FatherPotato Skrevet 13. november 2020 Del Skrevet 13. november 2020 Sitoy skrev (På 13.11.2020 den 23.29): Hadde 12. november på min og den ble sendt den 11, kom igår (13) Ekspander 3080 strix oc? Lenke til kommentar
J!nx Skrevet 13. november 2020 Del Skrevet 13. november 2020 (endret) Emile the rat skrev (På 13.11.2020 den 23.12): Noen som vet hvordan man justerer viftehastigheten? Verken Aorus engine eller MSI afterburner funker, kortet reagerer ikke på viftekontroll 😕 Ekspander Fant denne på reddit, så det funker visstnok med afterburner osv: "realk3wl 1 point · 1 day ago Could it be that your fans are not cooling the card sufficiently? I also just got my Aorus Xtreme 3090 yestaerday and one very weird thing I noticed was the highly unusual fan behavior. For me, the fans didn't start spinning at all at first except for the first moment of booting up. Then, after installing the native Aorus software for fan control (it's a nightmare), fans started spinning, but were contantly speeding up and slowing down. After getting rid of the Gigabyte software, installing MSI Afterburner and configuring a custom fan curve, the problem was solved." Endret 13. november 2020 av J!nx Lenke til kommentar
Emile the rat Skrevet 14. november 2020 Del Skrevet 14. november 2020 J!nx skrev (På 13.11.2020 den 23.46): Fant denne på reddit, så det funker visstnok med afterburner osv: "realk3wl 1 point · 1 day ago Could it be that your fans are not cooling the card sufficiently? I also just got my Aorus Xtreme 3090 yestaerday and one very weird thing I noticed was the highly unusual fan behavior. For me, the fans didn't start spinning at all at first except for the first moment of booting up. Then, after installing the native Aorus software for fan control (it's a nightmare), fans started spinning, but were contantly speeding up and slowing down. After getting rid of the Gigabyte software, installing MSI Afterburner and configuring a custom fan curve, the problem was solved." Ekspander Har prøvd det alt, men av en eller annen grunn responderer den ikke engang med MSI afterburner. Mulig jeg burde bruke REVO uninstaller, tilfelle det er noen reg filer som henger igjen etter jeg uinstallerte Aorus programmet 1 Lenke til kommentar
fudun Skrevet 14. november 2020 Del Skrevet 14. november 2020 Da har jeg endelig somla meg ned på butikken og henta MSI 3080 Ventus 3X OC. Klarer ikke helt bestemme meg for om jeg skal åpne og prøve det. Har egentlig tenkt å gå for X Trio eller TUF OC som ser ut til å sendes i desember. Lenke til kommentar
ticx Skrevet 14. november 2020 Del Skrevet 14. november 2020 Fikk 3090 strix oc fra komplett nå før helga, for en FEIT kubbe. Måtte veie det, landet på 1800gram 🤡 Sitter på 30-40 tallet idle og har ikke fått det over 70 grader enda, for et beist. Nesten helt stille også, var kjempehappy med 3090 zotac som ventekort, men det var både varmere og ga mye mer lyd. Nesten 1000 poeng mer i 3dmark utav boksen også for Asus, happy customer. 5 Lenke til kommentar
Theo343 Skrevet 14. november 2020 Del Skrevet 14. november 2020 (endret) *feil tråd* Endret 14. november 2020 av Theo343 Lenke til kommentar
