Si hei til potensiell des. 2020 lansering av Asus ROG Rapture GT-AXE11000
G
Quote
The new Asus ROG Rapture GT-AXE11000 supports Wi-Fi 6E, and features an eye-catching, gamer-friendly design with colored accent lights.
Pricing details are still yet to be determined, but given that the previous Wi-Fi 6 model is still selling for $450, you shouldn't expect the GT-AXE11000 to come cheap once it arrives.
The big benefit of support for Wi-Fi 6E is that it allows devices to access a massive swath of relatively untapped bandwidth in the 6GHz band. With 1,200MHz, it's more than twice as wide as the 5GHz band, which allows for a greater number of wider channels that can pass traffic faster and more efficiently. And, since there aren't any legacy Wi-Fi devices in that band, it'll serve as a semi-exclusive VIP section for the newest Wi-Fi gadgets equipped to take advantage. That means less interference and improved latency.
"AR/VR and gaming is another great use case for the 6GHz band," Correll told CNET. "Many don't realize the high-end VR sets that require the most bandwidth are actually tethered with cables. With Wi-Fi 6E, you not only get more bandwidth but cleaner bandwidth -- meaning it is able to wirelessly provide the higher data rates required along with true mobility."
Beyond the Wi-Fi 6E support, the GT-AXE11000 is powered by a 1.8GHz, 64-bit CPU with 1GB of RAM. It supports 4X4 Wi-Fi 6 connections, features a multi-gig LAN port for wired speeds of up to 2.5Gbps, and allows for WAN aggregation, where you combine the incoming speeds from two Ethernet WAN ports to achieve wireless speeds of up to 2Gbps. The router also uses "the latest 6GHz power amplifier" to improve signal strength and coverage -- a noteworthy inclusion, since signals won't travel quite as far in the 6GHz band.
https://www.cnet.com/news/asus-just-unveiled-the-first-router-that-supports-next-gen-wi-fi-6e-connections-rog-rapture-gt-axe11000/
1 Gig RAM litt lite på et så påkostet produkt??
Quote
In previous Wi-Fi standards, endpoints decided which Wi-Fi channel(s) to use. But, no more. Because the wireless access point should have the best view of local Wi-Fi airwave usage, the current Wi-Fi 6E host (WAP or router) decides which channel(s) the endpoint device will use.
https://dongknows.com/wi-fi-6e-explained/
Framtidsvyer:
Quote
Expanded 6 GHz frequency coverage including spectrum up to 7125 MHz expected to become available under new regulatory rules
BCM6755
 Dual 2x2 Wi-Fi 6 Quad-Core ARM SoC
https://www.broadcom.com/products/wireless/wireless-lan-infrastructure/bcm6755
Fra SNBForums
https://www.snbforums.com/threads/rog-rapture-gt-axe11000.66373/
Endret av G
3 hours ago, NULL said:
Wifi 6E er foreløpig ikke åpnet opp for i EU/CEPT. Forslaget innenfor EU/CEPT er også en begrenset del av 6 GHz-båndet. Mistenker at man tidligst ser WiFi 6E innenfor EU/CEPT mot slutten av året neste år....
Der tror jeg også du har rett. Da må det bli egenimport av andre regioners utstyr. Det er vel også helt uaktuellt å hente hjem noe sånn i kofferten under Covid-19. Beste nasjonen med minst covid-smitte måtte blitt Canada. Men også både der og i Norge har man karantenerestriksjoner å forholde seg til.
Å få noe sånn tilsendt som pakke er vel en risikosport, da man ikke vet hvor oppegående norske tollere måtte være på teknologi. Sannsynligvis meget lav forståelse der i gården. Men likevel så kan det jo hende at det ligger et ansvar på selgeren, ikke vet jeg?
Sannsynligvis må man vente en stund på 6E ja.
Men likevel, så har jo Asus da tatt sjansen. Da med tanke på esports-promotering vil jeg anta. Seile på den type reklame.
Endret av G
Utstyr med støtten vil ikke ha CE-merking vil jeg anta, så for tollen vil det kunne være ganske enkelt. I teorien kan man vel også få bøter hvis 6GHz er i bruk der man prøver å bruke ruteren, og de som bruker det rapporterer inn forstyrrelser. For det er andre løsninger som benytter 6GHz - og det er vel lisensbaserte løsninger, slik at de som drifter dem vil nok også være obs på forstyrrelser skulle jeg tro (og uten at jeg helt vet hvordan dette er i praksis).
Husk at det også er forskjeller på både 2,4 og 5 GHz i henhold til reguleringene innenfor EU/CEPT kontra eksempelvis USA.
Nå vil man også være avhengig av klientløsninger for å utnytte dette. Riktignok kan man si at WiFi 6E i starten kanskje har størst brukspotensiale som backhaul for mesh-løsninger o.l. I tillegg kan det vel være at man må fikle litt med "ting og tang" for å få det til å fungere på en PC med norsk regionsoppsett, slik driverne til klienter (altså wifi-kort, usb-dongle o.l.) vanligvis er laget. Eksempelvis hvis du kommer med en amerikansk PC til Norge, er det i hvert fall for en del klienter slik at man må sette de regionale innstillingene i Windows til et annet land for å bruke kanaler som ikke er støttet i USA. I hvert fall erfart det slik på Realtek-baserte løsninger tidligere - usikker om det gjelder eksempelvis Intel også, eller om man på klientsiden her kan si at det er aksesspunktet som egentlig styrer reguleringen, men at man begrenser kanalbruken hvis pc-en settes opp som et aksesspunkt.
Interessant det med at frekvensbåndenes utnyttelse for WiFi kan være forskjellig mellom regioner ja. Blir jo litt uvisst med klienter som du også nevner. Montro hvor mye strul Asus får med Europa- og Norge-godkjenningene..
Endret av G
Asus tar nok ikke denne saken. I praksis må EU/CEPT bestemme seg og sette en dato for når det er tillatt, samt få ut en offisiell publikasjon hva frekvensbåndet er og hvordan det kan brukes. Når det videre er på plass, blir det Asus som må ha en versjon av produktet som tilfredsstiller kravene. Kan godt også være at de må få en egen versjon av brikkesettet og wifi-kontrollere/radioer som de bruker som er tilpasset regulativet i Europa.
Mulig at første generasjon av produktet må være hardwaremessig mer fleksibelt enn noensinne, slik at de kan slå på og av ting i firmware etter behov.
Ja, man kan i teorien lage en versjon for det europeiske markedet som ikke støtter Wifi 6E i utgangspunktet, og så få dette via firmware-oppgradering senere. Blir med en viss risiko. Samtidig må enheter være produsert spesifikt for det europeiske markedet, og er vel ellers ganske strengt på at det ikke skal være mulig å enkelt sw-messig modifisere en løsning for at gå utenfor regulativet.
