Escobar Fold 2
Noen som har erfaringer med denne? Eller vurderer å teste ut?
Foldbar telefon til 399 USD. Har mine tvil, men hadde vært gøy å testet den.
https://www.escobarinc.com/product/fold2/
  • Device Type– Android 10 Foldable Smartphone
  • CPU– Octa-Core 2.84GHz Clock Speed
  • Chipset– Qualcomm Snapdragon 8 Series, 855, 64-bit ARM LTE Processor
  • GPU– Qualcomm Adreno 640
  • Main Camera– (1) 12 MP, f/1.5-2.4, 27mm (wide), 1/2.55″, 1.4µm, Dual Pixel PDAF, OIS, (2) 12 MP, f/2.4, 52mm (telephoto), 1/3.6″, 1.0µm, AF, OIS, 2x optical zoom and (3) 16 MP, f/2.2, 12mm (ultrawide), 1/3.1″, 1.0µm LED flash, HDR, panorama
    • Video: 2160p@60fps, 1080p@60/240fps (gyro-EIS), 720p@960fps (gyro-EIS), HDR10
  • Selfie Camera– (1) 10 MP, f/2.2, 26mm (wide), 1/3″, 1.22µm and (2) 8 MP, f/1.9, 24mm (wide), 1.22µm, depth sensor HDR.
    • Video: 2160p@30fps, 1080p@30fps, gyro-EIS
  • Memory– RAM- 8GB/12GB LPDDR4X | ROM 128GB/512GB
  • Display (Main) – Foldable Dynamic AMOLED capacitive touchscreen, 16M colors, 7.3 inches, 162.6 cm2 (~85.7% screen-to-body ratio), 1536 x 2152 pixels (~362 ppi density), HDR10+
  • Display (Two)–  6″, Super AMOLED, 720 x 1680 pixels (21:9)
  • Battery– Non-Removable 4,380 mAh Lithium-Polymer, 5V/5A
  • SIM– Nano-SIM, eSIM
  • Sensors– Fingerprint (side-mounted), accelerometer, gyro, proximity, compass, barometer
  • Color– Black and Gold
  • Operating System– Android 10.0
  • I/O Interface– 1 x Nano SIM Card Slot, Type-C USB Port, Type-C to 3.5mm Audio Out Port, Power Button, Volume Button, Microphone
  • Dimensions– Unfolded: 160.9 x 117.9 x 6.9 mm, Folded: 160.9 x 62.9 x 15.5 mm
  • Weight– 266 Grams (with Battery)
  • Variant – 8GB/128GB, 12GB/512GB
More Features – Foldable AMOLED Screen, Protection, LTE Cat-18, Fingerprint Scanner, Triple Camera, Big Size Screen, HD Sound, USB Type-C, Loudspeaker, BDS, Bluetooth 5.0, Dual-Band Wi-Fi, 4:3 Ratio, Fast Charger, Noise Cancellation, Document Editor, 5V/5A Charger Output Power, VoLTE Support
Endret av sir-alex
Det er nok stor sannsynlighet for at Escobar-mobilen er svindel så jeg ville personlig skygget unna. Det er lenker til flere artikler om nettopp det i beskrivelsen til Youtube-videoen du lenker til:
https://www.notebookcheck.net/Pablo-Escobar-s-brother-announces-the-Escobar-Fold-2-amid-claims-that-Escobar-Inc-is-scamming-buyers-of-the-Fold-1.452941.0.html
https://bgr.com/2020/02/04/pablo-escobar-fold-2-dont-buy-galaxy-fold-clone/
Videoen ser ut som en ekte Galaxy Fold med et Escobar-brandet skin på baksiden, tviler på at det er noe annet enn et PR-stunt å sende til vedkommende som så lager videoer, noe som igjen genererer flere bestillinger. Han som legger ut videoene tar jo forbehold i kommentarfeltet og i video-beskrivelsen for at det er ingen garanti at du får mobilen du bestiller eller en tilsynelatende velfungerende en slik han mottok. Så jeg ville vært forsiktig men selvfølgelig kjekt om jeg tar feil. Selv om jeg tviler på det :)
