G Skrevet 11. juni 2020 Forfatter Del Skrevet 11. juni 2020 Lager en digresjon her, siden det ser ut som om at det snart finnes reelle gaming-TV alternativer å få: https://www.guru3d.com/news-story/samsung-optimizes-new-qled-tvs-for-gaming-with-adaptive-sync-and-hdmi-2-1.html Spoiler Samsung optimizes New QLED TVs for gaming with Adaptive Sync and HDMI 2.1 by Hilbert Hagedoorn on: 06/11/2020 09:06 AM | source: samsung.com (via Hexus.net) | 8 comment(s) LG not too long ago announced improved support for gaming on their new tellys, so Samsung now also makes an effort. The 2019 and newer QLED TV sets are are optimised for "more immersive and responsive gaming sessions". Gaming is becoming more of a thing on TVs and with the newest Consoles and technologies like adaptive sync / HDR in mind, Samsung is keen to have you purchase their product. Samsung mentions the following key features of its new QLED TVs that will appeal to gamers: 4K@120Hz via HDMI 2.1-certified connector FreeSync Premium compatibility to minimize stuttering and tearing Low Input Lag, as low as 9.8ms Game Motion Plus to minimize motion blur and halo effects Auto Game Mode Dynamic Black EQ for clear pixel peeping in shady areas without washout Immersive built-in sound system with added 'Object Tracking Sound' technology Also, an interesting that is mentioned is a 'Multi-View' capability, basically, PIP splitting your screen with one game on the left, the other on the right. Lenke til kommentar
G Skrevet 14. juni 2020 Forfatter Del Skrevet 14. juni 2020 (endret) Oppdaget (har ikke giddet å kikke for mye rundt før i dag) i Radeoen Software at Freesync ikke er støttet med LG CX gaming-TV + AMD RX 5600XT + HDMI 2.1-kabel fra Hama. Håper dette er en midlertidig ting inntil jeg får kjøpt mer kraftig GPU: Endret 14. juni 2020 av G 1 Lenke til kommentar
samco Skrevet 19. juni 2020 Del Skrevet 19. juni 2020 Helt grei tv noen sliter litt med banding på AVS med 48cx. Tenke egentlig å kjøpe en selv men da nyheten om bare 40gbs hdmi så droppa jeg kjøpet gikk for en C9 med 48gbs hdmi som klarer 12 bit 444 ,120HZ ,2160p. For litt mere framtid sikring. Lenke til kommentar
G Skrevet 25. juni 2020 Forfatter Del Skrevet 25. juni 2020 (endret) On 6/19/2020 at 11:11 PM, samco said: Helt grei tv noen sliter litt med banding på AVS med 48cx. Tenke egentlig å kjøpe en selv men da nyheten om bare 40gbs hdmi så droppa jeg kjøpet gikk for en C9 med 48gbs hdmi som klarer 12 bit 444 ,120HZ ,2160p. For litt mere framtid sikring. Om du sjekker "sikringen", så er jo C9 2019-modeller og har dårligere prosessor. Og CX (noen hevder det skal uttales C10 andre CX) er 2020-modellene som denne artikkelens TV tar for seg. Jeg tror du har misforstått når du leser modellnummeret, eller mener du det du ytrer? La oss ihvertfall få avklart det med modellnummer først, så kan en jo kikke på hva specs. måtte være som prioritet nr. 2, greit? Endret 25. juni 2020 av G Lenke til kommentar
samco Skrevet 26. juni 2020 Del Skrevet 26. juni 2020 (endret) G skrev (21 timer siden): Om du sjekker "sikringen", så er jo C9 2019-modeller og har dårligere prosessor. Og CX (noen hevder det skal uttales C10 andre CX) er 2020-modellene som denne artikkelens TV tar for seg. Jeg tror du har misforstått når du leser modellnummeret, eller mener du det du ytrer? La oss ihvertfall få avklart det med modellnummer først, så kan en jo kikke på hva specs. måtte være som prioritet nr. 2, greit? C9 har full 12 bit 444 2160 hdr på dagens PCr en unik tv. mot 8bit på CX tror det har mere betydning en litt bedre motion på 24hz filmer. Får håpe neste års LG XI får full båndbredde igjen på hdmi inngangene Endret 26. juni 2020 av samco Lenke til kommentar