Emile the rat Skrevet 14. november 2020 Del Skrevet 14. november 2020 Fikk fiksa viftene på Aorus, her er hva jeg gjorde, tilfelle noen andre har lignende problem med Ampere kort fra Gigabyte. 1) Først brukte jeg REVO uninnstaller og fjernet samtlige programmer fra Gigabyte og reg filer. 2) Avinnstallerte også MSI afterburner og Riva tuner, her trengte jeg ikke å fjerne reg filer. 3) Restartet PC og innstallerte MSI afterburner og Riva tuner. Restarta PC på nytt etter innstallasjon. 4) Her kommer trikset. Av en eller annen grunn må jeg restarte PCen for hver gang jeg lager vifteprofil i MSI afterburner. Det vil si at endringer på vifter i MSI afterburner ikke trer i kraft før jeg restarter PCen. (Hvorfor det er slik er jeg ikke helt sikker på, men funker). Så hvis noen andre og får problemer med vifter på kort fra Aorus / Gigabyte så anbefaler jeg å prøve dette først ticx skrev (På 14.11.2020 den 5.10): Fikk 3090 strix oc fra komplett nå før helga, for en FEIT kubbe. Ekspander Når vi snakker om kubbe, Aorus Xtreme er jo like feit som rotta jeg har på lcd displayet. Men kjøleren gjør virkelig jobben. Nå kjører jeg to 1x8 PCIE til 2x8 PCIE, så får ikke begitt meg ut på overklokking enda Men på stock så ligger den stabilt på 31-34 grader, og under last er den på rundt 41-47 grader. Så forstår hvorfor kjøleren er så enorm. Ikke fått brukt kortet så lenge enda, så blir jo interessant å se hva som skjer med temperatur over lengre intense spillperioder Og i tyngre spill som Watch Dogs, Valhalla og Cyberpunk. 1 1 Lenke til kommentar
PaladinNO Skrevet 14. november 2020 Del Skrevet 14. november 2020 (endret) Emile the rat skrev (På 13.11.2020 den 23.12): Noen som vet hvordan man justerer viftehastigheten? Verken Aorus engine eller MSI afterburner funker, kortet reagerer ikke på viftekontroll 😕 Ekspander Wait, what? MSI Afterburner kan ikke styre GPU-viftene på Aorus Xtreme? EDIT: Emile the rat skrev (På 14.11.2020 den 10.38): Fikk fiksa viftene på Aorus, her er hva jeg gjorde, tilfelle noen andre har lignende problem med Ampere kort fra Gigabyte. ~snip~ Ekspander Phew, takker! Endret 14. november 2020 av PaladinNO Lenke til kommentar
Emile the rat Skrevet 14. november 2020 Del Skrevet 14. november 2020 PaladinNO skrev (På 14.11.2020 den 10.43): Wait, what? MSI Afterburner kan ikke styre GPU-viftene på Aorus Xtreme? Ekspander Les posten min over, fikk løst det. Er bare programvaren til Aorus, og biosen som er helt forferdelig å sammarbeide med Lenke til kommentar
PaladinNO Skrevet 14. november 2020 Del Skrevet 14. november 2020 (endret) Emile the rat skrev (På 14.11.2020 den 10.44): Les posten min over, fikk løst det. Ekspander Drev akkurat å endret posten min. Sånn er det når man prioriterer å sove - blir jo 15 nye sider her i tråden over natten. ^^ Endret 14. november 2020 av PaladinNO Lenke til kommentar
BadCat Skrevet 14. november 2020 Del Skrevet 14. november 2020 (endret) ticx skrev (På 14.11.2020 den 5.10): Fikk 3090 strix oc fra komplett nå før helga, for en FEIT kubbe. Måtte veie det, landet på 1800gram 🤡 Sitter på 30-40 tallet idle og har ikke fått det over 70 grader enda, for et beist. Nesten helt stille også, var kjempehappy med 3090 zotac som ventekort, men det var både varmere og ga mye mer lyd. Nesten 1000 poeng mer i 3dmark utav boksen også for Asus, happy customer. Ekspander Da kjører du ikke kortet hardt nok.Din mor bad deg sette stekeovnen til 250 grader, ikke 170. Jeg fikk bra ned varme på mitt da jeg kjørte på med frekvens og spenning. Dessverre stiger effekten mer enn ytelsen når man øker spenningen. Ser ikke vits i å kjøre kortet over 2000 MHz. 5-10% undervolt og 1900+ MHz er hva jeg skal ha til 24/7. Endret 14. november 2020 av BadCat Lenke til kommentar
