Samsung Galaxy S20/S20 Plus/S20 Ultra
nor50
S20 Ultra blir nok fristende. Hvordan blir det her i Europa tro? Var det ikke rykter om Snapdragon ei stund, men ser ut til at det ikke blir det her allikevel.
https://www.gsmarena.com/samsung_galaxy_s20_ultra_5g-10040.php
Unofficial preliminary specifications
Network Technology GSM / CDMA / HSPA / EVDO / LTE / 5G
Launch Announced Exp. announcement 2020, February
Status Rumored. Exp. announcement 2020, April
Body Dimensions 167 x 76 x 8.8 mm (6.57 x 2.99 x 0.35 in)
Weight 221 g (7.80 oz)
Build Glass front (Gorilla Glass 6), glass back (Gorilla Glass 6), aluminum frame
SIM Single SIM (Nano-SIM) or Dual SIM (Nano-SIM, dual stand-by)
  Samsung Pay (Visa, MasterCard certified)
IP68 dust/water resistant (up to 1.5m for 30 mins)
Display Type Dynamic AMOLED capacitive touchscreen, 16M colors
Size 6.9 inches, 114.9 cm2 (~90.6% screen-to-body ratio)
Resolution 1440 x 3200 pixels, 20:9 ratio (~509 ppi density)
Protection Corning Gorilla Glass 6
  HDR10+
Always-on display
120Hz
Platform OS Android 10.0; One UI 2
Chipset Exynos 990 - Global
Qualcomm Snapdragon 865 - USA
CPU Octa-core
Memory Card slot microSD, up to 1 TB
Internal 128GB 12GB RAM, 512GB 16GB RAM
Main Camera Quad 108 MP, (wide), Dual Pixel PDAF, OIS
48 MP, (telephoto), 1/2", 0.8µm, PDAF, OIS, 10x optical zoom
12 MP, (ultrawide), AF, Super Steady video
TOF 3D camera
Features LED flash, auto-HDR, panorama
Video 3240p@30fps, 2160p@30/60fps, 1080p@30/60/240fps, 720p@960fps, HDR10+, dual-video rec., stereo sound rec., gyro-EIS & OIS
Selfie camera Dual 40 MP, Dual Pixel PDAF
Features Dual video call, Auto-HDR
Video 2160p@30/60fps, 1080p@30fps
Sound Loudspeaker Yes, with stereo speakers
3.5mm jack No
  32-bit/384kHz audio
Active noise cancellation with dedicated mic
Dolby Atmos sound
Tuned by AKG
Comms WLAN Wi-Fi 802.11 a/b/g/n/ac/ax, dual-band, Wi-Fi Direct, hotspot
Bluetooth 5.0, A2DP, LE, aptX
GPS Yes, with A-GPS, GLONASS, BDS, GALILEO
NFC Yes
Radio FM radio (USA & Canada only)
USB 3.1, Type-C 1.0 reversible connector
Features Sensors Fingerprint (under display, ultrasonic), accelerometer, gyro, proximity, compass, barometer
  ANT+
Bixby natural language commands and dictation
Samsung DeX (desktop experience support)
Battery   Non-removable Li-Po 5000 mAh battery
Charging Fast battery charging 45W: 100% in 74 min
USB Power Delivery 3.0
Fast Qi/PMA wireless charging 15W
Power bank/Reverse wireless charging 9W
Misc Colors Black; other colors
First hands-on images of the Samsung Galaxy S20+ leak [Gallery]
s20-leaks.jpg?quality=82&strip=all&w=1600
The first hands-on images of the upcoming Samsung Galaxy S20+ have leaked giving us a glimpse of the design we expected to see at the Unpacked launch event on February 11, 2020.
We have been given these first close-up glances of the upcoming flagship courtesy of XDA-Developers Samsung maestro Max Weinbach as we inch ever closer to the launch event. A trio of Samsung Galaxy S20 devices are expected, with this being the S20+ model that as per the splash loading screen appears to include 5G connectivity.
