uker etter bytte.. Vifta ligger på 65% her og 65% power, men skal sies at jeg liker å ha litt hyggelig temperatur på stua også. Lukket kabinett med to 140mm @ ~800rpm inn og en 140mm @~1000rpm ut når jeg miner, men kanskje ikke helt optimalt det heller. Trodde jeg skulle klare å pushe kortet litt mer.. Uansett så er kortet kjøpt mest for spilling, klarer jeg å tjene det inn igjen så er jeg vel fornøyd. Men skal undersøke litt mer rundt bytte. Takk for tips om pads Lenke til kommentar
N o r e n g Skrevet 30. april 2021 Del Skrevet 30. april 2021 Nå som Nvidia skal komme med oppdaterte GPUer som har lavere hashrate bakt inn i BIOS/firmware, tror dere at det kommer en hack som klarer å "fikse" dette? Det hadde jo i så fall vært interessant, siden Nvidia har gimpet Geforce-kort i over 10 år uten at noen har klart å låse opp funksjonene til Quadro-kort. Lenke til kommentar
idleman_2 Skrevet 30. april 2021 Del Skrevet 30. april 2021 7 minutes ago, N o r e n g said: Nå som Nvidia skal komme med oppdaterte GPUer som har lavere hashrate bakt inn i BIOS/firmware, tror dere at det kommer en hack som klarer å "fikse" dette? Det hadde jo i så fall vært interessant, siden Nvidia har gimpet Geforce-kort i over 10 år uten at noen har klart å låse opp funksjonene til Quadro-kort. Har vel ikke vært etterspurt... Annet enn unlimited streams (bare begrenset av størrelse på minnet) Lenke til kommentar
Claus3000 Skrevet 30. april 2021 Del Skrevet 30. april 2021 N o r e n g skrev (5 minutter siden): Nå som Nvidia skal komme med oppdaterte GPUer som har lavere hashrate bakt inn i BIOS/firmware, tror dere at det kommer en hack som klarer å "fikse" dette? Det hadde jo i så fall vært interessant, siden Nvidia har gimpet Geforce-kort i over 10 år uten at noen har klart å låse opp funksjonene til Quadro-kort. De fleste minere tror at det er fort gjort å omgå denne sperren. Jeg tviler litt på at det er så lett som enkelte tror. Bla. pga Quadro som du nevner. De har nok gjort seg mange erfaringer med 3060-sperren som nok bare var et halvhjertet forsøk også. Blir interessant å følge utviklingen 🙂 Lenke til kommentar
MTH Skrevet 30. april 2021 Del Skrevet 30. april 2021 Claus3000 skrev (6 minutter siden): De fleste minere tror at det er fort gjort å omgå denne sperren. Jeg tviler litt på at det er så lett som enkelte tror. Bla. pga Quadro som du nevner. De har nok gjort seg mange erfaringer med 3060-sperren som nok bare var et halvhjertet forsøk også. Blir interessant å følge utviklingen 🙂 Dette er første gang jeg vet om at det faktisk har eksistert en hensikt bak å knekke firmwaren i en serie GeForce-kort, så det kan bli spennende å se hvor lenge det holder. Tradisjonelt sett har bedrifter hatt råd til Quadro-kort om man faktisk trenger dem, så jeg tror det er en mulighet for at det bare ikke har vært noe god årsak til å legge innsats inn i dette før. En del av bruksområdene til et Quadro-kort strekker seg forbi hva som kan gjøre med kun en firmware-hack, men her kan jeg absolutt ta feil. En ting jeg er rimelig sikker på er at det vil ta tid, så smarte minere innser nok at EIP-1559 sannsynligvis kommer lenge før man finner en firmware hack. Det er tross alt sannsynligvis snakk om en driver-firmware-hardware handshake med flere sikkerhetslag, så om minere ikke klarer å gå rundt gjenkjenningsalgoritmen har nok NVIDIA vunnet. Lenke til kommentar
