Nye filmer på kazaa
Delvis
finnes det nye filmer på kazaa da? Trodde ikke noen brukte det lenger...
uansett det er seint, og jeg gidder ikke å skrive så mye, så jeg bare limer inn noe fra vcdquality. Admins: Bryter vel ikke med retningslinjene det her? Det er bare ment som en informativ post.
///CAM\\\
- A cam is usually a handheld camera snuck into a full theater. The base is shaky, the audio is poor, you can hear people laughing and talking. A cam is distinguishable by usually having a combination of all three or more of these flaws. Another common cam flaw is that the screen is at an awkward angle, and a lot of various parts of the screen cut off. Sometimes black bars will be added to make cams look like telesyncs or screeners, or to make them appear widescreen. In most circumstances, it actually cuts off more of the movie by doing so. Most sites nuke cams for their general poor quality.
///Workprint\\\
- An early release of a movie. These are usually stolen or leaked copies of movies that have made their way onto VCD from VHS or a variety of other sources. These will usually contain running time codes as well as other identifying marks used in movie production, although in some cases these are not there. These also might not be the final copy of the movie, resulting in some scenes not there, and some scenes added. The quality on these can vary from bad to very good depending on the quality of the source material used to encode the VCD. Audio tends to be better then the video, for the video sometimes isn’t complete. Note: This category is also used for very bad screeners or copies of movies that just didn't fit into any of the other categories due to defects or problems with the quality of the VCD's audio/video image.
///Telesync\\\
- A "professional" Cam. A steady base such as a tripod is used. it is done with a 1-3' tripod that they take with a camera in a bag (backpack), they set up the tripod in the seat with the camera on top, then for safety, some put a hat or coat over the camera (not blocking the lens) to hide it. They usually adjust their camera at this point to get a nice full screen, with about 10-20 percent of the edges cut off, which is usually not that noticeable except when beginning credits are cut off. Sometimes a widescreen telesync comes along, but has crooked edges. To fix this, sometimes straight borders are added. The theater is empty or very close to empty, and the audio and video are up to par. The audio is SOMETIMES ripped with the movie, from either just the camera being there (bad audio, gets complaints) or from the handicap headphone audio jacks. Sometimes, after the movie is ripped, or as it is ripping, a device such as an electronic recorder, will be attached to the handicap headphone jacks and recorded as the camera is set up at a more proper angle (the headphone jacks are usually on the wall, which would make it difficult to get a good angle). If the audio is ripped separately, it is added in sync with the video once on the computer. The end result, a descent to good picture with good audio, very good (if ripped properly, other times, it can be hollow). Although, you can usually detect some flaw with a TS. You may see a random head pop up, the screen edges are noticeable, or the audio isn't always crystal clear. While not perfect, the quality in general of a telesync ranges from good to very good and is usually the first type of VCD made of a new movie.
///Telecine\\\
- A great rip of a movie. Done a number of ways, all from taking directly from the reel. Ripped in either widescreen (letterbox) or in full-screen (pan and scan) with excellent audio and video. The most common way is to get a device that you attach to the reel that generates a VHS tape of the reel. (called a telecine machine, but there are other machines that generate a digital output of both audio and video that are then put into a laptop or VCR and made into a VCD). The direct-from-reel process makes a brilliant rip. Telecine movies are mostly released as screeners, but the quality is usually a lot better then the common screener. The color is more vivid and audio should be (like most screeners) stereo surround. Good telecines (as telecines in general) are hard to find, but are becoming more common.
///Screeners\\\
- These are the top quality VCDs (except in the release of a good telecine, which is released as a screener anyway). They can be in either widescreen (letterbox) or in full-screen (pan and scan) with excellent audio and video, as a telecine. Unlike a teleicne, one that is full screen will NOT have the edges cut off... it will be, as the movies say, "formatted to fit the screen". These are made from video distributors demo tapes, reviewers copies, insider copies of the film or from any number of sources (Video Stores, Malls, Hotels). Most screeners will contain "1-800-NO-COPIES" or "Property of.." messages somewhere in the film, but it's not a requirement to fit into the screener category. Actually, copyright messages are becoming less popular all the time. These most closely resemble a VHS or LaserDisc copy of the movie. They're easily identifiable by their top quality. Lots of TC, or TeliCine movies are released as Screeners. Movie production studios will often release screeners for promotional purposes. These promotional screeners will be distributed to different organizations to hype up the film. They are also sometimes sent to video stores a few months before the movie releases on video to hype up the video. Hotels frequently receive screeners to sell the movie to their customer's rooms directly. Some people leak screeners to release groups.
