Spørsmål om koronaviruset? Still spørsmål her ×
Koronaviruset i NORGE [Les første innlegg]
Simen1
G skrev (4 minutter siden):
I Israel har de kommet på en ny metode for covid-testing. Ved et lite inngrepende opplegg hvor pasient bruker munnskyll:
https://www.jpost.com/health-science/tired-of-nose-swabs-israeli-research-test-for-covid-19-in-mouthwash-675824
btw, du som liker alternativt testutstyr fra Biltema, kunne kanskje prøvd ut denne for oss :D
du dytter en i hvert nesebor og avleser resultatet på lcd-skjermen umiddelbart.
  • Hjerte 1
Digger forslaget.
Forresten sjekk: https://www.jpost.com/health-science/israeli-scientist-says-covid-19-could-be-treated-for-under-1day-675612
Noen av poengene her:
Quote
Prof. Eli Schwartz, founder of the Center for Travel Medicine and Tropical Disease at Sheba, conducted a randomized, controlled, double-blinded trial from May 15, 2020, through the end of January 2021 to evaluate the effectiveness of ivermectin in reducing viral shedding among nonhospitalized patients with mild to moderate COVID-19.
Quote
<snip>
Over the years, it has been used for other indications, including scabies and head lice. Moreover, in the last decade, several clinical studies have started to show its antiviral activity against viruses ranging from HIV and the flu to Zika and West Nile.
Quote
Researchers in other places worldwide began looking into the drug at around the same time. But when they started to see positive results, no one wanted to publish them, Schwartz said.
“There is a lot of opposition,” he said. “We tried to publish it, and it was kicked away by three journals. No one even wanted to hear about it. You have to ask how come when the world is suffering.”
“This drug will not bring any big economic profits,” and so Big Pharma doesn’t want to deal with it, he said.
Israeli scientist says COVID-19 could be treated for under $1/day
Double-blind study shows ivermectin reduces disease’s duration and infectiousness • FDA and WHO caution against its use
By MAAYAN JAFFE-HOFFMAN
AUGUST 2, 2021 21:01
Ivermectin (photo credit: REUTERS)
Ivermectin
Endret av G
  • Innsiktsfullt 1
DEPARTEMENTET: TIDEN FOR NASJONALE TILTAK KAN VÆRE FORBI
https://direkte.vg.no/nyhetsdognet/news/departementet-tiden-for-nasjonale-tiltak-kan-vaere-forbi.IaeMVfic2
Sitat
Helsedepartementet sier at en eventuell ny smittebølge trolig ikke blir møtt med en nasjonal nedstenging i høst, men at det kan bli regionale tiltak.
Helsedepartementet opplyser at alle voksne i løpet av neste uke vil ha fått tilbud om første vaksinedose. Innen siste halvdel av september skal alle ha fått tilbud om andre dose.
– Det er dermed ikke sikkert en eventuell ny smittebølge vil bli møtt med nasjonale tiltak på samme måte som tidligere. Det er mer sannsynlig at det vil bli satt inn lokale tiltak av kommunene, eventuelt at staten beslutter regionale tiltak, sier statssekretær Saliba Andreas Korkunc til NTB.
– Vi har gode erfaringer fra bruken av regionale tiltak ved lokale smitteutbrudd, sier han.
Helsedirektoratet og FHI jobber med en revisjon av tiltakene, i takt med at befolkningen blir vaksinert, opplyser han. (NTB)
  • Innsiktsfullt 2
Slo opp Ivermectin på Drugs.com som ofte har mange nyttige bivirkningsoversikter. Ivermectin har absolutt en del bivirkninger. Men, det sier seg jo ofte selv. Synes at de som fronter det sier det er en så mild behandling. Mot parasitter så er det jo en engangsdosering det gis. Så hvordan det nyttes i covid-forebygging er jo et litt åpen spørsmål her. Uansett så sies dette om stoffet, som er litt mer interessant:
Quote
How is Ivermectin thought to work on COVID-19?
For the SARS-CoV-2 virus to make you sick, it has to first infect your cells.
Then while inside the cell, the virus makes heaps of copies of itself, so it can spread around your body.
The virus also has ways of reducing the way your body fights the infection.
During the infection of the cell, some viral proteins go into the cell nucleus, and from here they can decrease the body’s ability to fight the virus, which means the infection can get worse.
Quote
To get into the nucleus the viral proteins need to bind a cargo transporter which lets them in.
Ivermectin can block the cargo transporter, so the viral proteins can’t get into the nucleus. This is how the scientists believe Ivermectin works against SARS-CoV-2 virus.
By taking Ivermectin, it means the body can fight the infection like normal, because its antiviral response hasn’t been reduced by the viral proteins.
https://www.drugs.com/medical-answers/ivermectin-treat-covid-19-coronavirus-3535912/
Noen interessante spørsmål blir da: Hva transporterer dette "cargo transporter" vanligvis? Er dette noe man tåler at blokkeres på en grei måte? Er det pga. den blokkeringen at man opplever ymse bivirkninger?