N o r e n g Skrevet 30. april 2021 Del Skrevet 30. april 2021 idleman_2 skrev (26 minutter siden): Har vel ikke vært etterspurt... Annet enn unlimited streams (bare begrenset av størrelse på minnet) Ja, ikke sant, det har jo ikke vært etterspurt i 5 år. Eller vent nå litt... https://www.overclock.net/threads/pascal-bios-editor-any-news.1621789/page-16 Programmet som "fikser" bærbare skjermkort virker ikke som det fungerer heller. Folk ender opp med å shunt-modde i stedet. Lenke til kommentar
Mumriken Skrevet 30. april 2021 Del Skrevet 30. april 2021 56 minutes ago, idleman_2 said: Har vel ikke vært etterspurt... Annet enn unlimited streams (bare begrenset av størrelse på minnet) Kjører denne på plex serveren min https://github.com/keylase/nvidia-patch Lenke til kommentar
Cardinal Skrevet 30. april 2021 Del Skrevet 30. april 2021 Noen som har prøvd Gigabyte 3070 av nyere produksjon? Har Gigbyte fremdeles problem med varme under mining? Lenke til kommentar
QUiPS Skrevet 30. april 2021 Del Skrevet 30. april 2021 (endret) 12 minutes ago, Cardinal said: Noen som har prøvd Gigabyte 3070 av nyere produksjon? Har Gigbyte fremdeles problem med varme under mining? Gigabyte 3070 Gaming OC funker bra under mining, Gigabyte 3080 throttler som fy uten modifikasjoner (kjøleribber, ekstra vifter...o.l Her er tuf oc vs gaming oc: Endret 30. april 2021 av QUiPS Lenke til kommentar
Claus3000 Skrevet 30. april 2021 Del Skrevet 30. april 2021 Cardinal skrev (22 minutter siden): Noen som har prøvd Gigabyte 3070 av nyere produksjon? Har Gigbyte fremdeles problem med varme under mining? Har flere Gigabyte 3070 og 3060ti. Alle fungerer fint. Kjøper kun modeller med 3 vifter da. Lenke til kommentar
Cardinal Skrevet 30. april 2021 Del Skrevet 30. april 2021 takker, apropos 3080. Har ett Evga FTW ultra i gaming pcen. Har kjørt på CoreCl -150, mem +1000/1200 (har kjørt på 1200 men satt ned da jeg ble litt usiker de siste dagene), fan 80 og 227W. GPU temp 47-49 og Junction 96-100 I dag tidlig når jeg stod opp så jeg den var noe rar. GPU temp mener jeg var 55-65 grader, power ca 330W og så i hwinfo under performance limit : Throttle var no, men reliability voltage og max operating voltage stod som Yes Noen som har noen formening om hva som har skjedd eller hva feilen var? Bare høy temp? Lenke til kommentar
Claus3000 Skrevet 30. april 2021 Del Skrevet 30. april 2021 Cardinal skrev (9 minutter siden): takker, apropos 3080. Har ett Evga FTW ultra i gaming pcen. Har kjørt på CoreCl -150, mem +1000/1200 (har kjørt på 1200 men satt ned da jeg ble litt usiker de siste dagene), fan 80 og 227W. GPU temp 47-49 og Junction 96-100 I dag tidlig når jeg stod opp så jeg den var noe rar. GPU temp mener jeg var 55-65 grader, power ca 330W og så i hwinfo under performance limit : Throttle var no, men reliability voltage og max operating voltage stod som Yes Noen som har noen formening om hva som har skjedd eller hva feilen var? Bare høy temp? Overklokking som har resatt seg kanskje? Hvis kortet trakk 330W tenker jeg Lenke til kommentar
Cardinal Skrevet 30. april 2021 Del Skrevet 30. april 2021 hmm tror nesten ikke det. Jeg lukket Trex og valgte profil 2 som default settings i afterburner og da roet alt seg ned. men mulig dog skal jeg fortsette med den er det vel ett spørsmål om tid før jeg må finne noen nye pads til det Lenke til kommentar
Cardinal Skrevet 30. april 2021 Del Skrevet 30. april 2021 Sikkert noen som vil teste? Lenke til kommentar
