Yale Doorman V2 + Smartthings - any chance?
hi there! Does anyone know if it's possible to connect a Yale Doorman V2 (not V2N) to a Smartthings hub using the Yale Doorman Smart Home Module (https://www.elkjop.no/product/smarte-hjem/smart-sikkerhet-overvakning/elektronisk-dorlas/18185/yale-smartmodul-til-doorman-v2n-las)?
I've tried to do some searching around these parts but my Norwegian isn't great. Ideally, I'd like to avoid purchasing the Yale hub if I can just use the module to connect the lock to Smartthings.
