NVIDIA GeForce RTX 30xx tråden
Nizzen
Melding lagt til av Jarmo
Vennligst ikke ta AMD vs. Intel diskusjoner i denne tråden :)
4 minutes ago, N o r e n g said:
Optane har vel ikke akkurat veldig høy sekvensiell ytelse? Microsoft snakker om å hente ut flere filer på 64KB og opp, det er vel bortimot ideelt for en typisk SSD?
Optane har ikkje veldig høy, men 2.7GB/s lesehastighet er ikkje veldig treigt med en latterlig lav latency. Som regel vinner den over det meste på sekvensiell les av flere filer grunnet dette, selv om andre har mye høyere sekvensiell lesehastighet på papiret.
Optane gjør at hastigheten er HELT stabil, og ikkje yoyo som vanlige ssder kan gi.
Endret av Nizzen
LOL
Quote
Report: NVIDIA GeForce RTX 30 GPUS To Be In Short Supply Until 2021
One of the primary reasons that NVIDIA decided to go with the Samsung 8nm process was because the company would allow them to overcome the capacity constraints inherent in buying from TSMC. Unfortunately for gamers, however, Anthony over at Tweak Town is reporting that stock is going to be scarce until the end of the year and if you want in on the Ampere GPU craze before then, you better preorder.
The reason that Anthony's sources gave was that NVIDIA is unsure of the maximum yield of Samsung's process and considering the clear performance advantage they have over basically everything, they want to (voluntarily) reduce the numbers of wafers produced till yield can be maximized at Samsung's end. This is a very sensible business decision but could ultimately end up jacking up prices for the RTX 30 series way above the MSRP as people pre-order the limited supply and then resell at much higher rates to indulge in some profit-taking.
Quote
It is unlikely that AMD's big Navi will be able to go toe to toe with this level of performance enhancement and I am sure NVIDIA has SKUs up its sleeve that they will roll out as soon as AMD's big Navi launches.
https://wccftech.com/report-nvidia-geforce-rtx-30-gpus-to-be-in-short-supply-until-2021/
Mer kjølevann i gamer-blodårene:
Quote
My fear is that repeat is what we get, RDNA cards sell out to miners and the second RDNA2 cards are available BAM, gone too. But again, they're not going to gamers. It's good for AMD and Radeon's initial sales numbers but not to their long term brand penetration. But Keith, what about the RTX 20 Series won't this have the same effect on them? Not to the same degree, the RTX 20 Series are still not on the level of mining Ethereum as the RDNA cards, they're clearly gaming cards first. From what I could find you're going to need a 2080 Super or so to match the 5700 Series in ETH efficiency and hash rates, but that's going to cost you upwards of double. Although the recent RTX 20 Series push on the second-hand market may find themselves in a good position over new RDNA cards.
https://wccftech.com/ethereum-gpu-mining-profitability-puts-eyes-on-radeon-rx-5700-series/
Endret av G
kjetilkl skrev (7 timer siden):
Er egentlig i samme situasjon selv, men sitter med 4770K og har ventet på intel 10nm et års tid nå, så må nok gjøre en midlertidig oppgradering - men synes det er lite tilgjengelig til ok pris brukt.
Kjøp en billig oppgraderingspakke med Ryzen og et B550 kort som ventepølse!
Mala skrev (1 time siden):
Fikk 3500 ,- for mitt Asus 1080 TI, nøgd med det :) Skal rocke Asus 980 TI og CRT-monitor den nesten tiden ?
Tror ikke man kan forvente noe særlig mer for et 1080Ti nå, er godt fornøyd med 6000 for begge korta selv. Glad jeg hoppa over 2080 serien, den frista aldri for min del mtp ytelse/pris.
Blir det 3080 på deg også?
Tviler på at PCIe 4.0 har mye å si for ytelsen.
På prestentasjonen, og på nVidia sine egne nettsider står det at alle tall og «benchmarks» på 3070/3080/3090 er kjørt på oppsett med i9 10900k.
Tror ikke Jensen hadde valgt intel om AMD og PCIe 4.0 hadde gitt mer ytelse.
Jeg tror mange i Ryzen leiren vil få en real overraskelse når benchmarks kommer, men de har vel en eller annen unnskyldning eller bortforklaring da også.
7 minutes ago, Nizzen said:
Tipper den kommer med Rocketlake eller.no
Du vet vel at ytelse på ssd ikkje bare er sekvensiell ytelse? ?
Vil nesten anta at den gjør det ja ?
Jepp, har skjønt hva de gjør med optane, hadde forøvrig vært kult om de samarbeidet med nvidia og fikk til noe der teknologiene samarbeidet
Simkin skrev (13 minutter siden):
Følte meg i grunn heldig som fikk såpass. Hadde vi fått fingen ut for noen uker siden kunne vi vel ha gjort det litt bedre ? ?
2080 kortene var jo en spøk, og hadde null for seg for min del. Her blir det 3080 ja :)