Emile the rat Skrevet 14. november 2020 Del Skrevet 14. november 2020 PaladinNO skrev (På 14.11.2020 den 10.45): Drev akkurat å endret posten min. Sånn er det når man prioriteterer å sove - blir jo 15 nye sider her i tråden over natten. ^^ Ekspander Jepp, var ganske frustrert før jrg fikk fiksa det. Lenke til kommentar
PaladinNO Skrevet 14. november 2020 Del Skrevet 14. november 2020 Emile the rat skrev (På 14.11.2020 den 10.47): Jepp, var ganske frustrert før jrg fikk fiksa det. Ekspander Da håper jeg på å slippe enklere unna når (hvis? Proshop, please?) jeg får kortet mitt. Jeg har ikke hatt Aorus programvare installert før, og jeg har allerede en ferdig viftekurve i Afterburner. Lenke til kommentar
Mala Skrevet 14. november 2020 Del Skrevet 14. november 2020 (endret) Trist man ikke fikk seg COD kode, for dette hadde vært penger spart lol. Nå må man heller kjempe om refund hos Blizzard som påstår jeg har spilt i over 10 timer 😛 Spilt 2 enspiller oppdrag i går, og ett par avbrutte runder online i dag. Men spillet ser helt ræva blues ut slik som Modern Warfare, blurry og jævlig online. Ikke funket settings menyen heller slik at man fikk slått av Anti-Aliasingen. Så dette var skikkelig dårlig førsteintrykk av COD på PC atter en gang. Og går ikke klagen min igjennom så er det siste gang Battle.net er å finne på min maskin. Endret 14. november 2020 av Mala Lenke til kommentar
Mumriken Skrevet 14. november 2020 Del Skrevet 14. november 2020 Emile the rat skrev (På 14.11.2020 den 10.38): Nå kjører jeg to 1x8 PCIE til 2x8 PCIE, så får ikke begitt meg ut på overklokking enda Ekspander Klart du kan overklokke forutsatt at du ikke har en fullstendig krise jalla psu. Alldri hatt problemer med pigtails psu kabler på vannkjølte XOC kort med høyere effekt 500W (maks for et nok shunted 3090) Undervolter da heller ikke 3*8pin kort.. 500W bios ftw 1 Lenke til kommentar
Zeroni13 Skrevet 14. november 2020 Del Skrevet 14. november 2020 Noen som i det hele tatt har fått 3080 Strix OC? Min står fortsatt slik: 1 Lenke til kommentar
Nixs Skrevet 14. november 2020 Del Skrevet 14. november 2020 Zeroni13 skrev (På 14.11.2020 den 11.56): Noen som i det hele tatt har fått 3080 Strix OC? Min står fortsatt slik: Ekspander Samme her. Lenke til kommentar
BadCat Skrevet 14. november 2020 Del Skrevet 14. november 2020 Zeroni13 skrev (På 14.11.2020 den 11.56): Noen som i det hele tatt har fått 3080 Strix OC? Min står fortsatt slik: Ekspander Kanskje de venter på at folk skal kansellere slik at de kan selge de til høyere pris. Jeg antar det er mange som kjøpte et slikt kort med 10% rabatt og det er ikke god butikk. De ønsker nok å selge til 12k+ uten rabatt. Lenke til kommentar
Kjeks1 Skrevet 14. november 2020 Del Skrevet 14. november 2020 Zeroni13 skrev (På 14.11.2020 den 11.56): Noen som i det hele tatt har fått 3080 Strix OC? Min står fortsatt slik: Ekspander Samme her Lenke til kommentar
BadCat Skrevet 14. november 2020 Del Skrevet 14. november 2020 Kan ikke en spørre support på vegne av de som venter og så poste her? Lenke til kommentar
