Trenger webdesign som ligner litt
Hei!
Jeg trenger et webdesign forlsag som ligner på www.snyggast.se designet bare med penere farger og litt mer hi-tech.
Jeg vet at mange ikke har tid men folk har gjort dette før, så hvis du ikke har noe å gjøre eller noe så please prøv ihvertfall :)
God jul og godt nyttår til alle :) !
HTTP/1.1 200 OK
Server: Microsoft-IIS/5.0
Date: Sat, 27 Dec 2003 15:28:20 GMT
Connection: Keep-Alive
Content-Length: 6486
Content-Type: text/html
Cache-control: private
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "DTD/xhtml1-transitional.dtd">
<html><head><title>glish.com : CSS layout techniques : 3 columns, the holy grail</title>
<style type="text/css">
@import "all.css"; /* just some basic formatting, no layout stuff */
body {
	margin:10px 10px 0px 10px;
	padding:0px;
#leftcontent {
	position: absolute;
	left:10px;
	top:50px;
	width:200px;
	background:#fff;
	border:1px solid #000;
#centercontent {
	background:#fff;
  		margin-left: 199px;
  		margin-right:199px;
	IE5x PC mis-implements the box model. Because of that we sometimes have
	to perform a little CSS trickery to get pixel-perfect display across browsers.
	The following bit of code was proposed by Tantek Celik, and it preys upon a CSS
	parsing bug in IE5x PC that will prematurly close a style rule when it runs
	into the string "\"}\"". After that string appears in a rule, then, we can override
	previously set attribute values and only browsers without the parse bug will
	recognize the new values. So any of the name-value pairs above this comment
	that we need to override for browsers with correct box-model implementations
	will be listed below.
	We use the voice-family property because it is likely to be used very infrequently,
	and where it is used it will be set on the body tag. So the second voice-family value
	of "inherit" will override our bogus "\"}\"" value and allow the proper value to
	cascade down from the body tag.
	The style rule immediately following this rule offers another chance for CSS2
	aware browsers to pick up the values meant for correct box-model implementations.
	It uses a CSS2 selector that will be ignored by IE5x PC.
	Read more at [url="http://www.glish.com/css/hacks.asp"]http://www.glish.com/css/hacks.asp[/url]
	voice-family: "\"}\"";
	voice-family: inherit;
  		margin-left: 201px;
  		margin-right:201px;
html>body #centercontent {
  		margin-left: 201px;
  		margin-right:201px;
#rightcontent {
	position: absolute;
	right:10px;
	top:50px;
	width:200px;
	background:#fff;
#banner {
	background:#fff;
	height:40px;
	border-top:1px solid #000;
	border-right:1px solid #000;
	border-left:1px solid #000;
	height:39px;
html>body #banner {
	height:39px;
p,h1,pre {
	margin:0px 10px 10px 10px;
h1 {
	font-size:14px;
	padding-top:10px;
#banner h1 {
	font-size:14px;
	padding:10px 10px 0px 10px;
	margin:0px;
#rightcontent p {
	font-size:10px
</style>
</head><body>
<div id="banner"><h1><a href="home.asp">LAYOUT TECHNIQUES</a>: 3 columns, the holy grail</h1></div>
<div id="leftcontent">
<h1>leftcontent</h1>
<pre>#leftcontent {
position: absolute;
left:10px;
top:50px;
width:200px;
background:#fff;
}</pre>
<p class="greek">
 Lorem ipsum dolor sit amet, consectetuer adipiscing elit, sed diam nonummy nibh euismod tincidunt ut laoreet dolore magna aliquam erat volutpat. Ut wisi enim ad minim veniam, quis nostrud exercitation ulliam corper suscipit lobortis nisl ut aliquip ex ea commodo consequat. Duis autem veleum iriure dolor in hendrerit in vulputate velit esse molestie consequat, vel willum lunombro dolore eu feugiat nulla facilisis at vero eros et accumsan et iusto odio dignissim qui blandit praesent luptatum zzril delenit augue duis dolore te feugait nulla facilisi.
</p>
</div>
<div id="centercontent">
<h1>centercontent</h1>
<pre>#centercontent {
background:#fff;
margin-left: 199px;
margin-right:199px;
margin-left: 201px;
margin-right:201px;
margin-left: 201px;
margin-right:201px;
}</pre>
<p>This is the most elegant technique and perhaps the most sought after layout: a 3 column page with a fluid center column. Easy to understand, easy to implement. I first saw this layout at <a href="http://www.wrongwaygoback.com">dynamic ribbon device</a> and have since learned that the sweet CSS came from Rob Chandanais of <a href="http://www.bluerobot.com">BlueRobot</a>. Owen also made a very nice <a href="http://members.home.net/bigstripes/tutorial/css_3box_plus_topbox.html">tutorial</a> using this layout technique.</p>
<p>Read about the IE5x PC workaround in use on this page <a href="hacks.asp">here</a>.</p>
<p><strong>Scroll down for the source.</strong></p>
<p class="greek">
</p>
<p class="greek">Li Europan lingues es membres del sam familie. Lor separat existentie es un myth. Por scientie, musica, sport etc., li tot Europa usa li sam vocabularium. Li lingues differe solmen in li grammatica, li pronunciation e li plu commun vocabules. Omnicos directe al desirabilit? de un nov lingua franca: on refusa continuar payar custosi traductores. It solmen va esser necessi far uniform grammatica, pronunciation e plu sommun paroles.
</p>
<br />
</div>
<div id="rightcontent">
<h1>rightcontent</h1>
<pre>#rightcontent {
position: absolute;
right:10px;
top:50px;
width:200px;
background:#fff;
}</pre>
	<p>
This page is part of <a href="home.asp">CSS Layout Techniques</a>, a resource for web developers and designers.
</p>
<p>
Other Layout Techniques:<br/>
	<a href="7.asp">3 columns, the holy grail</a><br/>
<a href="9.asp">2 columns, ALA style</a><br/>
<a href="8.asp">4 columns, all fluid</a><br/>
<a href="2.asp">3 columns, all fluid </a><br/>
<a href="3.asp">static width and centered</a><br/>
<a href="1.asp">nested float</a><br/>
</p>
<p>
Does it <a href="http://validator.w3.org/check?uri=http://www.glish.com/css/7.asp?noSRC=true">validate</a>?
</p>
</div>
</body>
</html>
Lemme get this straight.
Du vil at noen her skal lage et webdesign, inkludert php osv. som et FORSLAG til deg, GRATIS? Når skal folk lære at slikt koster penger, tid og krefter?
Kontakt en profesjonell webdesigner, gjerne en på forumet, og tilby en viss sum for arbeidet (vi snakket noen tusen her). Så skal du nok få deg et design.
Ikke med php og alt det, bare et enkelt design som ligner litt på den siden. Ikke med alle greiene de har da.
Det jeg sa gjelder like fullt fremdeles.
Bla opp noen store lapper eller ti for evig. :cool:
EDIT: Vent nå litt... Uranus, jeg tok en titt på sida du hadde i signaturen. Og en ting slo meg:
Hvordan i svarte tror du folk faktisk KJØPER disse vitsene per sms, når HELE vitsen står der?
Hva pokker er da vitsen med det? :thumbs:
Endret av HalTan
SMS-addicts er et eget slag og bruker penger på alt som kan hentes inn på telefonen. De vil vel ha noe de kan sende videre til hele telefonboken, og betaler heller en slant for å slippe å skrive hele greia inn selv (skjønt en 1337-sms'er hadde vel bare brukt noen sekunder).
Det er min teori. :p
