Okkupereings leken
Jeg har ikke skjønt at det er en lek før nå. Når du nevner det er en lek.
Onanere
nanere
anere
nere
ere
re
e
Nytt ord:
methionylglutaminylarginyltyrosylglutamylserylleucyl phenylalanylalanylglutaminylleucyllysylglutamylarginyl lysylglutamylglycylalanylphenylalanylvalylprolylphenyl alanylvalylthreonylleucylglycylaspartylprolylglycylisol eucylglutamylglutaminylserylleucyllysylisoleucylaspartyl threonylleucylisoleucylglutamylalanylglycylalanylaspartyl alanylleucylglutamylleucylglycylisoleucylprolylphenyl alanylserylaspartylprolylleucylalanylaspartylglycylprolyl threonylisoleucylglutaminylasparaginylalanylthreonylleucyl arginylalanylphenylalanylalanylalanylglycylvalylthreonyl prolylalanylglutaminylcysteinylphenylalanylglutamyl methionylleucylalanylleucylisoleucylarginylglutaminyllysyl histidylprolylthreonylisoleucylprolylisoleucylglycylleucyl leucylmethionyltyrosylalanylasparaginylleucylvalylphenyl alanylasparaginyllysylglycylisoleucylaspartylglutamylphenyl alanyltyrosylalanylglutaminylcysteinylglutamyllysylvalyl glycylvalylaspartylserylvalylleucylvalylalanylaspartylvalyl prolylvalylglutaminylglutamylserylalanylprolylphenylalanyl arginylglutaminylalanylalanylleucylarginylhistidylasparaginyl valylalanylprolylisoleucylphenylalanylisoleucylcysteinyl prolylprolylaspartylalanylaspartylaspartylaspartylleucyl leucylarginylglutaminylisoleucylalanylseryltyrosylglycyl arginylglycyltyrosylthreonyltyrosylleucylleucylserylarginyl alanylglycylvalylthreonylglycylalanylglutamylasparaginyl arginylalanylalanylleucylprolylleucylasparaginylhistidyl leucylvalylalanyllysylleucyllysylglutamyltyrosylasparaginyl alanylalanylprolylprolylleucylglutaminylglycylphenylalanyl glycylisoleucylserylalanylprolylaspartylglutaminylvalyllysyl alanylalanylisoleucylaspartylalanylglycylalanylalanylglycyl alanylisoleucylserylglycylserylalanylisoleucylvalyllysylisol eucylisoleucylglutamylglutaminylhistidylasparaginylisoleucyl glutamylprolylglutamyllysylmethionylleucylalanylalanylleucyl lysylvalylphenylalanylvalylglutaminylprolylmethionyllysyl alanylalanylthreonylarginylserine
Beskrivelse hva det er for noe:
Dette er verdens lengste norskt ord, og er fulle navnet på proteinet tryptophan synthetase. Ordet består av 1 913 bokstaver. Proteiner består av aminosyrer, og navnet ovenfor er fremkommet ved å navngi alle aminosyrene i proteinet.
I prinsippet er det altså ikke noe i veien for å lage ord så lange som evigheten, på komplekse kjemiske komponenter, for eksempel proteiner. Du bare navngir hver enkelt del i molekylet. Og sånn holder du på til du enten ikke gidder mer, eller til du dør av alderdom.
Nå misforstår du leken. Annenhver bruker skal skrive ord. Og når første forbokstav i hvert ord er fjernet, skal neste forbokstav ha stor forbokstav.
Sånn var det før:
Spre-M: Bæsj
TheD: Æsj
Spre-M: Sj
TheD: J
Okei, da starter vi på nytt.
Nytt ord:
Onanere
Endret av SprengeMobil
Gjest
