Intel 10 serie - OC og erfaringsutveksling
Div programmer og bioser. Triks og tips oppsamlingsplass.
1099966063_CB205600-4700c17-52001.42vbiosllc8.thumb.PNG.1f8af226f17c6a113e812bde373eda87.PNG
MSI z490 Bioser. XOC og offisielle: https://community.hwbot.org/topic/197141-msi-z490-xoc-biostools/?tab=comments
Asus z490 bioser
XOC https://community.hwbot.org/topic/196740-rog-maximus-xii-apex/
Offisielle: https://rog.asus.com/forum/showthread.php?118328-Asus-Z490-stuff
Få flere sensorer i Aida64
Quote
You need to enable Embedded Controller (EC) bank switching too:
We've implemented Asus EC bank switching in the latest AIDA64 beta build:
https://www.aida64.com/downloads/latesta64xebeta
You need to enable both Embedded Controller (EC) support and Embedded Controller (EC) bank switching in AIDA64 / main menu / File / Preferences / Stability. That will unlock a few additional sensor readings on your motherboard. Make sure to not have Asus AI Suite or any of its background services installed on your system. If you have any of those left around, a collision may occur while AIDA64 tries to perform EC bank switching, and it may just cause a system lockup or sudden system restart.
Memtest: https://mega.nz/file/AQ1TUShK#Z0BssAZyMEfN6rfJBueUrhlKtc9NXHJsrR4Rzp_txgE
Info om TXP setting (3. timing)
TurboV_Core_1.05.06.7z
https://mega.nz/file/3CBDSILC#luAYpy5EUTPChYh31HuIh0cH8D1TcloVObF1benMFok
0097 bios
Formula bios: https://www.dropbox.com/s/zt6v5pphpt7oof7/ROG-MAXIMUS-XII-FORMULA-ASUS-0097.7z?dl=0
Formula extreme bios: https://www.dropbox.com/s/7pcnp0ttcfzkoxs/ROG-MAXIMUS-XII-EXTREME-ASUS-0097.7z?dl=0
0804  apex xii
https://www.diskusjon.no/applications/core/interface/file/attachment.php?id=637534
OC Pack:
VRM tool - run exe on boot.
New tool that might help push a bit more on the cpu side / run same freq with a bit less volts (15~mv less):
https://www.dropbox.com/s/hkoydak1vm0zgpb/vrm2.zip?dl=0
TurboV:
https://www.dropbox.com/s/wzyzlf9cjn...10.07.zip?dl=0
Mem TweakIt:
https://www.dropbox.com/s/s7azeckt1f2s4yt/Mem TweakIt-V2.02.46.7z?dl=0
0804-no-ucode.rar Apex z490 bios
Bruk ratio Tool under oppstart for å få "ratio" til å fungere.
Ratio Tool (thanks to @elmor for the tool -> use ratio_tool_cml.exe for ratios -> patch_cml_ifnoucode.exe if using a bios without ucode to get it patched/fixed) :
https://www.dropbox.com/s/7kf6wqwtyu3erqj/Tool.zip?dl=0
Endret av Nizzen
Nizzen skrev (16 timer siden):
10900k @5300mhz 4600c18 tweaked 2080ti
VS
10900k @5300mhz 4000c15 xmp 2080ti
Godt levert ?
Har hele tiden vært klar over at Intel er det beste når det kommer til gaming. For å sammenligne litt med AMD har jeg kjørt noen tester med 3900X. Med litt forskjellig minne. CPU kjører undervolt med 0.1V, ikke at det gjør så mye akkurat for kjørte uten undervolt også og det var ikke mye til forskjell. Her er det kun forskjell på minnehastigheten med andre ord. Max jeg kjørte er selvfølgelig ett godt stykke under ditt resultat. Gpu kjører stock. Det jeg bryr meg mest om er hva minimum fps havner på.
Samme innstillinger som du testet:
Spoiler
Ripjaws ren XMP profil 3600 16-16-16
Kjørte også en test med en 3600 16-16-16 med en mild profil fra Ryzen dram kalkulator og fikk da minimum fps opp til 98-99. Her viser jeg ikke noe bilde, tok heller ingen så får bare ta meg på ordet uten bevis :)
Spoiler
Ripjaws 3733 14-16-14
Ja, så her ser en fint at Intel er ett godt stykke foran. Ikke det at jeg synes en min fps på 113 er så lite heller. Men spiller jo nesten ikke like vel men tenkte jeg kunne kjøre ett AMD (mitt) oppsett til sammenlignings grunnlag, selv om det ikke kommer meg til gode :) Ingen problemer med å snakke ned AMD selv om det er det jeg sitter på selv ?
Endret av FranZe
  Hide contents
  Reveal hidden contents
Godt levert ?
Takk for bidraget ditt :)
42 minutes ago, FranZe said:
Bare morosamt :)
Forskjellen fra stock 3900X med litt dårlig minne til overklokka 10900k med kjempe bra minne er egentlig ganske så stor. Når det begynner å bli bortimot 60 fps som skiller på minimum fps'en så snakker man.
Bare ikkje nevn det i Ryzen tråden, fordi da blir du anklaget for å trolle :p
Ok. Om ikke for andre grunner enn at jeg akkurat innstallerte Shadow of the Tomb Raider, og for å hekte på ytterligere et AMD-resultat OC'erne i denne tråden kan ha det moro med.
Med 1080Ti riktignok. 3900X stock. FCLK 1900. TridentZ@3800 16-17-16-32 osv. (Ryzen calc-basert med egne etterjusteringer).
Ingen grunn til å snakke ned AMD. Forskjellig bruksområder og personlige preferenser gjør den store forskellen. Forholdsmessig bruk av cpu mellom gaming og arbeid eller annet.
20/80 eller 90/10? Kr pr. ytelse til det man faktisk bruker pcen til?
You choose.
Endret av Extantitus
feilfiks 2. ooops Fclk 1900 selvfølgelig