G Skrevet 26. juni 2020 Forfatter Del Skrevet 26. juni 2020 (endret) 2 hours ago, samco said: C9 har full 12 bit 444 2160 hdr på dagens PCr en unik tv. mot 8bit på CX tror det har mere betydning en litt bedre motion på 24hz filmer. Får håpe neste års LG XI får full båndbredde igjen på hdmi inngangene HDMI er 2.1, så da må det du prater om evt. ligge på elektronikk videre i behandlingskjeden? Dessuten har CX en nyere bedre prosessor. Så det rimer ikke helt. Jeg skal la tvilen komme deg litt tilgode. Men kan du også dobbeltsjekke? Her må en altså inn i specs. å sammenlikne? Quote Spoiler Pros Excellent HDRExcellent HD, 4KHDMI 2.1 ports, featuresGaming features like 4K HFR, VRRNew 48" size Cons Rear-facing portswebOS not receiving updates77" still very expensive https://www.flatpanelshd.com/review.php?subaction=showfull&id=1585020920#6 Skal vi se: Han fyren nedenfor sin unboxing 23. juni. Fikk denne TV'en før denne pro-testeren jeg https://www.displayspecifications.com/en/model/9ae01dec Nå er ikke jeg så stødig på TV'er, men det er panelet du prater om, ikke sant? Står 10-bit, og ikke 8-bit som du hevder. Tror også 30-bits farger holder til min bruk. Modellbetegnelse 48" CX LG α9 Gen 3 processor LG OLED48CX6LB Modellbetegnelse 55" C9 LG OLED55C9MLB.AEU Jeg finner ikke MLB. Finner PLA og PUA Denne PLA-modellen er også 10-bits og 30-bits farger https://www.displayspecifications.com/en/model/9b6c18b5 Denne PUA-modellen er er også 10-bits og 30-bits farger https://www.displayspecifications.com/en/model/8a79189a Uten å søke opp MLB spesifikkt fra 2019 C9 så ser jo panelet kliss likt ut på specs. C9-modellen har uansett fjorårets prosessor: 2nd Gen α9 Processor Endret 26. juni 2020 av G Lenke til kommentar
MrMarbles Skrevet 26. juni 2020 Del Skrevet 26. juni 2020 G skrev (11 minutter siden): HDMI er 2.1, så da må det du prater om evt. ligge på elektronikk videre i behandlingskjeden? Dessuten har CX en nyere bedre prosessor. Så det rimer ikke helt. Jeg skal la tvilen komme deg litt tilgode. Men kan du også dobbeltsjekke? Her må en altså inn i specs. å sammenlikne? https://www.flatpanelshd.com/review.php?subaction=showfull&id=1585020920#6 Skal vi se: https://www.displayspecifications.com/en/model/9ae01dec Han henger seg opp i at CX "kun" har ~40Gbps båndbredde på HDMI 2.1 mot 48Gbps på C9. 40Gbps er akkurat nok til 4K 120Hz 4:4:4 @10bit. C9 vil klare 12bit på samme oppløsning, men igjen, OLED-panelene er 10bit-paneler, så det har absolutt null og si. Du vil ikke klare å kjøre et 12bit signal til C9 heller, siden panelet ikke støtter 12bit. 1 Lenke til kommentar
G Skrevet 26. juni 2020 Forfatter Del Skrevet 26. juni 2020 Jeg lurer på om samco har misunnelse, og håper jeg returnerer TV'en? Så han kan stille i kø og få, siden jeg fikk den så tidlig? Bare en tanke Lenke til kommentar
samco Skrevet 28. juni 2020 Del Skrevet 28. juni 2020 (endret) G skrev (På 26.6.2020 den 11.11): Jeg lurer på om samco har misunnelse, og håper jeg returnerer TV'en? Så han kan stille i kø og få, siden jeg fikk den så tidlig? Bare en tanke Misunelse ? nei Ikke en millimeter...var en grunn til at jeg hoppa fort påen C9 etter hdmi skandalen med CX ... tar ikke sjangsen med kun 10 bit på neste generasjon konsoller. Har bra headroom på hdmi fart og 12bit støtte . Bedre in Bedre ut prinsippet. Endret 28. juni 2020 av samco Lenke til kommentar
samco Skrevet 28. juni 2020 Del Skrevet 28. juni 2020 MrMarbles skrev (På 26.6.2020 den 10.56): Han henger seg opp i at CX "kun" har ~40Gbps båndbredde på HDMI 2.1 mot 48Gbps på C9. 40Gbps er akkurat nok til 4K 120Hz 4:4:4 @10bit. C9 vil klare 12bit på samme oppløsning, men igjen, OLED-panelene er 10bit-paneler, så det har absolutt null og si. Du vil ikke klare å kjøre et 12bit signal til C9 heller, siden panelet ikke støtter 12bit. Tror du må lese mere opp har altid vært brukt 12 bit in fra kilder på tvr fra UHD for best mulig signal in. 10 bit er kun en nerfing for å skille 4K og 8k som bruker 12bit selv med ..... 10 bit paneler ...... Lenke til kommentar
KriZZ Skrevet 28. juni 2020 Del Skrevet 28. juni 2020 C9 til halve prisen er sånn sett ikke noe å lure på. Var selv på ballen og vurderte en 55" CX til pcn, men så fikk jeg C9 til 10k med DNB supertilbud hos power nå, så den får duge 10 000,- spart som kan brukes på noe annet fornuftig ? 1 Lenke til kommentar
