Kryptovaluta mining med skjermkort diskusjonstråd.
kremt skrev (Akkurat nå):
Minerstat sier null i profitt, hvordan regner du?
Pc Lynet skrev (4 timer siden):
Da regner du feil. Se her for en 3070
https://whattomine.com/coins?aq_380=0&aq_fury=0&aq_470=0&aq_480=3&aq_570=0&aq_580=0&aq_vega56=0&aq_vega64=0&aq_5600xt=0&aq_5700=0&aq_5700xt=0&aq_vii=0&aq_68=0&aq_68xt=0&aq_1050Ti=0&aq_10606=0&aq_1070=0&aq_1070Ti=0&aq_1080=0&aq_1080Ti=0&aq_1660=0&aq_1660Ti=0&aq_166s=0&aq_2060=0&aq_2070=0&aq_2080=0&aq_2080Ti=0&aq_3060Ti=0&aq_3070=1&a_3070=true&aq_3080=0&aq_3090=0&eth=true&factor[eth_hr]=58.10&factor[eth_p]=130.00&e4g=true&factor[e4g_hr]=58.10&factor[e4g_p]=130.00&zh=true&factor[zh_hr]=100.00&factor[zh_p]=180.00&cnh=true&factor[cnh_hr]=1750.00&factor[cnh_p]=180.00&cng=true&factor[cng_hr]=2900.00&factor[cng_p]=180.00&cnr=true&factor[cnr_hr]=0.00&factor[cnr_p]=0.00&cnf=true&factor[cnf_hr]=3400.00&factor[cnf_p]=170.00&eqa=true&factor[eqa_hr]=390.00&factor[eqa_p]=180.00&cc=true&factor[cc_hr]=10.20&factor[cc_p]=180.00&cr29=true&factor[cr29_hr]=10.30&factor[cr29_p]=180.00&cz29=true&factor[cz29_hr]=5.80&factor[cz29_p]=180.00&ct31=true&factor[ct31_hr]=0.00&factor[ct31_p]=0.00&ct32=true&factor[ct32_hr]=0.50&factor[ct32_p]=180.00&eqb=true&factor[eqb_hr]=34.00&factor[eqb_p]=180.00&rmx=true&factor[rmx_hr]=1030.00&factor[rmx_p]=160.00&ns=true&factor[ns_hr]=0.00&factor[ns_p]=0.00&ops=true&factor[ops_hr]=52.70&factor[ops_p]=180.00&eqz=true&factor[eqz_hr]=55.00&factor[eqz_p]=180.00&zlh=true&factor[zlh_hr]=57.00&factor[zlh_p]=180.00&kpw=true&factor[kpw_hr]=27.60&factor[kpw_p]=180.00&ppw=true&factor[ppw_hr]=27.40&factor[ppw_p]=180.00&x25x=true&factor[x25x_hr]=8.00&factor[x25x_p]=180.00&mtp=true&factor[mtp_hr]=4.00&factor[mtp_p]=180.00&vh=true&factor[vh_hr]=1.19&factor[vh_p]=140.00&factor[cost]=0.1&sort=Profitability24&volume=0&revenue=24h&factor[exchanges][]=&factor[exchanges][]=binance&factor[exchanges][]=bitfinex&factor[exchanges][]=bitforex&factor[exchanges][]=bittrex&factor[exchanges][]=dove&factor[exchanges][]=exmo&factor[exchanges][]=gate&factor[exchanges][]=graviex&factor[exchanges][]=hitbtc&factor[exchanges][]=hotbit&factor[exchanges][]=ogre&factor[exchanges][]=poloniex&factor[exchanges][]=stex&dataset=Main&commit=Calculate
Pc Lynet skrev (6 minutter siden):
For gods sake 😜
For 3070 har jeg justert ethash hashrate fra 58 til 62 og ellers beholdt det som ligger i kalkulatoren. Ikke sjekket om det stemmer helt for Octopus.
5,62/4,35 = 1,29 => 29% bedre per nå for ETH enn CFX
Endret av KjellV
7 hours ago, idleman_2 said:
De som har bytta thermopads på sine skjermkort, tåler disse varmen bedre enn pads som er montert fra fabrikk ?
Hva er konduktiviteten på pads montert fra fabrikk ?
Ser ut som at hvis en har tuna kortene til en begynner å få invalid shares, så virker det nesten som at thermopads på minnet blir 'kokt' og får dårligere kjøleegenskaper etter tune processen..  stemmer mine antakelser/observasjoner på mine skjermkort ?
Ser nesten ut som at jeg må bytte thermopads på mine skjermkort før eller siden
Bumper denne!
Ingen som kan svare ? 😛
idleman_2 skrev (1 minutt siden):
Bumper denne!
Dårlige thermal pads tørker ut og blir dårligere med tiden. Lar du kortene stå avslått en times tid mellom forsøkene? Hvis ikke vil minne være varmt fra før. Det er begrenset hvor mange Mhz du kan klokke minnet uten feil.
idleman_2 skrev (3 minutter siden):
Bumper denne!
Har ikke byttet thermal pads på mine kort, men det finnes helt klart bedre pads enn de som følger med fra fabrikken. Noen produsenter har litt høyere kvalitet enn andre, men å bytte med nye vil være bedre for mining.
Produsentene forventer ikke at kortene skal kjøres 24/7 på 100%.
kjørte et av korta på 3000 på hiveos  stabil i flere dager uten invalid shares...  fin tunet kort til det kom invalid shares.. men nå klarer dette kortet bare 2575.... klarer ikke lenger 3000   så da må det jo skje en endring på thermopad mens en tester hvor langt det kan gå ?
Du har vel slitt ut minnet. Det er ikke bra med for høy overklokk over lengre tid.
