NVIDIA GeForce RTX 30xx tråden
Nizzen
Melding lagt til av Jarmo
Vennligst ikke ta AMD vs. Intel diskusjoner i denne tråden :)
BadCat skrev (På 31.1.2021 den 5.40):
Der har du årsaken. Corsair er kjent for å slippe modell etter modell med coil whine. Jeg kastet ut mine i 2012, aldri hatt whine etter det.
Han snakker om at skjermkortet har coil whine.
Dessuten er RM(tall)x serien til Corsair anti coil whine serien deres.. Og han kan lett få erstatning på det om det er tilfellet. Men jeg kan satse penger på at det ikke er noe relevant.
  • Liker 3
Spoiler
Quote
Corsair CW Series Power Supplies
If Corsair continues to release power supplies with Coil Whine, will they eventually put them under the CW "Coil Whine" Series Line, much like the other lines they have eg AX/RM/HX/CX. Maybe we can have some input from Corsairs Director of Marketing (George Makris)?
Quote
Corsair Power Supplies Notorious for Coil Whine!
I was wondering why Corsair keep releasing Power Supplies with Coil Whine?, If you check Amazon Reviews especially for the RM Series they are Notorious for Coil Whine!
https://www.amazon.co.uk/Corsair-CP-...yStar=critical
The Video below is exactly what the coil whine sounds like from the Corsair RM1000i, even above their stock loud intel cpu cooler it is very much noticeable! (My System Fans Run at Low RPM making the Coil Whine even more Noticeable)
https://www.amazon.co.uk/gp/customer...SIN=B00YPQLRNO
Do you think it's acceptable that I should have to hear your power supply whining/buzzing/chirping over my Graphics Card/CPU/Case fans and Speakers while gaming at night? Can you ask your Power Supply Guru "Jon Gerow" to comment on this and also ask him if he can hear the Coil whine in the Video from the First Link?
What is Corsair doing to rectify these Coil Whine Series Power Supplies, are they even taking this Coil Whine issue seriously? (Considering you keep releasing Coil Whine Power Supplies) and how would one replace a Coil Whine Series Power Supply with one that does not Whine?, are you testing replacements being sent out for Coil Whine (Do you even have anyone who can?) ? or do we just have to keep testing and returning them till we get a Whine free one, if so how will you compensate us for our time?
Quote
How Corsair Does not Fight Coil Whine (At Least not in Europe)
https://www.corsair.com/ww/ru/blog/coil-whine
This article above was written by Corsair Power Supply Guru "Jon Gerow", with respect some say because of his Age he cannot detect Coil Whine, it is a fact people over a certain age cannot detect it, Jon Gerow himself mentions it "these noises can be at such a high frequency that only some people are actually able to hear them. Many people, especially those over 25 years of age, cannot hear noises over 15kHz" in the article, yet he is your power supply guru but may not be able to detect something (coil whine) he wrote an article about!
So is this the reason why you keep releasing these "Coil Whine" Series Power Supplies, because you may not have the employees in your Technical/Test/Design/Quality Control department who are under the age needed to detect it?
Jeg har gjentatte ganger fått grafikkort fra NVIDIA helt tyst ved å hive ut PSU fra Corsair. Det er ikke noe som har skjedd én gang.
BadCat skrev (På 1.2.2021 den 10.28):
  Vis skjult innhold
Men det er som sagt ikke CW serien det er snakk om........ Nesten alle PSU produsenter har coil whine hvis man kjøper den billigste typen de selger (dersom de også selger til det segmentet).
Endret av Dudeliduu
Opplever en sjelden gang mens jeg spiller at skjermen blir helt svart i ca. 2 sekunder (spillet fortsetter i bakgrunnen) før alt kommer tilbake igjen som om ingenting hendte, men er usikker på hva det kan være. Kanskje 750W PSU er i minste laget med mine komponenter: 5900X og RTX 3090 (som er kjent for høye power spikes)? Eller kanskje det er derfor GPUen var et demokort? Klarer fint å leve med det siden det skjer kanskje en gang i løpet av flere timer med spilling, men skulle også gjerne funnet ut hva det var.
TemporalFracture skrev (Akkurat nå):
hdmi?
8 minutes ago, KriZZ said:
hdmi?
Kanskje. Det minner litt om det (edit: men det er fremdeles lyd), men det er vanskelig å forklare hvorfor det skulle skje så sjeldent uten at man er borti kabelen. Den er 2.1 og det virker som den takler bandwidth (ingen chroma subsampling, Forum VRR, 1440p@120hz/4K@60hz, HDR, etc).
Kanskje det blir for varmt av og til der den er koblet til GPUen? :laugh:
Endret av TemporalFracture
TemporalFracture skrev (3 minutter siden):
Prøv en annen kabel.
Har du info om den du bruker nå?
Kanskje. Det minner litt om det, men det er vanskelig å forklare hvorfor det skulle skje så sjeldent uten at man er borti kabelen.
Strømforsyning er en dårligere forklaring, ettersom det ikke er noen form for kommunikasjon mellom strømforsyning og skjermkort.
Alle gode strømforsyninger i dag har overstrømsvern, som kutter strømmen om det oppdages et noe trekker for mye strøm. Når dette slår inn skrur maskinen seg av, fullstendig.
Nå kan også strømforsyninger levere mer strøm enn spesifisert før beskyttelsen slår inn, men selv da skal det mye til før skjermsignalet ikke fungerer lengre.
Tror det er denne:
https://www.multicom.no/vivolink-pro-hdmi-kabel-3-m/cat-p/c/p1000665577
Kjøpte min i 2013. :closedeyes:
https://www.dustinhome.no/product/5010752536/corsair-rm-series-750w-gold-modular-psu
Edit: Ser nå at den har overstrømvern.
9 minutes ago, Mumriken said:
LG c9 tilfeldigvis? Såfall helt vanlig og du må vente på en firmware update
Jupp. Så det er LGen altså? Er på 05.00.10 nå.
TemporalFracture skrev (2 minutter siden):
Nei det er ikke LGen, jeg har LG C9 og 3090 selv.
Jeg hadde samme problem og bytta kabel, aldri skjedd siden.