Previous CAD-based renders hinted at the rear domino camera array. Unlike the disorganised design first hinted at, the quad-camera setup has a more uniform and aligned layout.
The camera setup isn’t expected to have the highest end specs this time around. Instead, the “Galaxy S20 Ultra” will be the highest-end model but the S20+ is expected to include a brand new 12-megapixel 1.8μm main image sensor. We’ll also see an ultra-wide-angle and telephoto zoom lens.
The leaked Samsung Galaxy S20+ images appear to lack the dedicated Bixby button — which had been rumored for some time prior to these new leaks. The display retains the central punch-hole notch that was first tweaked on the Galaxy Note 10 lineup. However, the bezels appear to have shrunk yet again, with barely any forehead and chin of note.
XDA notes that Samsung has opted to use 2.5D glass rather than the usual curved glass on the Galaxy S20 line this time around. That means that the S20+ has less pronounced curves at either side of the display.
While these leaked hands-on images of the Samsung Galaxy S20+ don’t confirm the internals, the 5G splash screen does semi-confirm the inclusion of the Snapdragon 865 chipset — at least on the North American variant. It’s unclear if we’ll see the 5G version launching globally or not. Although, outside the US, the Galaxy S20 series is expected to come with Samsung’s own Exynos 990 chipset.
We’ll have four versions of the S20 to choose from this time around, as there will be the 4G Galaxy S20, 5G Galaxy S20, 4G Galaxy S20+, and 5G Galaxy S20+. That should be more than enough choice for just about anyone interested in the next Galaxy device.
Let us know what you think of the upcoming Samsung Galaxy S20+ and these leaked images down in the comments section below.
Endret av nor50
Legger bare inn og oppdaterer linker som omhandler mobilen her etterhvert det kommer noe aktuelt.
https://ww.9to5google.com/2020/01/16/galaxy-s20-curved-screen-opinion/
https://mobil.nu/samsung/rygte-samsung-galaxy-s20-ultra-5g-kan-faa-hele-16-gb-ram-106735
Samsung Galaxy S20 Ultra 5G kan få hele 16 GB RAM
Samsung Galaxy S20 Ultra 5G kan komme med hele 16 GB RAM - tre modeller i serien får desuden 5G og alle får understøttelse af eSIM.
De seneste dage har der været gang i jungletrommerne om Samsungs kommende Galaxy S20-serie. Bagmanden bag mange af rygterne har været XDA Developers Max Weinbach og han har både kunnet vise de første billeder af Galaxy S20 Ultra 5G og byde på specifikationer og detaljer om de forskellige modeller.
Samsung Galaxy S20 5G får 16 GB RAM
Blandt de vildere af rygterne er, at topmodellen Galaxy S20 Ultra 5G kommer i en version med absurde 16 GB RAM. Det kan faktisk være, at den dermed får mere RAM, end de fleste har i deres laptop.
Standardmodellen kommer dog ifølge Weinbach ”kun” til at have 12 GB RAM. Udover al den RAM kan man også vælge imellem forskellige mængder hukommelse – fra 128 til 512 GB med understøttelse af Micro SD for at kunne udvide op til 1 TB.
Kamera med 10 gange optisk zoom
Vi har tidligere hørt rygter om, at Ultra-versionen af S20 skulle have et endnu bedre kamera end grundmodellen, og her bekræfter Weinbach, at S20 Ultra får en hovedsensor på 108 megapixel, en 48 megapixel 10x optisk zoomsensor og en ultra vidvinkel på 12 megapixel.
Samtidig postede Weinbach et billede af, hvordan kamaeraet skulle kunne se ud. Til at køre alt det her har den et batteri på 5.000 mAh, der understøtter 45W lynopladning, formentlig af samme slags, som vi har set i Note 10+.
