"beste" hdmi kabel
Hei. Gaming pcen min med rtx 2080 trenger en 10m lang hdmi kabel til lg65sm9800 tven, ønsker å kjøre steam spill i 1440p. Av tidligere brukte jeg https://www.komplett.no/product/846082/datautstyr/pc-tilbehoer/kabler/hdmi/iiglo-hdmi-kabel-10m?noredirect=true?noredirect=true men denne kutter bildet litt ut i noen sek fra tid til annen som er vist pga lang ledning og ikke sterkt nok signal? Hvertfall det jeg har lest av lignende opplevelser.
Har lest om aktiv hdmi kabel som visst styrker signalet ved lengre avstand, kan dette være noe for meg? Kan denne være god nok https://www.komplett.no/product/431773/tv-lyd-bilde/kabler/hdmi-kabler/supra-high-speed-hdmi-kabel-10m ? Evt om dere vet om alternativer?
Takk
Generelt sett, trenger du ikke kabel med oksygenfritt kobber (snake oil) for å få bilde. ? Med det sagt, utgjør (større) lengder en forskjell. Diverse kilder sier følgende:
Sitat
HDMI is hit or miss when it comes to longer runs. Distance plays an extreme factor to signal transmission.
Sitat
If you're in the longer-than-50-foot category, it gets dicier. We have had good consistent results with the BJC Series-1 cable out to 100 feet, with reports of no trouble in the great majority of installations. Cable quality starts to be a real concern at these distances, and performance always is hard to predict, especially because the cable that works on one source/display pair may not work on another. There is, unfortunately, no really good way to know what will work without plugging it in.
Sitat
Are expensive HDMI cables necessary?
High Definition Multimedia Interface is a digital signal transmitting zeros and ones. This means that the cable should, in theory, either work or it won't. However, signals can and will often be affected by factors such as:
  • Transmission distance
  • Higher resolutions
  • Interference form other electrical/electronic devices
  • Environmental factors
  • Cable quality
Tror likevel at Supra du linker til ikke vil ha problemer, men det blir litt eksperimentering.