Endret av G
siden det er så få sykehusinnleggelser nå, tyder ikke det på at Delta er mindre alvorlig enn fryktet?
man prøver å gi cred til at det er pga. vaksine, men det stemmer vel ikke, siden fullvaksinerte smittede (siste 14 dager) bare utgjør 250 av 3800 smittede. Ergo fremstår det som heller ikke u-vaksinerte innlegges i særlig grad.
  • Innsiktsfullt 1
Vet ikke vad du har förväntat. Finns en del man kan tänka på:
De flesta smittede er unga.
Delta har väl inte varit dominerande så väldigt länge? Kanske bara de siste två ukene eller noe.
Inlagda är i alla fall 10% av smittede per dag hvis man ser på snitt når det har varit stabilt. Var mer tidigare men så väldigt lite är det ikke.
Problemet med delta tror jag mest är att det smitter lättare, antagligen smitter vaksinerade lättare och en del full vaksinerade sprer också viruset vidare.
  • Liker 3
  • Innsiktsfullt 3
Mr.M skrev (2 timer siden):
Stikkordet er Fullvaksinerte, som er det de 250 smittede er. Det er sikkert en større andel av de 3800 smittede som er delvaksinerte ;)
Endret av Evil-Duck
  • Liker 4
54 minutes ago, Kjetil Lura said:
Min er ikke fra biltema, viser 000:grin:
Har du prøvd å sette den til Omega-symbolet? Du må ikke glemme å følge Mr.M sine instrukser om en pinne opp i hvert nesebor. Prøv å få kontakt med slimhinne for best måleresultat?
Hva verdier får du da, og hva betyr disse tallverdiene egentlig for oss ulærte? :wee: Hjelper det om jeg tar litt Omega-3 ? Er Möllers tran ok?
Endret av G
At vi ville få en fjerde smittebølge forstod man allerede når man åpnet for fri reise tidlig i sommer og slapp helt opp for reiser i sommer. At det ikke kommer som en overaskelse blir litt "captain obvious" aka "Vi åpna krana så vi regner med å få litt vann på gulvet etterhvert".
Det jeg er mer spent på er hva vi vil se ut august og de neste par måneder som et resultat av det. Fikk forøvrig beskjed i går om at en kollega av en bekjent ble lagt inn etter å ha svimt av og gått i bakken og testet positiv på sykehuset. Han er dog ikke registrert som "covid innlagt" men undersøkes om det har vært årsaken til hendelsen. Han er i 40 årene.
Endret av Theo343
satt å grublet over noe her, typ "snedige ting du lurer på"
er det smart å snyte seg litt ofte (for å bli kvitt evt. ansamling av virus)
eller
vil det bare føre til tørrere vegger oppe i snyteskaftet (og evt. lettere for virus og annet å feste seg)
kan ikke se det har vært skrevet noe om dette på FHI etc. i løpet av pandemien. Hva tror dere?
G skrev (10 minutter siden):
bare for å presisere,
en i hvert nesebor er for å sjekke antigen, altså om du er smittet her og nå.
derimot, en i rektum og den andre oralt, viser om de har antistoffer, dvs. har gjennomgått Covod-19
god fornøyelse :evil:
Hvis man ikke får et godt resultat kan man forsøke å bytte om på nodene.
  • Liker 3
Mr.M skrev (3 timer siden):
1) cred til vaksinen om kun 6,6% av de smittede er fullvaksinerte når en tredjedel av befolkningen er fullvaksinert
2) blant de resterende 3350 som ikke var fullvaksinert så var sannsynligvis en stor andel vaksinert med én dose, som også gir veldig god beskyttelse mot alvorlig sykdom (dog ikke allverdens beskyttelse mot infeksjon)
3) det er hovedsakelig de yngste og minst utsatte som ikke er vaksinert enda. Dvs. om smitten øker i befolkningen mens innleggelse ikke øker så er det all mulig cred til vaksinen. Det ser man tydelig i UK og andre land med høy vaksinasjonsgrad, til tross for at smitten skyter i været så øker innleggelse og død relativt forsiktig
  • Innsiktsfullt 1
fredrik2 skrev (29 minutter siden):
Det är ikke som tidigare men nog ökar inläggelser också. I Norge får vi se hur det går. Smitteökningen har ikke haft tid att resultera i inläggelser ännu.
https://coronavirus.data.gov.uk/details/healthcare
Det er fortsatt for tidlig å si sikkert, men innleggelser ser ut å falle igjen i UK etter at smitten, som vel ingen forventet, har gått ned igjen. Det spekuleres i at spesielt EM skapte en midlertidig bølge. Det er nok gode muligheter for en ny kraftig økning når høsten kommer, men uansett oppløftende at andelen smittede som har blitt lagt inn og døde er så mye lavere enn det var før vaksinasjonen.
knipsolini skrev (36 minutter siden):
Smitten nå i UK er under halvparten av hva den var på det høyeste for drøyt tre uker siden. Og antall innlagte nådde aldri mer enn 1/6 av hva det var i vinter. Og det i nasjon hvor den generelle folkehelsen neppe er den aller beste. De som er bekymrede for tiden bør absolutt ikke bli hørt fremover. Det bør ikke komme innskrenkninger og flere tiltak, og man bør heller gå til trinn 4 med gjenåpning fremfor å gå den andre veien.
Endret av OlavEH
  • Liker 3
