FuglFøniks Skrevet 1. januar 2004 Forfatter Del Skrevet 1. januar 2004 Endelig oppsett fra PSdata, bestiller hvert øyeblikk. Noen innvendinger? Samsung CD-RW 52X / 32X / 52X ATAPI Internal Black Bulk W / Software, SW-252FEB 270.00 270.00 Samsung DVD-ROM 16X / 48X ATAPI Internal Black Bulk, SD-616Q/HPC 250.00 250.00 Samsung Floppy Disk Drive 1.44MB 3.5" AT Internal Black, SFD-321B/LBL1 105.00 105.00 Wd Harddisk 120.0GB IDE 7200RPM UDMA-100 3.5" 8MB, WD1200JB 637.09 637.09 Asus Mainboard Socket-A nForce2 400 ATX Audio LAN Retail, A7N8X-X 545.00 545.00 Aopen Case ATX Tower Black 350W PSU USB 2.0 Silent PSU, H600B 641.29 641.29 Geil 512MB DDR PC3200 400MHz Value CL2,5 5ns Aluminium Heat Spreader 2,5-2,8V, GE5123200B 550.00 550.00 AMD CPU Athlon XP 2500 1.833MHz Socket A 333FSB 640kb Cache 11clk Barton, AXDA2500DKV4D 596.00 596.00 Glacial Cooling Fan Socket-A 19dB For All AMD CPU (Up To XP3000 / All Duron) 24K Gold, SILENT BREEZE 462 II 175.00 175.00 Cooler Fan Case 80x80x25mm 12V Ball Bearing, AF8-25IM-74 2stk TOTALT: 4.835kr. Lenke til kommentar
Same- Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 Endelig oppsett fra PSdata, bestiller hvert øyeblikk. Noen innvendinger? Samsung CD-RW 52X / 32X / 52X ATAPI Internal Black Bulk W / Software, SW-252FEB 270.00 270.00 Samsung DVD-ROM 16X / 48X ATAPI Internal Black Bulk, SD-616Q/HPC 250.00 250.00 Samsung Floppy Disk Drive 1.44MB 3.5" AT Internal Black, SFD-321B/LBL1 105.00 105.00 Wd Harddisk 120.0GB IDE 7200RPM UDMA-100 3.5" 8MB, WD1200JB 637.09 637.09 Asus Mainboard Socket-A nForce2 400 ATX Audio LAN Retail, A7N8X-X 545.00 545.00 Aopen Case ATX Tower Black 350W PSU USB 2.0 Silent PSU, H600B 641.29 641.29 Geil 512MB DDR PC3200 400MHz Value CL2,5 5ns Aluminium Heat Spreader 2,5-2,8V, GE5123200B 550.00 550.00 AMD CPU Athlon XP 2500 1.833MHz Socket A 333FSB 640kb Cache 11clk Barton, AXDA2500DKV4D 596.00 596.00 Glacial Cooling Fan Socket-A 19dB For All AMD CPU (Up To XP3000 / All Duron) 24K Gold, SILENT BREEZE 462 II 175.00 175.00 Cooler Fan Case 80x80x25mm 12V Ball Bearing, AF8-25IM-74 2stk TOTALT: 4.835kr. Det ser veldig bra ut Lenke til kommentar
FuglFøniks Skrevet 1. januar 2004 Forfatter Del Skrevet 1. januar 2004 Velkommen til forumet! Lenke til kommentar
FuglFøniks Skrevet 1. januar 2004 Forfatter Del Skrevet 1. januar 2004 en idè er jo å be komplett etc sette opp et oppsett, men tror nok jeg har mekket et fullverdig et til denne prisen. Noe som mangler, kabler etc? Lenke til kommentar
hn66 Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 Endelig oppsett fra PSdata, bestiller hvert øyeblikk. Noen innvendinger? Samsung CD-RW 52X / 32X / 52X ATAPI Internal Black Bulk W / Software, SW-252FEB 270.00 270.00 Samsung DVD-ROM 16X / 48X ATAPI Internal Black Bulk, SD-616Q/HPC 250.00 250.00 Samsung Floppy Disk Drive 1.44MB 3.5" AT Internal Black, SFD-321B/LBL1 105.00 105.00 Wd Harddisk 120.0GB IDE 7200RPM UDMA-100 3.5" 8MB, WD1200JB 637.09 637.09 Asus Mainboard Socket-A nForce2 400 ATX Audio LAN Retail, A7N8X-X 545.00 545.00 Aopen Case ATX Tower Black 350W PSU USB 2.0 Silent PSU, H600B 641.29 641.29 Geil 512MB DDR PC3200 400MHz Value CL2,5 5ns Aluminium Heat Spreader 2,5-2,8V, GE5123200B 550.00 550.00 AMD CPU Athlon XP 2500 1.833MHz Socket A 333FSB 640kb Cache 11clk Barton, AXDA2500DKV4D 596.00 596.00 Glacial Cooling Fan Socket-A 19dB For All AMD CPU (Up To XP3000 / All Duron) 24K Gold, SILENT BREEZE 462 II 175.00 175.00 Cooler Fan Case 80x80x25mm 12V Ball Bearing, AF8-25IM-74 2stk TOTALT: 4.835kr. Hvordan får du til slike lave priser? Når jeg går inn på PSData, så koster f.eks. DVD-ROMen 291,-. AMD XP2500: 739, Du har oppgitt 596,- Det er vel uten mva i dine priser? Vel, uansett, jeg ville kun kjøpt en kabinettvifte. Den monterer du bak i kabinettet, til å blåse varm luft ut. PSU blåser jo også varm luft ut, det holder for ditt oppsett. Det gir liten effekt å sette en vifte i tilleg i front (ca 30%), da der er mest lønnsom å ha vifter i parallell (i samme unde av et "rør) istedet for i serie. Lenke til kommentar
