Nautica Skrevet 20. august 2019 Forfatter Del Skrevet 20. august 2019 Nå er også 90D offisiell og blir lansert i neste uke, kommer med oppdatering når det har blitt lansert. spesifikasjonen i spoiler. Vis skjult innhold The EOS 90D is a powerful, fully equipped interchangeable lens camera providing you with everything you need at your fingertips to advance your photography and video skills. The EOS 90D shoots a fast 10 frames per second continuous shooting with full autofocus tracking. Paired with the 3” vari-angle LCD touch screen, the EOS 90D allows you to get creative and photograph your subject from any angle. The camera also comes equipped with a 32.5 MP APS-C CMOS sensor and the ability to shoot 4K 30p and Full HD 120p movies.IMAGE SENSORType APS-C CMOSEffective Pixels Approx. 32.5 megapixelsTotal Pixels Approx. 34.4 megapixelsAspect Ratio 3:2Sensor Cleaning EOS integrated cleaning systemColour Filter Type Primary ColourIMAGE PROCESSOR DIGIC 8TypeLENSLens Mount EF/EF-SFocal Length Equivalent to 1.6x the focal length of the lensFOCUSINGMethod Dual Pixel CMOS AFAF System/ Points 45 cross-type AF pointsAF working range EV -3 – 18 (at 23°C & ISO100)AF Modes Spot AF1-Point AF Zone AF Large Zone AFFace Priority AF AI FocusOne Shot AI ServoMovie Servo AF Continuous AF Eye Detection AFAF area Horizontal: approx. 88%, Vertical: approx. 100%AF Lock Locked when shutter button is pressed half wayAF Assist Beam Intermittent firing of built-in flash or emitted by optional dedicated SpeedliteAF Microadjustment Adjust all lenses by same amount Adjust by lensManual Focus Selected on lensEXPOSURE CONTROLMetering modes Viewfinder shooting:Approx 220,000 pixels RGB+IR metering sensor 216-zone (18×12) TTL full-aperture meteringLive View shooting and Move recording: 384-zone metering with image sensorMetering Range EV 1-20 (optical viewfinder) EV -2 – 20 (Live View)EV 0 – 20 (Movie recording)AE Lock Auto: In One-shot AF mode with evaluative metering exposure is locked when focus is achieved.Manual: By AE lock button in P, TV, AV and M mode.Exposure Compensation +/-5 EV in 1/3 or 1/2 stop increments (viewfinder)+/-3 EV in 1/3 or 1/2 stop increments (Live View/ Movie)AEB +/-3 EV 1/3 or 1/2 stop incrementsISO Sensitivity (8) Auto (100-12800min / 100-25600 max) in 1-stop increments.Manual (100-25600) in 1/3-stop increments, expanded to 51200 equivalent.Minimum limit may change depending on the lensSHUTTERType Vertical-travel mechanical focal-plane shutter, electronically controlled at all speedsSpeed Creative Zone: 1/16000 – 30 sec, bulb Basic Zone: 1/8000 – 1 secAvailable range varies by shooting modeWHITE BALANCEType Auto white balance with the imaging sensorSettings AWB (Ambience priority, White priority), Daylight, Shade, Cloudy, Tungsten light, White Fluorescent light, Flash, Custom, Colour Temperature Setting. White balance compensation: 1. Blue/Amber +/-9. Magenta/ Green +/-9Custom White Balance Yes, 1 setting can be registeredWB Bracketing +/-3 levels in single level incrementsVIEWFINDERType PentaprismCoverage (Vertical/Horizontal) Approx. 100%Magnification Approx. 0.95x (4)Eyepoint Approx. 