Spørsmål om koronaviruset? Still spørsmål her ×
Coronaviruset i verden: Nyheter og diskusjon
Gjest Slettet-404071
helsten2 skrev (13 minutter siden):
Noe å tenke på ?
eller, slå sammen Norge og Sverige til en sone, og ha grensekontroll mot kontinentet.
for dette kommer ikke til å gå over med det første.
Over ganske kort tid, vil statistikken nok utligne seg mellom N og S
Europas CDC (ECDC) anbefaler i dag alle land i EU som ser en økning i smittetilfeller om å gradvis gjeninnføre tiltakene som tidligere i var bruk.
Sitat
Further increases in the incidence of COVID-19, and associated hospitalisations and deaths, can be mitigated if sufficient control measures are reinstalled or reinforced in a timely manner.
Countries that are now observing an increase in cases, after having lifted their control measures following a temporary improvement in the epidemiological situation, should consider re-instating selected measures through a phased, step-wise and sustainable approach.
Assessment of risk at local level is important, taking into consideration the epidemiological situation, local services and lessons learned regarding the impact of previous measures.
Member States implementing comprehensive testing are better able to rapidly detect an increase in cases and identify groups at high risk of disease. Alongside a tailored local testing strategy, the speed of contact tracing is important to reduce transmission, and efforts should be made to shorten the time needed for each step in the testing, notification, and contact tracing process.
Given that there are now dedicated COVID-19 surveillance systems, extensive public health measures in place, and ongoing testing and contact tracing of the population, countries should be better prepared to prevent and control any resurgence in cases.
https://www.ecdc.europa.eu/en/publications-data/rapid-risk-assessment-coronavirus-disease-2019-covid-19-eueea-and-uk-eleventh
Pressemeldingen kommer ironisk nok fra ECDCs hovedkontor .... i Stockholm !
  • Innsiktsfullt 1
0laf skrev (2 minutter siden):
Det nytter vel ikke så lenge Sverige har Dr. Tengele og en totalt fraværende sveiser (statsministeren) !
dem er nok bedre enn sitt rykte :grin2:
farbror Anders har blitt et yndet mobbe-objekt.
siste ord er nok ikke sagt om "regnskapet"
Etter tidligere fadeser med svensker i Hellas, innfører grekerne nå krav til negativ test før innreise fra flere land.
Sitat
Visitors to Greece arriving from Sweden, Belgium, Spain, the Netherlands and the Czech Republic will need proof they have tested negative for the novel coronavirus to gain entry, the government said on Monday.
Tightening controls after a recent spike in COVID-19 infections, the government said the requirement will go into effect from August 17. The required test cannot be older than 72 hours prior to entry.
https://www.reuters.com/article/us-health-coronavirus-greece/greece-to-require-negative-coronavirus-test-for-entry-from-sweden-spain-belgium-idUSKCN2561T0
EU advarer igjen mot grensekontroller igjen ...
Sitat
In a letter to national governments, seen by The Associated Press, the European Commission warns that “while we must ensure that the EU is ready for possible resurgences of COVID-19 cases ... we should at the same time avoid a second wave of uncoordinated actions at the internal borders of the EU.”
“The re-establishment of ineffective restrictions and internal border controls must be avoided. Rather, the response should be to have targeted, proportionate and coordinated measures, informed by scientific evidence,” said the letter, sent to the 27 EU member countries and Britain.
Scandinavian nations are notably quick to react to any rise in infection rates. Denmark’s foreign ministry now has Spain, Bulgaria, Luxembourg, Romania and Andorra on its so-called red list. Norway, which is not an EU member but is part of the Schengen area, has not hesitated either.
“Unfortunately, developments in several European countries are not moving in the right direction,” Norwegian Foreign Minister Ine Eriksen Soereide said. She says that people arriving from France, Monaco, Switzerland and the Czech Republic must now self-quarantine for 10 days.
https://apnews.com/57d90962c17cb1834341e0573241096e
Endret av 0laf
Sitat
FHI med ny anbefaling om røde land:
Det har den siste tiden vært økt coronasmitte i Polen, Malta, Island, Kypros og Nederland. FHI anbefaler derfor at disse landene blir «røde» når bestemmelsene for innreisekarantene skal oppdateres denne uken - hvis det ikke skjer endringer.
Samtidig betegnes også Færøyene, seks regioner i Sverige og to regioner i Danmark som røde
0laf skrev (14 minutter siden):
Smaken er som baken, de snart 6000 døde svenskene og deres pårørende er nok uenige.
samme "billige retorikk" kan man ytre om døde/pårørende i Belgia, Nederland, Spania, etc.
Men, vi var heldige og har mye penger, vi får se om det kan redde oss hele veien frem, eller om vi må jekke oss ned noen hakk når sluttregnskapet gjøres opp.