Star Skrevet 1. januar 2004 Del Skrevet 1. januar 2004 Greit oppsett det der.. Enig i at du ikke trenger mer en 1 kabinett vifte.. Cpu kjøler klarer jo jobben bra selv.. Lenke til kommentar
FuglFøniks Skrevet 2. januar 2004 Forfatter Del Skrevet 2. januar 2004 Total prisen er m/mvh, men ikke stk prisen... Lenke til kommentar
thomas81 Skrevet 2. januar 2004 Del Skrevet 2. januar 2004 husk at en WD støyer like mye som 16stk seagate disker..... jeg ville ikke hatt en wd i "stue-pc'n" om jeg hadde fått n gratis har en i serveren på ett annet rom (for seagate lager ikke så store disker som WD), og den bråker seagate=25dB wd=39dB Lenke til kommentar
Møkkalasset Skrevet 2. januar 2004 Del Skrevet 2. januar 2004 WD bråker no ikkje...... Wd er konge kas kab har du wd hater? Lenke til kommentar
FuglFøniks Skrevet 2. januar 2004 Forfatter Del Skrevet 2. januar 2004 husk at en WD støyer like mye som 16stk seagate disker.....jeg ville ikke hatt en wd i "stue-pc'n" om jeg hadde fått n gratis har en i serveren på ett annet rom (for seagate lager ikke så store disker som WD), og den bråker seagate=25dB wd=39dB Så sant så sant, men det er ikke til meg Lenke til kommentar
Gjest Slettet+9817234daf Skrevet 2. januar 2004 Del Skrevet 2. januar 2004 husk at en WD støyer like mye som 16stk seagate disker.....jeg ville ikke hatt en wd i "stue-pc'n" om jeg hadde fått n gratis har en i serveren på ett annet rom (for seagate lager ikke så store disker som WD), og den bråker seagate=25dB wd=39dB Så sant så sant, men det er ikke til meg Men hvis det er til en kamerat bør du kanskje tenke litt på ham også? Gå for Seagate. Lenke til kommentar
FuglFøniks Skrevet 2. januar 2004 Forfatter Del Skrevet 2. januar 2004 Det er ingen god kamerat... Dessuten er WD raskere og han er nok vant med støy. Han kommer ikke til å bry seg. Merker ikke noe bråk med min raptor. Dessuten har ikke PSDATA Seagate ATA disker Lenke til kommentar
Gjest Slettet+9817234daf Skrevet 2. januar 2004 Del Skrevet 2. januar 2004 Det er ingen god kamerat... Dessuten er WD raskere og han er nok vant med støy.Han kommer ikke til å bry seg. Merker ikke noe bråk med min raptor. Dessuten har ikke PSDATA Seagate ATA disker Da så. Er ytelsen verdt støyen på en WD i forhold til en Seagate? Lenke til kommentar
Møkkalasset Skrevet 2. januar 2004 Del Skrevet 2. januar 2004 Lol ooo bråk av wd det er det ikkje.... Ein kamerat av meg (han er full i peng) har altid hatt wd kjøpte Seagate. Den selte han for den var ræva.... ( Seagate Seagate ibm ibm låter ikkje bra WD der i mot hører bra ut) Lenke til kommentar
FuglFøniks Skrevet 2. januar 2004 Forfatter Del Skrevet 2. januar 2004 Ekke en dritt trøtt, kjeder meg nå as... Lenke til kommentar
tøs Skrevet 2. januar 2004 Del Skrevet 2. januar 2004 Hallo.. Hvis du overholde ikke er kompetent til å bygge en maskin, eller må spørre andre om råd, er det vell ikke å anbefale at du bygger maskinen for din venn? Da kan han vel like gjerne gjøre det selv. Lenke til kommentar
FuglFøniks Skrevet 2. januar 2004 Forfatter Del Skrevet 2. januar 2004 Ehh... Tror du jeg ikke klarer bygge en kasse? Har faktiskt nettopp bygd min første Lenke til kommentar
