Får ikke åpne bilder
Prøver å åpne bilder men får beskjeden Ugyldig verdi for registret. Prøvd bildene på andre pcer og der funker det å åpne de.
Sitter med asus sonicmaster med windows 10.
Noen som vet om hvordan ska fikse detta probleme?.
Takk.
Gjest Slettet-x7D6du0Hjb
Takk.
Hei.
Prøv dette:
1. Open regedit as Administrator
2. check the following key: \HKEY_CURRENT_USER\SOFTWARE\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\Repository\Families\Microsoft.Windows.Photos_ ... etc.
3. You should have several entries for this key which all have a version number for the app in the name - like: Microsoft.Windows.Photos_15.1201.10020.0_ etc.
4. Check if you have 8 entries in total of which 4 have an older version number than the other 4. That basically means that 4 are outdated an were not deleted for some reason (if you have already uninstalled the photo app there might be only 4 entries in there; some reported having only 4 keys, with 2 keys being outdated - same principle should apply though).
5. Delete the outdated entries (ie. the entries with the smaller version number). That sounds easier than it is, because you won't have the right to do that - even as admin. To take property of the obsolete entries, right click each entry, go to permissions, click advanced, change owner from System to yourself, press ok and then assign full rights to the key to yourself. Now you should be able to delete it. (Check this video to see are more detailed explanation on how to take ownership of the registry keys: Link to Youtube)
6. Do that for all outdated keys and restart.
Hei.
Prøv dette:
Takk, ska prøve.
