Slik unlocker du multiplier på en Barton CPU
Leffa01
har de lest guiden?
The PowerNow! Support will depend if your board supports or not FID_Command changing, if it doesn't, most nForce 2 don't seem to work, you shall need to edit registers with WPCREDIT.
If your mod with nForce2 is successful please post it in the forum a picture of your nForce2 PCR configuration, so a solution can be found for all nForce2.
står det på ei sida...
