Essm1984 Skrevet 30. november 2018 Del Skrevet 30. november 2018 (endret) Play skill games online free, and put your skills to the test. The graphics are great, and no download is required, which will add to your fun. 1. The Spear Stickman Here, you take control of a stickman who is armed with just a spear. In the game, you take control of a stickman who is armed with just a spear. You are required to kill the other stickmen appearing at random on various platforms and trying to kill you. You must use your mouse to adjust your shot’s angle and aim fast to take down your enemy! Depending on where you hit them on their body, more shots are asked. For example, a head shot will kill stickmen instantly, while a shot to the leg will take some arrows to kill them. So, aim carefully! As you destroy more stickmen, apple coins are generated. You can use these coins to purchase upgrades – for example, a metal helmet! How long will you stay alive and how many stickmen will you kill? Aim by dragging your left mouse button. Release to shoot » You may also be interested in: Online games on PC 2. Helix Jump To rotate the tower, press the left or right arrow. The fun gameplay helps make Helix Jump increasingly popular. In the game, you’re required to successfully guide the ball through a tower that is slowly descending. Rotate the tower in order for the ball to fit through the gaps. As easy as it sounds, you must have great reactions and work quickly. Apart from the ball progression, you’re also required to try and gather as many diamonds as you can. It’s also possible for you to use different ball models as well as the background color changes too as you advance. The ball models are changeable. There are collectible diamonds To rotate the tower, press the left or right arrow. 3. CircloO There are totally 14 levels for you to complete with the addition of six hard mode levels to test your skill. CircloO is one of the popular online games for PC. It has realistic physics with momentum-based gameplay. Here, you take control of a circle that is required to gather other circles to expand the level and move on with the game. A physics engine is used in the game; you must manipulate it as it’s impossible to jump, build momentum up to manage to travel around the map. To complete a level, you’re required to gather seven circles spread out around the map, and grow the circle. There are totally 14 levels for you to complete with the addition of six hard mode levels to test your skill. Have fun! Use AD or the left/right arrow to control the movement. Endret 13. desember 2018 av Essm1984 Lenke til kommentar
Isbilen Skrevet 30. november 2018 Del Skrevet 30. november 2018 Det er lov å ringe legevakten hvis du er bekymret. Lenke til kommentar
Gaea Skrevet 30. november 2018 Del Skrevet 30. november 2018 Hallo, Jeg hadde smerte hele natten og følte meg syk, så jeg våknet opp i morges med en hvilepuls på rundt 140 og diaré. Er det normalt å ha så høy hjertefrekvens når du har mageinfluensa? Jeg har ikke hatt det på lenge, så jeg husker ikke. Jeg kan knapt bevege seg og har ikke forsøkt å spise. Eventuell hjelp er verdsatt. -Takk skal du ha Ring legevakten (116 117), og ber de deg dra inn, dra inn med en gang. Prøv å beskrive til legevakten om du har hatt luftavgang den siste tiden (har du hatt det er det bra!), hvor smerten sitter, og husk å nevne avføring(altså konsistens og hyppighet). Lenke til kommentar
