Pc krasjer under spilling
I går begynte pc å krasje under alle spill jeg har prøvd. Dette har skjedd før under enkelte spill men trudde det bare var bugs i early access spill nå er det alle. Den er 10 år gammel snart med ett litt nyere skjermkort nvidia 770 så mulig det er noe hardware feil.
Har testet med furmark og memtest
Når det krasjer så har jeg fortsatt bilde og lyd så må jeg slå den av ved å holde inn power
System Information
      Time of this report: 8/2/2019, 13:26:38
             Machine name: DESKTOP-CPPF6FM
               Machine Id: {2600F896-4826-4619-AA28-B5F3E8F81574}
         Operating System: Windows 10 Home 64-bit (10.0, Build 18362) (18362.19h1_release.190318-1202)
                 Language: English (Regional Setting: English)
      System Manufacturer: Gigabyte Technology Co., Ltd.
             System Model: X58A-UD3R
                     BIOS: Award Modular BIOS v6.00PG (type: BIOS)
                Processor: Intel® Core i7 CPU         930  @ 2.80GHz (8 CPUs), ~2.8GHz
                   Memory: 6144MB RAM
      Available OS Memory: 4094MB RAM
                Page File: 4824MB used, 3109MB available
              Windows Dir: C:\WINDOWS
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: 96 DPI (100 percent)
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Available, no HDCP
Microsoft Graphics Hybrid: Not Supported
 DirectX Database Version: Unknown
           DxDiag Version: 10.00.18362.0267 64bit Unicode
Event wiever: EDIT: googlet den første feilen. det tar vist 1-2 timer og fikse det så sjekker her om noen vet om det kan være noe annet
Error 1:
The application-specific permission settings do not grant Local Launch permission for the COM Server application with CLSID
Windows.SecurityCenter.WscBrokerManager
 and APPID
Unavailable
 to the user NT-MYNDIGHET\SYSTEM SID (S-1-5-18) from address LocalHost (Using LRPC) running in the application container Unavailable SID (Unavailable). This security permission can be modified using the Component Services administrative tool.
Error 2:
Session "Cloud Files Diagnostic Event Listener" failed to start with the following error: 0xC0000022
Error 3:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Endret av OPL
Eventviever viser ikke noe annet enn informasjons event at PCen her gjort en recovery etter power-loss.
De andre to tingene er utelatert.
Hvis PCen er 10 år er det kanskje PSUen som er blitt degradert og ustabil. Ville ha testet med en annen PSU.
Det er mulig, har ikke en annen og teste med
Rart der står både 6144MB og 4096MB minne. Kan dette bety at en 2 GB brikke ikke virker?
Kjøre en minne test kanskje?
Har gjort det men sjekket litt og fikk låst opp mer. Nå ser det mer riktig ut
Memory: 6144MB RAM
      Available OS Memory: 5630MB RAM
                Page File: 3381MB used, 6089MB available
Har du enablet integrert grafikk kan de resterende 512MB av system minne være reservert til IGP i BIOS.
Fant ikke noen integrert grafikk i bios.
Den krasjer ikke lenger nå, demonterte den delvis og rengjorde. Håper det holder en stund til nå. Kommer nok til å bygge en ny amd i løpet av året.
EDIT: Nå er jeg tilbake på 4094 ram
Endret av OPL
Den begynte og krasje igjen under spilling nå. Jeg har overclocket den tidligere så jeg tok en default reset av bios og nå har jeg riktig ram mengde
Memory: 6144MB RAM
      Available OS Memory: 6142MB RAM