samco Skrevet 28. juni 2020 Del Skrevet 28. juni 2020 KriZZ skrev (5 minutter siden): C9 til halve prisen er sånn sett ikke noe å lure på. Var selv på ballen og vurderte en 55" CX til pcn, men så fikk jeg C9 til 10k med DNB supertilbud hos power nå, så den får duge 10 000,- spart som kan brukes på noe annet fornuftig ? Bedre for spilling spesielt for PC brukere nå. Er en unik tv C9 og E9 med farten på hdmi. Ble solgt litt C9 i USA og England etter hdmi nyheten om 2020 ikke støtter full 2.1 Lenke til kommentar
KriZZ Skrevet 28. juni 2020 Del Skrevet 28. juni 2020 samco skrev (3 minutter siden): Bedre for spilling spesielt for PC brukere nå. Er en unik tv C9 og E9 med farten på hdmi. Ble solgt litt C9 i USA og England etter hdmi nyheten om 2020 ikke støtter full 2.1 Ja, må bare vente på rtx 30XX så 2.1 støtte er på plass og 120Hz over 4K lar seg gjøre med pcn 2560x1440p får duge inntil videre. Det krever jo uansett sitt å nå 120fps i 4K! Lenke til kommentar
G Skrevet 28. juni 2020 Forfatter Del Skrevet 28. juni 2020 (endret) Får håpe jeg får mye desktop + spillglede med CX 48" skjermen da. Respekterer at andre kan ha andre meninger om ting. Har tilgode å kjøpe TV som jeg ønsker absolutt størst mulig om det gir høy nok WAF da. Men, her vil jeg pine ut tiden så lenge lenge jeg kan. Så en får ekstra mye for pengene. Har ingen planer om en umiddelbar TV-fornyelse etter kjøpet av 48" til bruk på "gutterommet/mannehulen". Har ikke TV for tiden i stue. Bruker PC-monitor til TV. Sitter ekstra nære den fra sofa Ser ikke for mye TV uansett. Men bare måtte ha en arbeidsskjerm først og fremst, og at den er spillkapabel. Skulle gjerne hatt 12-bit, som dere er inne på dersom det er av betydning. Endret 30. juni 2020 av G redigert ordet til "størst" nå 1 Lenke til kommentar
MrMarbles Skrevet 29. juni 2020 Del Skrevet 29. juni 2020 G skrev (13 timer siden): Får håpe jeg får mye desktop + spillglede med CX 48" skjermen da. Respekterer at andre kan ha andre meninger om ting. Har tilgode å kjøpe TV som jeg ønsker absolutt størt mulig om det gir høy nok WAF da. Men, her vil jeg pine ut tiden så lenge lenge jeg kan. Så en får ekstra mye for pengene. Har ingen planer om en umiddelbar TV-fornyelse etter kjøpet av 48" til bruk på "gutterommet/mannehulen". Har ikke TV for tiden i stue. Bruker PC-monitor til TV. Sitter ekstra nære den fra sofa Ser ikke for mye TV uansett. Men bare måtte ha en arbeidsskjerm først og fremst, og at den er spillkapabel. Skulle gjerne hatt 12-bit, som dere er inne på dersom det er av betydning. CXen er super. Det er ingen forbruker TVer/monitorer som er 12bit. De fleste monitorer er faktisk 8bit, men lar deg bruker dithering for å få 10bit. 1 Lenke til kommentar
G Skrevet 20. august 2020 Forfatter Del Skrevet 20. august 2020 (endret) For de som er sugen på om denne TV-en er bra. Kom over denne praten rundt firmware 3.10.20 til TV-en. I dag mottok jeg 3.10.44 firmware automatisk uten å vite hva forbedringer den evt. bærer med seg: Obs! video omtaler altså 3.10.20 firmware: Er visst en forumtråd som nevner 3.10.44 her: https://www.avsforum.com/threads/2020-lg-oled-cx-gx-owners-thread-faq-posts-1-6-no-price-talk.3119288/page-459#post-60043727 Endret 20. august 2020 av G Lenke til kommentar
samco Skrevet 3. september 2020 Del Skrevet 3. september 2020 (endret) Synd for PC eiere ... Ikke overrasket lå veldig i spesifikasjonen for 8k 48gbs var det som trengtes. Som sagt kjøpte en C9 rimelig fort tidligere i år da hdmi skandal nyheten kom. Var riktig valg ser jeg nå....? Endret 3. september 2020 av samco 1 Lenke til kommentar
G Skrevet 3. september 2020 Forfatter Del Skrevet 3. september 2020 "Four kind of peoples in the world" Forresten takk for informasjonen. Veldig interessant hvordan produsenter stadig holder litt tilbake på ting. Er dette litt sånn "HD-ready"-greier igjen da? Lenke til kommentar
Nimrad Skrevet 3. september 2020 Del Skrevet 3. september 2020 G skrev (2 minutter siden): Forresten takk for informasjonen. Veldig interessant hvordan produsenter stadig holder litt tilbake på ting. Er dette litt sånn "HD-ready"-greier igjen da? Det har ingenting å si. Panelet på både C9 og CX er 10 bit, så man får ikke utnyttet 12bit uansett. 1 Lenke til kommentar
MrMarbles Skrevet 3. september 2020 Del Skrevet 3. september 2020 Er litt som å snakke til en vegg det her ^^ Lenke til kommentar