Da er fadderuken i gang og skolene starter om en uke! Vi går noen uhyre nervepirrende uker i møte.
Foreløpig tall frå FHI viser at det var 311 smittetilfeller i forrige uke. Det var 199 tilfeller uken før, altså en oppgang på over 100 tilfeller. Sist det var over 300 tilfeller var i uken 27.april- 3.mai.
Når jeg ser på de tilsvarende tallene fra april/mai ser det ut som at ca. 300 tilfeller førte til rundt 15 sykehysinnleggelser på en uke. Vi får se om dette stemmer med nåværende tall.
Gjest b6487...931
Har observert rimelig store gjenger med studenter her i Bergen. Og også store gjenger med faddere. Så om meningen er å ha mindre kohorter som gjennomfører uka sammen bør nok noen minne fadderne på at de ikke bør henge sammen...
Anonymous poster hash: b6487...931
asdaylightdies skrev (12 minutter siden):
Bryt ned den lokale smitten og gradvis åpne opp igjen til andre land om 5 måneder.
hva er annerledes om 5 måneder?
blir det ikke bare samme sirkuset om igjen da?
og gangen etter der igjen osv.
eller tenker du på at vaksinen skal redde oss? Det blir sånn sett spennende å se hvor mange som egentlig kommer til å ta den (utover innlagte på gamlehjem, institusjoner, og risiko-utsatte)
https://www.dagbladet.no/kultur/vi-kan-matte-betale-dyrt/72719406
Linken er en som kommer med et surt oppstøt mot at det er gjester på hotellene som tar seg mat i kantina, osv.
"Myndighetene burde lytte spesielt nøye til de faglige rådene, framfor å gi etter for økonomiske særinteresser."
Sier han. Men syns han det er noe bedre hvis disse hotellene slutter å eksistere? En lockdown nummer to og tre, vil sikkert gi større nerveproblemer hos folk enn den første. Som kan føre til andre typer dødsfall enn korona.
Budeia skrev (10 minutter siden):
Akkurat det med buffet er et (godt) poeng. Jeg bodde noen netter på hotell i sommer, og minst halvparten av gjestene ga jo fullstendig beng i alt som het koronavirus. Stimle seg sammen rundt frokostbuffeten, alle klår på alt og halvparten bruker håndspriten. Så sitter vi tett i spisesalen der noen hoster, andre nyser og atter andre harker opp egget som satt seg i vrangstrupen..
Ferdigpakket frokost levert på døra, det hadde ikke vært så dumt altså. Det finnes en mellomting mellom fullt frislipp og stengt dør.
Endret av :utakt
Budeia skrev (9 minutter siden):
lett for han å si. trygg og god jobb lønnet av staten.
og bekymrer seg sikkert ikke nevneverdig om 200.000 evt. må gå på trygd på ubestemt tid. Staten betaler.
Mr.M skrev (42 minutter siden):
Håper på at kurven har flatet ut på en skikkelig måte. Tosifret antall smittende i store europeiske land daglig. Mindre land som Norge null smittende på flere uker. Da tror jeg vi kan forsiktig åpne opp igjen.
Vaksine og effektive behandlinger er bonuser hvis de kommer.
Endret av asdaylightdies
Mr.M skrev (Akkurat nå):
Hr M. Nå skal du ikke fortvile. Service yrkene blir lett bemannet opp igjen når det gjelder ufaglærte. Sånn er det bare. Oljearbeiderne kan få nye jobber i nye og mindre 'anleggs betonte' yrker. Oljeeventyret er over i Norge. Det må vi bare innse. Nordmenn har et fantastisk land og gode forutsetninger for å komme seg fra dette med mye av arbeidsstokken inntakt. Jeg må finne på noe nytt og det må nok en hel haug med andre folk også gjøre. Ungdommen må få trangere kår da de har hatt et forbruk som er hinsides all fornuft i flere årtier.  Den eldre generasjonen må på sin side ta mye av tapene som kommer nå. Men det er en grense for hva vi alene skal ofre. Pengefolkene må gjøre sitt. Det vil de stritte imot med nebb og klør, men hvis vi ikke tar et oppgjør med gryende korrupsjon og generellt pengebruk her til lands kommer det til å nedenom og hjem og det fort. Hvis dere har følgt med så er Trond Giske på vei inn i varmen igjen. Han står for en slagkraftig politikk som flere av hans kvinnelige motstandere ikke gjør. Og de har sett skrifta på veggen og forlatt skuta. Lure på hva Torbjørn Berntsen hadde sagt om situasjoen. Han hadde gitt 'vingle' Raymond det glatte lag er jeg redd. Vel. Jeg skal avstå fra å si mer om noe som er off topic, men gamle ord og uttrykk som solidaritet og ansvar er vel verd å huske betydningen av.
