IceCool Skrevet 21. desember 2003 Del Skrevet 21. desember 2003 Nullsoft Winamp is a fast, flexible, high-fidelity music player for Windows. Winamp supports MP3, CD, Audiosoft, Audio Explosion, MOD, WAV and other audio formats, custom appearances called skins, plus audio visualization and audio effect plug-ins. additional features including free-form skins, a new decoder, built-in cross fade, and an advanced Media Library. Winamp3 was a failure in terms of what it hoped to achieve, many users reverted back to Winamp 2 as it was faster and more recent versions included some of the features that 3.0 introduced. What's New in This Release: · Fixed gen_ml selection bug · Added gen_ml option for no guessing at all · Made AVS and SPS support loop() in user code · Made AVS support megabuf() in user code · Made pro installer not prompt for regkey if already valid · Improved font directory retrieval in gen_ff · Added content rating system in Internet TV's listing · Added bandwidth usage statistic in Internet Radio/TV listings · Made media library guess from filename only when NO metadata found · Added seperate recent items tracking options for files/streams · Made installer better handle installing wa5 directly over wa3 · Added milkdrop docs to installer · Made uninstaller not remove winamp directory if not empty Download Full Version http://download.nullsoft.com/winamp/client...amp501_full.exe Download Lite version http://download.nullsoft.com/winamp/client...amp501_lite.exe http://warp2search.net/modules.php?name=Ne...ticle&sid=15726 Lenke til kommentar
wil Skrevet 21. desember 2003 Del Skrevet 21. desember 2003 ja, høres jo kurrant ute det men Winamp 5.01 versjonen er vel tilnærma 5.0 versjonen? eller er det den samme? selv kjører jeg Winamp 5.0, den er digg. mye bedre enn de andre+ at den kan spille av musikkvideoer. Lenke til kommentar
IceCool Skrevet 21. desember 2003 Forfatter Del Skrevet 21. desember 2003 Eeeeeeh ja...Oppgraderingen fra 5.0 til 5.01 står nå hva den inneholder av fixes i listen på 1. post Lenke til kommentar
bjaa Skrevet 21. desember 2003 Del Skrevet 21. desember 2003 Har merket en feil i Winamp 5 (dette gjelder både beta'en og den vanlige), nemlig at når jeg tar og markerer mange filer (sanger) i en mappe og trykker enter. Da starter den opp en winamp for hver sang, ikke alle sammen i en play list. det er ikke allitd den bugger slikt..noen ganger tar den på vanlig måte også... Er dette fikset opp i 5.01 tru? Lenke til kommentar
Spaz Skrevet 21. desember 2003 Del Skrevet 21. desember 2003 Har merket en feil i Winamp 5 (dette gjelder både beta'en og den vanlige), nemlig at når jeg tar og markerer mange filer (sanger) i en mappe og trykker enter. Da starter den opp en winamp for hver sang, ikke alle sammen i en play list. det er ikke allitd den bugger slikt..noen ganger tar den på vanlig måte også... Er dette fikset opp i 5.01 tru? Gå inn i option og fjern haken ved "Allow multiple instances" i "General Preferences". Mulig det hjelper Lenke til kommentar
IceCool Skrevet 21. desember 2003 Forfatter Del Skrevet 21. desember 2003 Har merket en feil i Winamp 5 (dette gjelder både beta'en og den vanlige), nemlig at når jeg tar og markerer mange filer (sanger) i en mappe og trykker enter. Da starter den opp en winamp for hver sang, ikke alle sammen i en play list. det er ikke allitd den bugger slikt..noen ganger tar den på vanlig måte også... Er dette fikset opp i 5.01 tru? Ser ut til å være fixet, har standard settings og den ruller fint gjennom alle selected MP3's i den ene åpne winamp 5.01 avspilleren Lenke til kommentar