22mm (from eyepiece lens centre)Dioptre Correction -3 to +1 m-1 (dioptre)Focusing Screen FixedMirror Quick-return half mirrorViewfinder Information AF information: AF points, focus confirmation, AF area selection modeExposure information: Shutter speed, aperture value, ISO speed (always displayed), AE lock, exposure level/compensation, spot metering circle, exposure warning, AEB.Flash information: Flash ready, high-speed sync, FE lock, flash exposure compensation, red-eye reduction light.Image information: Card information, maximum burst (2 digit display), Highlight tone priority (D+).Composition information: Grid, Electronic level, Aspect RatioOther information: Battery check, Alert symbol, Flicker DetectionDepth of field preview Yes, with Depth of Field preview button.Eyepiece shutter None. Eyepiece cover attached to strapLCD MONITORType Touch screen vari angle 7.7cm (3.0″) 3:2 Clear View II TFT, approx. 1040K dotsCoverage Approx. 100%Viewing Angle (horizontally/vertically) Approx. 170°Coating Anti smudgeBrightness Adjustment Adjustable to one of seven levelsTouch Screen Operations Touch Shutter Touchscreen sensitivity BeepFLASHType Manual pop-up retractable flash in the pentaprism housingGuide number Approx 12/39.4 (ISO100 m/feet)Flash coverage Approx. 17mm focal length/angle of viewFlash exposure compensation +/- 3 stops in 1/3 or ½ stop increments. It is available using either built-in flash on the side of the camera or an external flash unit.Built-in Flash recycle time Approx. 3 secondsModes Auto, Manual flash, Integrated Speedlite TransmitterColour temperature Equivalent to daylightRed eye reduction Using the red eye reduction lampFE lock flash metering SupportedFlash sync speed Max 1/250 secSlow synchro 1/250 – 30 sec (auto) 1/250 – 1/60 sec (auto 1/250 sec (fixed)External Flash Compatibility E-TTL II with EX series Speedlites, wireless multi-flash supportE-TTL II flash metering Evaluative (Face Priority) EvaluativeAverageTechnical Specifications EOS 90DSHOOTINGModes Scene Intelligent Auto (Stills and Movie), SCN (Portrait, Group Photo, Landscape, Close-up, Sports, Night Portrait, Handheld Night Scene, HDR Backlight Control, Food, Kids, Candlelight, Panning), HDR movies, Creative filters, Program AE, Shutter priority AE, Aperture priority AE,Manual (Stills and Movie), Bulb, CustomPicture Styles Auto, Standard, Portrait, Landscape, Fine Detail, Neutral, Faithful, Monochrome, User Defined (x3)Colour Space Selectable between sRGB and Adobe RGBImage Processing Highlight Tone Priority (Disable/Enable/Enhanced) Auto Lighting Optimizer (4 settings)Long exposure noise reductionHigh ISO speed noise reduction (4 settings) Multi Shot Noise ReductionAuto Correction of Lens Peripheral illumination and Chromatic aberration correctionDiffraction correction Digital Lens OptimizerCreative filters (Grainy B/W, Soft focus, Fish-eye effect, Water painting effect, Toy camera effect, Miniature effect, HDR x 4)RAW image processing (Brightness adjustment, White balance, Picture Style, ALO, High ISO speed NR, image quality, Colour space, Lens aberration correction.)Drive modes Single, Continuous L, Continuous H, Continuous Shooting Panning, Silent Single Shooting, Self timer (2s+remote, 10s +remote, Continuous)Continuous Shooting One shot: Max approx. 10 fps (viewfinder) / 11 fps (live view)Servo: Max approx. 10 fps (viewfinder) / 11 fps (live view)LIVE VIEW MODEType Electronic viewfinder with image sensorCoverage Approx. 