Hydrogenstasjon i brann etter eksplosjon i Sandvika
(Oslo, June 13, 2019) Nel ASA (Nel, OSE:NEL) announces preliminary findings from safety consultancy Gexcon regarding the incident at the Kjørbo hydrogen station on June 10, 2019.
"Based on what we have seen at the site, we can conclude that neither the elctrolyzer nor the dispenser used by customers had anything to do with this incident. We will continue to analyze the other components of the site to further narrow down the source," says Geirmund Vislie, Vice President Consultant of Gexcon AS.
In addition to the electrolyzer and the dispenser used by customers, the Kjørbo site comprises of a stationary low-pressure storage unit, a low-pressure transport unit, a stationary high-pressure storage unit, various valve panels, and a hydrogen refueling station unit.
The Kjørbo site also includes a containerized, pressurized alkaline electrolyzer that produces hydrogen in part from solar power. This is delivered by the Nel Hydrogen Electrolyser division.
"We are pleased with the preliminary findings, and our electrolyzer division will now return to business as usual," says Jon André Løkke,
Nel has published a dedicated status update and Q&A site to address the incident at the Kjørbo hydrogen station. The site can be accessed on www.nelhydrogen.com, and will updated as new information becomes available.
- ENDS-
Første melding som tyder på at NEL ikke har noe med ulykken å gjøre gjennom deres teknologi. Da står tankene igjen, med tilhørende deler.
Samtidig, så har investorer reagert, og aksjen er opp 35% fra bunnen etter ulykken.
Endret av oophus3do
Gjest Slettet+45613274
Q: Was there an explosion?
No unit exploded at the site. Based on our current information, hydrogen gas that had leaked caught fire in open air. This created a pressure wave.
En alternativ definisjon av begrepet eksplosjon? :)
Noen som har innsikt hva på selve tanken som kan gå galt?
Endret av Slettet+45613274
For å sitere Wikipedia: "Kjemisk drevne forbrenninger som går med høy hastighet blir gjerne omtalt som eksplosjoner"
Påstår de at det var en vanlig brann som utløste to kollisjonsputer og forflyttet deler av stasjonen 40 meter i luftlinje?
Nei? De som selskap snakker selvsagt direkte ut til sine investorer. Hva er dem interessert i?
Var det noe av NEL sitt utstyr som eksploderte (for det er jo ingen tvil om at det var en eksplosjon)? Og svaret på det er nei. Det er ikke noe av deres utstyr som eksploderte.
I og med at hydrogenet hadde leke ut i lufta var det vel ingen sitt på det tidspunktet, men er det ikkje litt vel teoretisk å kverrulere på kven som var den formelle eigaren av hydrogenet som eksploderte?
Når nok ein hydrogenstasjon går i lufta fordi bransjen bagatelliserer risikoen, ser det ikkje betre ut om dei fråskriv seg ansvar i tillegg,
  • Liker 4
Vel, det er utvilsomt Uno-X sitt hydrogen, ikke NEL, siden det er Uno-X som selger det. Det er jo irrelevant, siden det interessante er å vite hvilken svakhet det var som førte til eksplosjonen. At det ikke er noe av det som NEL leverer som er skyld i den er bra for NEL omdømmemessig og erstaningsmessig, men det er da åpenbart at NEL ikke vil tjene på at hydrogenstasjoner går i luften.
Skumlest tråden nå kun fordi jeg bor ett steinkast unna stasjonen og tenkte det kunne være greit å få med seg om det var noe mer info her. 9 sider krangling om urelaterte/filleting og ingenting nytt.
Supert   :dremel:
Hva enn kan man forvente når det er forskjellige lag. "Batterilaget, Hydrogenlaget og "alt er bare jug-laget"
Så har man menneskelig tribalisme som tar over og man forsvarer sitt lag selv om det ikke gir mening enkelte ganger. Rasjonell tankegang går ut av vinduet og blir fylt med bias.
Jepp, menneske i et nøtteskall.
Hadde vært fint om vi vokste opp snart.
Du gløymte "ja til miljøverntiltak men hydrogen er farleg når den blir handtert av ukvalifiserte-laget".
Tok bare noen veldig grove lag for og gjøre det kort :p
Som en som har hatt en pakkboks på ventil blåse ut rein hydrogen i trynet ditt mens du skrur på pakkboksen med nøkkel. Og eneste du tenker er "ikke lag gnist, ikke lag gnist" så er jeg helt enig :p
Hydrogen har ingenting og gjøre i hendene på folk flest.
Man legger ikke en dynamitt fabrikk midt i byen..
  • 1 måned senere...
  • 3 uker senere...
Utrolig tragisk ulykke. I motsetning til Sandvika-eksplosjonen ble noen alvorlig skadet (men ingen europaveier stengt). Det er nesten for galt til å påpeke åpenbare utfordringer med brennbar gass som energilagringsmedie i personbiler, uansett type brennbar gass. Får krysse fingrene for at hun overlever og kommer forholdsvis bra fra det.
Gamlefar: Jøss, blir spennende å se hva etterforskningen kommer fram til. (Kanskje eieren hadde kjøpt propan til grillen og oppbevarte den i bilen?)