Ifølge alle de detaljer om kameraet, som Weinbach også har afsløret, skal S20 have en hovedsensor på 12 megapixel med Sonys IMX 555 med 1.8μm pixel. Derudover skal der også være en Samsung ISOCell S5KGW2-sensor på 48 megapixel, uden at vi ved, hvad den skal have for rolle, samt en Samsung ISOCell S5K2LA-sensor, som vi ikke kender antallet pixel på, og endelig en fjerde sensor.
8K video optagelser
S20+ understøtter op til 8K 30 fps-optagelser og 4K 60 fps i stabiliseret mode. Selfie-kameraet får samme sensor som Galaxy S10 og Note 10 med systemet Smart Selfie Angle, der selv skifter til vidvinkel-mode, når det behøves. S20+ får også Note 10-seriens ”zoom-in mic”.
Ny er en funktion med navnet Single Take Photo, der automatisk snupper et billede eller videoklip, når du vifter med telefonen.
Alle S20 modeller understøtter eSIM
Også antallet af S20-modeller har Weinbach bekræftet. Mindst fem forskellige versioner, hvor tre af dem er 5G-telefoner, der desuden alle understøtter eSIM. Det kan være, at de resterende to også gør det. Nogle af telefonernes wallpaper har vi også set.
Med tanke på alt, der er kommet fra Weinbach den seneste tid, og hvis han fortsætter sådan, kommer vi til at vide alt om S20-telefonerne, inden det rent faktisk bliver tid til præsentationen i februar måned.
https://ww.9to5google.com/2020/01/14/galaxy-s20-headphone-jack-leak/
https://www.tek.no/nyheter/nyhet/i/dO0yzo/dette-skal-vre-samsung-galaxy-s20
https://ww.9to5google.com/2020/01/13/galaxy-s20-ultra-specs-leak/
https://mobil.nu/samsung/foerste-smugkig-paa-samsung-galaxy-s20-plus-5g-106698
Endret av nor50
nor50 skrev (4 minutter siden):
Ja, men var tidligere i høst/vinter snakk om å la oss få Snapdragon her og.
Tviler på at vil skje. Eneste grunnen til at det ikke er Exynos i USA er vel pga noe patentrettigheter om jeg ikke tar feil.
Så Exynos kommer nok til USA også etterhvert. :D
Men blir nok en S20 på meg hvertfall :)
Merko. skrev (19 minutter siden):
S20 Ultra frister STORT!
Jeg har hatt det meste av mobilens toppmodeller opp gjennom årene. Jeg ender bestandig tilbake til Samsung. Huawei eksempelvis kan ha litt bedre kamera, en annen produsent noe annet snadder, men totalsummen av alt går bestandig i favør Samsung hos meg.
120hz høyoppløst skjerm med godt kamera frister. Det har vært rykter om at Snapdragon kommer til flere land, men Europa har alltid vært i ryktene om de som får Exynos. Det er synd, fordi Mongoose ikke er i nærheten av ARM sin A77. Amd sin teknologi innen grafikk gjør også at Snapdragon yter bedre. Derfor ønsker samsung å benytte Snapdragon mer i år, nettopp fordi forskjellen skal være ganske stor.
Det jeg synes er mest kjedelig er at det kun er ultra som får 108mp brikken og periskop-kameraet.
Jeg synes s20 høres perfekt ut med tanke på størrelsen på 6.2". Synd den ikke får den nye 108mp brikken som skal være stor og gi bedre bilder.
6.9" må da være gigantisk? :)
gurka skrev (46 minutter siden):
Nei da, jeg brukte et Samsung 7" 4G nettbrett som mobil for noen år siden.
Merko. skrev (6 timer siden):
Sikkert flere elementer i spill, avtaler med Qualcomm og manglende støtte for de eldre amerikanske nettene i Exynos modemet er sannsynlig:
Fortsatt med hull i skjemen. Venter med ny Samsung til dem kommer med en skjerm uten hull. Får håpe på neste Galaxy S30.
Skulle ønske dem sluttet med de avrundede kantene. Man kunne jo gått for den billigere varianten som ikke har avrundede kanter, men den er ikke like godt spekket.
Endret av DJViking