100%Frame Rate 30 fpsFocusing Manual Focus (Magnify the image 5x or 10x at any point on screen)Autofocus: Dual Pixel CMOS AF (Face detection and Tracking AF, FlexiZone-Multi, FlexiZone-Single), Tracking sensitivity (-3 to +3) and Movie Servo AF Speed (-7 to +2)Metering Real-time evaluative metering with image sensor. Evaluative metering, partial metering, spot metering,center-weighted average metering.Display Options Basic, Detailed, On-screen buttons, Histogram, Electronic levelFILE TYPEStill Image Type JPEG: (Exif 2.31 compliant)RAW: RAW (14bit, Canon original RAW CR3),RAW+JPEG simultaneous recording RAW/C-RAW and JPEG simultaneous image recording quality is supported.Image Size JPEG 3:2: (L) 6960 x 4640, (M) 4800 x 3200, (S1) 3472 x2320, (S2) 2400 x 1600, (RAW/CRAW) 6960 x 4640JPEG 4:3: (L) 6160 x 4640, (M) 4256×3200, (S1) 3072×2320, (S2) 2112×1600, (RAW/CRAW) 6960 x 4640 JPEG 16:9: (L) 6960×3904, (M) 4800×2688, (S1) 3472×1952, (S2) 2400×1344, (RAW/CRAW) 6960 x 4640 JPEG 1:1: (L) 4646×4646, (M) 3200×3200, (S1) 2320×2320, (S2) 1600×1600, (RAW/CRAW) 6960 x 4640Movie Type MP4MPEG-4 AVC/H.264 (variable averaged bit rate) Audio: AAC/Linea PCMMovie Size 4K (3840 x 2160) Uncropped/Cropped 29.97 fpsFull HD (1920 x 1080) 119.88 fpsHD (1280 x 720) 59.94 fpsHDR (1920 x 1080) 29.97 fpsMovie Length Max duration 29min 59sec, Max file size 4GB (If file size exceeds 4GB a new file will be created automatically)OTHER FEATURESCustom Functions 29 Custom FunctionsWater / Dust resistance YesPlayback zoom 1.5x – 10xHistogram Brightness: Yes RGB: YesImage Erase/Protection Erase: Single image, All images in folder, All images on cardProtection: 6 optionsMenu Languages 29 LanguagesEnglish, German, French, Dutch, Danish, Portuguese, Finnish, Italian, Norwegian, Swedish, Spanish, Greek, Russian, Polish, Czech, Hungarian, Vietnamese, Hindi Romanian, Ukrainian, Turkish, Arabic, Thai, Simplified Chinese, Traditional Chinese, Korean, Malay, Indonesian and JapaneseFirmware Update Update possible by the user.Technical Specifications EOS 90DINTERFACEComputer Hi-Speed USBOther Video output (PAL/ NTSC) (integrated with USB terminal), HDMI mini output (Typce C only, CEC not supported), External microphone (3.5mm Stereo mini jack), Headphone socket (Stereo mini jack)DIRECT PRINTCanon Printers Canon Compact Photo Printers and PIXMA Printers supporting PictBridgePictBridge YesSTORAGE SD, SDHC or SDXC (UHS-II) cardTypeSUPPORTED OPERATING SYSTEMS Windows 10 / 8.1 / 8 / 7(*)* With Microsoft .NET Framework 4.5 is installed.Mac OS X 10.9, 10.10, 10.11PC & MacintoshSOFTWAREImage Processing Digital Photo Professional 4.4.0 (RAW Image Processing)Other EOS UtilityCanon Camera Connect AppPOWER SOURCEBatteries Rechargeable Li-ion Battery LP-E6N (supplied)Battery life Approx. 1860 (at 23°C)- Not including battery packsBattery Indicator 6 levels + percentagePower saving Power turns off after 30 sec, 1, 2, 4, 8, 15minPower Supply & Battery Chargers AC Adapter AC-E6(N), DC coupler: DR-E6, Battery charger LC-E6/LC-E6EACCESSORIESViewfinder Eyecup Eb, E-series Dioptric Adjustment Lens, Eyepiece Extender EP-EX15, Angle Finder CWireless File Transmitter Built in Wi-Fi transmissionGPS Receiver GP-E2, Wireless remote BR-E1, Remote Controller RC-6, Remote Switch RS-60E3, Timer Remote Controller TC-80N3, Remote Controller Adapter RA-E3Lenses All EF and EF-S lensesFlash ST-E2, ST-E3-RT, EL-100, 270EX II, 430EX III RT/ 430 EX III, 470EX-AI, 600EX II-RT, Macro Ring Lite MR-14EXII, Macro Twin Lite MT-26EX-RTBattery Battery Park LP-E6NBattery Charger LC-E6 or LC-E6E Car Battery Cable CB-570Care Battery Charger CBC-E6 Grip: BG-E14Other Hand Strap E2Battery Magazine BGM-E14L / BGM-E14APHYSICAL SPECIFICATIONSBody Materials Aluminum alloy and polycarbonate resin with glass fibreOperating Environment 0 – 40 °C, 85% or less humidityDimensions (WxHxD) 140.7 x 104.8 x 76.8mmWeight (body only) Approx. 701g (CIPA testing standard, including battery and memory card) Lenke til kommentar
