stian_molvik Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 I cellen skal texten opperst isteden for nederst,, har prøvd mg rundt med valign og altslags, nada funker.. Ibsen Art Sikkert etleraent møkkalett jeg overser,, eller Lenke til kommentar
Dunestar Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 (endret) <html> <head> <title>Untitled Document</title> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> <link href="Level1_Arial.css" rel="stylesheet" type="text/css"> <script language="JavaScript" type="text/JavaScript"> <!-- function MM_swapImgRestore() { //v3.0 var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc; } function MM_preloadImages() { //v3.0 var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array(); var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++) if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}} } function MM_findObj(n, d) { //v4.01 var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) { d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);} if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n]; for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document); if(!x && d.getElementById) x=d.getElementById(n); return x; } function MM_swapImage() { //v3.0 var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3) if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];} } //--> </script> </head> <body onLoad="MM_preloadImages('/rollover/camera%20on.jpg','rollover/book%20on.jpg','rollover/photo%20on.jpg','top 1 kort.jpg','top 2 kort.jpg','top 3 kort.jpg','below 1.jpg','below 2.jpg','below 3.jpg','center 1.jpg','center 2.jpg','center 3.jpg','bottom 1 mod.jpg','bottom 2.jpg')"> <table width="349" height="275" border="0" cellpadding="0" cellspacing="0" valign="top"> <tr> <th scope="col"><img src="top%201 kort.jpg" width="87"></th> <th scope="col"><img src="top%202 kort.jpg" width="396"></th> <th scope="col"><img src="top%203 kort.jpg" width="317"></th> </tr> <tr> <td><img src="below%201.jpg" width="87" height="38"></td> <td><img src="below%202.jpg" width="396" height="38"></td> <td><img src="below%203.jpg" width="317" height="38"></td> </tr> <tr> <td><img src="center%201.jpg" width="87" height="215" style="valign:top"></td> <td style="valign:top" background="center%202.jpg"><img src="transparent.gif" width="18" height="210">Dette skal stå opperst i cellen</td> <td style="valign:top"><img src="center%203.jpg" width="317" height="215"></td> </tr> <tr> <td background="bottom%201 mod.jpg"><table width="0" border="0" cellspacing="0" cellpadding="0" align="center" valign="top"> <tr> <th width="241" height="19" scope="col"> </th> </tr> <tr> <th height="10" scope="col"><a href="Filmer.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Camera','','rollover/camera%20on.jpg',1)"><img src="rollover/camera%20off.jpg" name="Camera" width="50" height="50" border="0"></a></th> </tr> <tr> <th height="50"><a href="Biografi.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Bio','','rollover/book%20on.jpg',1)"><img src="rollover/book.jpg" name="Bio" width="50" height="50" border="0"></a></th> </tr> <tr> <th height="50"><a href="Foto.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Foto','','rollover/photo%20on.jpg',1)"><img src="rollover/photo%20off.jpg" name="Foto" width="50" height="50" border="0"></a></th> </tr> <tr> <td height="116"> </td> </tr> </table></td> <td><img src="bottom%202.jpg" width="396" height="466"></td> <td><img src="bottom%203.jpg" width="317" height="466"></td> </tr> </table> </body> </html> Endret 1. januar 2004 av Dunestar Lenke til kommentar
huf Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 Hva var det du gjorde da Dunestar? Lenke til kommentar
Dunestar Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 (endret) Hva var det du gjorde da Dunestar? Mekka litt på koden. Den kan bare limes inn og den skal etter mitt skjønn fungere. Endret 1. januar 2004 av Dunestar Lenke til kommentar
huf Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 Hva var det du gjorde da Dunestar? Mekka litt på koden. Den kan bare limes inn og den skal etter mitt skjønn fungere. Ja, det forstod jeg da..lurte på hvilken ting du forandret på. Lenke til kommentar
Dunestar Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 (endret) Hva var det du gjorde da Dunestar? Mekka litt på koden. Den kan bare limes inn og den skal etter mitt skjønn fungere. Ja, det forstod jeg da..lurte på hvilken ting du forandret på. <tr> <td><img src="center%201.jpg" width="87" height="215" style="valign:top"></td> <td style="valign:top" background="center%202.jpg"><img src="transparent.gif" width="18" height="210">Dette skal stå opperst i cellen</td> <td style="valign:top"><img src="center%203.jpg" width="317" height="215"></td> </tr> Endret 1. januar 2004 av Dunestar Lenke til kommentar
Arve Systad Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 (endret) <td valign="top"> innhold </td> for å gjøre det enkelt Endret 1. januar 2004 av arve87 Lenke til kommentar
stian_molvik Skrevet 1. januar 2004 Forfatter Del Skrevet 1. januar 2004 (endret) kopierte og limte koden din jeg dunestar,, ble ikke no aent resultat,, valign="middle" gjorde heller ikke trikset arve.. Endret 1. januar 2004 av stian_molvik Lenke til kommentar
enden Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 (endret) Teit å rediger hele koden og gi den tilbake. Det hjelper ikke så mye når vedkommende må tråle seg gjennom en masse kode for å kanskje finne noe som er endret. Vis hva du endrer og hvor du endrer det og hvorfor. Da er det mye lettere å lære noe av det Riktig er forøvrig <td valign="top">innhold</td> Ganskel logisk at top er riktig verdi når teksten skal stå "opperst" Endret 1. januar 2004 av enden Lenke til kommentar
Arve Systad Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 @ meg sjøl, meinte seff å skrive "top" der eg presterte å skrive "middle"... aner virkelig ikkje korfor... Lenke til kommentar
huf Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 @ meg sjøl, meinte seff å skrive "top" der eg presterte å skrive "middle"... aner virkelig ikkje korfor... Bra arve! Lenke til kommentar
stian_molvik Skrevet 1. januar 2004 Forfatter Del Skrevet 1. januar 2004 Problem fikset,, Fant ut at gif-bildet jeg brukte som marg, fokket opp ganske bra... Lenke til kommentar
enden Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 Takk for dagens smil Arve Lenke til kommentar
