Hvor gammelt er zoomobjektivet
Vi er en gjeng ivrige foto/videoentusiaster.
Det vi lurer på er når zoomobjektivet så dagens lys, dvs når ble det oppfunnet og når ble det tilgjengelig for folk flest. Dette ble også tidligere kalt gummilinse.
Vi har Googlet og Googlet men har ikke funnet svar på dette.
Er det noen som vet ??
Sakset fra Wikipedia:
Spoiler
History
Early forms of zoom lenses were used in optical telescopes to provide continuous variation of the magnification of the image, and this was first reported in the proceedings of the Royal Society in 1834. Early patents for telephoto lenses also included movable lens elements which could be adjusted to change the overall focal length of the lens. Lenses of this kind are now called varifocal lenses, since when the focal length is changed, the position of the focal plane also moves, requiring refocusing of the lens after each change.
The first true zoom lens, which retained near-sharp focus while the effective focal length of the lens assembly was changed, was patented in 1902 by Clile C. Allen (U.S. Patent 696,788). An early use of the zoom lens in cinema can be seen in the opening shot of the movie "It" starring Clara Bow, from 1927.
The first industrial production was the Bell and Howell Cooke "Varo" 40–120 mm lens for 35mm movie cameras introduced in 1932. The most impressive early TV Zoom lens was the VAROTAL III, from Rank Taylor Hobson from UK built in 1953. The Kilfitt 36–82 mm/2.8 Zoomar introduced in 1959 was the first varifocal lens in regular production for still 35mm photography.[7]
The first modern film zoom lens, the Pan-Cinor, was designed around 1950 by Roger Cuvillier, a French engineer working for SOM-Berthiot. It had an optical compensation zoom system. In 1956, Pierre Angénieux introduced the mechanical compensation system, enabling precise focus while zooming, in his 17-68mm lens for 16mm released in 1958. The same year a prototype of the 35mm version of the Angénieux 4x zoom, the 35-140mm was first used by cinematographer Roger Fellous for the production of Julie La Rousse. Angénieux received a 1964 technical award from the academy of motion pictures for the design of the 10 to 1 zoom lenses, including the 12-120mm for 16mm film cameras and the 25-250mm for 35mm film cameras.
Since then advances in optical design, particularly the use of computers for optical ray tracing, has made the design and construction of zoom lenses much easier, and they are now used widely in professional and amateur photography.
Kilde: https://en.wikipedia.org/wiki/Zoom_lens
Endret av xRun
Formattering