Nautica Skrevet 24. august 2019 Forfatter Del Skrevet 24. august 2019 Ser ut som det også kommer 3 nye RF-objektiver. Canon RF 15-35mm f/2.8L IS USM 82,600 THB – $2499 USD Canon RF 24-70mm f/2.8L IS USM 82,600 THB – $2499 USD Canon RF 70-200mm f/2.8L IS USM 93,500 THB – $2799 USD Lenke til kommentar
L/\R~ Skrevet 6. september 2019 Del Skrevet 6. september 2019 C500 Mark II er lansert, vil gi den litt plass i denne tråden. https://butikk.foto.no/canon/122966/canon-eos-c500-mark-ii--plus-512gb-cfexpress-og-kortleser?gclid=Cj0KCQjwh8jrBRDQARIsAH7BsXdqy5frMbPSPo0mnjug9aMdUPIbkDAmRLdPYm8MpjiJta3MsboOeUQaAgZpEALw_wcB 1 Lenke til kommentar
Nautica Skrevet 10. september 2019 Forfatter Del Skrevet 10. september 2019 (endret) Rykter angående en RS speilløst kamera, vi vil nok ikke se det for omtrent et års tid. Rumored information about the EOS RS: A slightly larger body and grip than the EOS R 80mp full-frame image sensor A “new style” of joystick Larger LCD than the EOS R Larger viewfinder than the EOS R The “viewfinder” can be tilted up and down (We’re not sure if this was the LCD screen or the EVF, we have reached out for some clarification) Dual SD card slots No video specifications are known Endret 10. september 2019 av Nautica Lenke til kommentar
Nautica Skrevet 17. september 2019 Forfatter Del Skrevet 17. september 2019 Ser ut som det kommer en erstatter for M100, en M200 Ingen spesifikasjoner ennå. Nå er det avdekket detaljerte patenter på IBIS så kan hende vi ser det i Canon kameraer snart. Lenke til kommentar
Nautica Skrevet 20. september 2019 Forfatter Del Skrevet 20. september 2019 (endret) Flere kameraer på gang ifølge ryktene. Ser ut som det kommer et nytt astrofotograferingskamera eos Ra og et nytt 1Dx mk3. Canon har også "lansert" er fjernstyrt kamerastativ/holder. Endret 20. september 2019 av Nautica Lenke til kommentar
Nautica Skrevet 14. oktober 2019 Forfatter Del Skrevet 14. oktober 2019 Ser ut som Canon fortsatt vil satse på 5D serien, nå er vist mk5 på gang. Lenke til kommentar
L/\R~ Skrevet 15. oktober 2019 Del Skrevet 15. oktober 2019 Høres bra ut for min egen del. Jobber med film, med foto primært som hobby men også litt jobb. Kjøpte Xa50 når det ble satt ned med 4 000, og nå blir det enten 5d ii, iii eller iv. Kanskje ii eller iii først, så iv når v kommer og senker resten i pris, sammen med speilløse som også senker de med speil. Med hus fra Canon får jeg da B-kamera som kan matches med farger. Lenke til kommentar
L/\R~ Skrevet 13. februar 2020 Del Skrevet 13. februar 2020 Det har skjedd og skjer mye framover hos Canon. @Nautica lager du en tråd for 2020 eller skal jeg overta stafettpinnen? Lenke til kommentar
Nautica Skrevet 13. februar 2020 Forfatter Del Skrevet 13. februar 2020 (endret) Er det 2020 allerede Ligger så mye på etterskudd angående jobbing, så mye som har blitt nedprioritert. Du kan gjerne påta deg det ærefulle oppdraget med å lage en ryktetråd for 2020 Da tar du sikkert også tak i annonseringen til Canon angående R5 og div nye objektiver, selv og det ikke lengre er et rent rykte. Foto.no skriver litt om dette. Annonseringer pleier jeg også og nevne i chattetråden og lanseringer pleier jeg og lage egne tråder for i "fotokamera". Endret 13. februar 2020 av Nautica Lenke til kommentar
