Xiaomi Redmi K20-tråden
Diskuter alt om Xiaomi Redmi K20 her!
SPLAY Type AMOLED capacitive touchscreen, 16M colors Size 6.39 inches, 100.2 cm2 (~86.1% screen-to-body ratio) Resolution 1080 x 2340 pixels, 19.5:9 ratio (~403 ppi density) Protection Corning Gorilla Glass 5
HDR
PLATFORM OS Android 9.0 (Pie); MIUI 10 Chipset Qualcomm SDM730 Snapdragon 730 (8 nm) CPU Octa-core (2x2.2 GHz Kryo 470 Gold & 6x1.8 GHz Kryo 470 Silver) GPU Adreno 618 MEMORY Card slot No Internal
256 GB, 8 GB RAM or 64/128 GB, 6 GB RAM
MAIN CAMERA Triple 48 MP, f/1.8, 26mm (wide), 1/2", 0.8µm, PDAF
8 MP, f/2.4, 53mm (telephoto), 1/4", 1.12µm, PDAF, 2x optical zoom
13 MP, f/2.4, 12mm (ultrawide), 1/3", 1.12µm Features Dual-LED flash, HDR, panorama Video 2160p@30fps, 1080p@30/120/240fps, 1080p@960fps SELFIE CAMERA Single Motorized pop-up 20 MP, f/2.2, 0.8µm Features HDR Video 1080p@30fps SOUND Loudspeaker Yes 3.5mm jack Yes   24-bit/192kHz audio
Active noise cancellation with dedicated mic
COMMS WLAN Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot Bluetooth 5.0, A2DP, LE, aptX HD GPS Yes, with A-GPS, GLONASS, GALILEO, BDS NFC Yes Radio Yes USB 2.0, Type-C 1.0 reversible connector, USB On-The-Go FEATURES Sensors Fingerprint (under display), accelerometer, gyro, proximity, compass BATTERY   Non-removable Li-Po 4000 mAh battery Charging Fast battery charging 18W MISC Colors
Carbon black, Red flame, Glacier blue
https://www.gsmarena.com/xiaomi_redmi_k20-9720.php
US $374.58 19%OFF | Global Version Xiaomi MI 9T 9 T Redmi K20 6GB 128GB Snapdragon 730 Octa Core Smartphone 6.39''AMOLED Display 48MP Cameras NFC
https://s.click.aliexpress.com/e/b0YCcITI
Jeg betalte $374 for 128Gb utgaven. Bestilte samme dag som den ble lagt ut for salg (30.05), så jeg betalte nok litt mer enn prisene kommer til å stabilisere seg på ut over sommeren.
De rimeligste butikkene ligger nå på $329 for 64Gb utgaven
Endret av OC-Freak
$30 kupong hos aliexpress i dag og i morgen:
US $329 20%OFF | Presale Global Version Xiaomi Mi 9T (Redmi K20) 6GB 64GB /6GB 128GB Smartphone Snapdragon 730 Pop-up Front Camera NFC 6.39" 48MP
https://s.click.aliexpress.com/e/bwSq0U5S
Dette gir ca 300$ for 64Gb og 340$ for 128Gb utgaven.
Om man har "coins" hos aliexpress kan man bytte inn 20 mot ytterligere 5$ rabatt.
Obs på at denne selgeren kan være litt treg på å sende ut varer.
Endret av OC-Freak
Har slått denne fra meg siden den mangler B20. Eller tar jeg feil?
Synes fortsatt at Lenovo Z6 Pro som har SD kort og Super Amoled frister vel så mye. Der følger det med en liten busslomme og så antar jeg at Miui er bedre. Uansett vil man vel gå over til LineageOS eller lignende etterhvert.
https://www.kimovil.com/en/compare/lenovo-z6-pro-global,xiaomi-redmi-k20-pro-6gb-128gb-cn
Endret av kimare
  • 2 uker senere...
Da har jeg hatt telefonen i snart to uker. Kjempefornøyd så langt.
*Fantastisk skjerm, skikkelig god amoled skjerm uten notch eller hull. Høy lysstyrke utendørs.
*Bra kamera, jeg har funnet ut at jeg liker best bildene fra stock app i dagslys, i mørke er gcam bedre. gcam vil nok finpusses mer etterhvert når fler moddere får tak i telefonen.
*God batteritid, jeg lader hver 3. dag med mitt bruk.
*God ytelse i daglig bruk.
Den har også dukket opp på prisjakt, men prisene som kreves er ganske høye sammenlignet med å bestille fra utlandet.  https://www.prisjakt.no/search?search=xiaomi%20mi%209t&searchInProps=false
Den er også testet hos gsmarena nå; https://www.gsmarena.com/xiaomi_mi_9t-review-1950.php
Og kommer bra ut "all round", med god batteritid og bra kameraresultater.