///DVD Rip\\\
- Using DVD-ROMS, and ripping software, takes the best quality movie you can get. Widescreen, awesome. Best video, usually awesome audio, sometimes not so good audio (it is lower) but "re-doing" the audio by re-encoding with TMPG Encoder with the Audio Effect filter on. The audio is great, stereo, but just the volume is a problem, which, in the way that I mentioned, and be fixed. The only disadvantage is that you have to wait for the movie to come out on video\DVD (or a month away, but very close to its official video release) so you can't get theater movies. For some people in other countries, however, the movie does not come out in the theater for them until over here it is already out on DVD, so they can get DVD rips of theater movies.
Original VCD rip – These rips are equal to DVD rips, sometimes better actually. Obviously, a DVD will be better then an original DVD, but when “ripping” a DVD, if the encoding is not done properly, or even good, but not GREAT, the quality of an original VCD rip passes it up. An original silver VCD is taken, and just made into a .bin and .cue directly, with virtually no loss in quality. Although these are usually the most crisp looking releases on side DVD rips, they are not that common, and as DVD rips, you have to wait until the movie is available on video, or close to the release date.
///TvRip\\\
– These are rips of television shows. Taken from a video-in card, converted to VCD, very simple. SHOULD be done with professional video capturing equipment. Usually, quality is just a little less then what you would see if you watched it on the television as it was being played. Music video rips are usually TVRips.
Er det folk som sitter med videokamera på kino og
tar dem opp eller..?  :dontgetit:
Ja.
Det er ingenting som er mer hat enn akkurat dette. At folk gidder å ha filmer av så skitten kvalitet på pc'en sin er forbi meg. Spesielt hat er det når man laster ned disse møkka filmene i håp om at det er bra kvalitet, og får et kinopublikum med latter og klapping med på kjøpet.
Hele gleden av filmen blir jo borte, eller så godt som eliminert. :angry:
Du skal slite med å se forskjellen på SVCD og DVD.
egentlig ikke, det ser jeg fort som bare det. Selv DVDR som er encodet med CCE @ flere pass av releasgrupper har jeg ikke noe problem med å se forskjell på fra en original DVD. Nå skal det også sies at det fortsatt er bra kvalitet, og at jeg har drevet med dette så lenge at jeg (desverre) har begynt å se etter feil på de aller beste rips, bare av vane, men ikke kom å si at det ikke er forskjell på SVCD og DVD
Ja.
Det er da ingen som tvinger deg til å laste det ned... dessuten er det bare å sjekke vcdquality.com for å finne ut kvaliteten. Nå er 80% av det som er på kazaa også feilmerket som DVD-Rip, så det er på tide å slutte å bruke det :yes:
Original VCD rip ? These rips are equal to DVD rips, sometimes better actually.
Bare et lite spm ang dette:
Har ikke VCD betraktelig dårligere oppløsning osv enn DVD? I så fall, hvordan kan da en VCD-rip bli bedre enn en DVD-rip utført på riktig måte?
Nå er jeg ikke helt sikker, men hør nå. Jeg antar at både DVD'en og VCD'en kommer fra samme kilde (ferdigredigert DV e.l), så VCD'en er blitt komprimert mye mer enn DVD'en. Dette forandres selvføgelig når DVD'en skal bli omgjort til VCD. Da har den allerede blitt komprimert fra den originale DV-filmen, og når den nå skal komprimeres igjen kan den ikke bli bedre enn den originale VCD'en. Skjønner?
Endret av sebdude
Jeg burde kanskje ha inkludert det i forrige innlegget mitt at jeg ikke bruker kazaa. :innocent:
Direct Connect er tingen. Og jeg tenkte mer på de som ikke hadde en beskrivelse. F.eks, når det bare står navnet på filmen. vcdquality viste jeg ikke om. :)
Det pleier ikke å være folk som sitter å filmer, det er oftest folk som jobber med filmene som legger dem ut.
nei... nesten alle nye filmer kommer ut som Telesync eller Cam først, med unntak av noen få sånn som Hulken. Bare se på vcdquality, atter en konge er allerede ute i tre versjoner, alle Telesyncs.
Filmentusiaster som søker den gode filmopplevelsen slipper dette problemet..
Kanskje noe å tenke på?
Var det ikke en undersøkelse som viste at de fleste filmene på nettet kom fra hollywood selv. Altså det var folk i den tekniske avdelingen som la dem ut.
jo, det er hovedkanalen, enten kurere, folka som sitter på oscar styre slipper faktisk mange ettersom de får mange til review..utrolig nok!
teknikere, og andre utro tjenere..det er ett stort problem i hollywood...
