Malvado Skrevet 1. oktober 2018 Del Skrevet 1. oktober 2018 Nå ser det virkelig ut som det vil begynne å dukke opp litt mer utvalg i minnetyper fremover og i større mengder.Mange av oss entusiaster har jo vært rimelige irriterte over stive priser og lite minne for pengene, men kanskje nå kan vi få noe som er langt bedre :https://www.techpowerup.com/247949/asus-ddr4-double-capacity-dimm-form-factor-a-workaround-to-low-dram-chip-densitiesDette er brikker som er langt større så de kan komme borti cpu kjølerne om de bruker en kjøler som strekker seg over minneplassen. 32-gigabyte DDR4 UDIMMs are a reality. Samsung recently announced the development of a 32 GB DDR4 dual-rank UDIMM, using higher density DRAM chips. Those chips, however, are unlikely to be available anytime soon, compounded by Samsung's reported scumbaggery in the making. In the midst of all this, motherboard major ASUS designed its own non-JEDEC UDIMM standard, called "Double Capacity DIMM" or DC DIMM, with the likes of G.Skill and Zadak designing the first models. The utility of these modules is to max out the CPU memory controller's limit despite having fewer memory slots on the motherboard. Possible use-cases include LGA1151 mini-ITX motherboards with just one slot per memory channel (2 slots in all), or certain LGA2066 boards with just four slots (one slot per channel). There is no word on the memory chip configuration modules, but it's highly likely they are dual-rank. The first DDR4 DC modules could be 32 GB, letting you max out the memory controller limit of 8th gen and 9th gen Core processors with just two modules. ASUS is heavily marketing this standard with its upcoming motherboards based on Intel's Z390 Express chipset, so it remains to be seen if other ASUS motherboards (or other motherboards in general) support the standard. Ironically, the Zadak-made module shown in ASUS marketing materials use DRAM chips made by Samsung. Lenke til kommentar
LMH1 Skrevet 1. oktober 2018 Del Skrevet 1. oktober 2018 (endret) Kingston DDR4 2133MHz 32GB (1x32GB) Eller trenger du flere slike? Tror ferreste trenger så mye ram. Endret 1. oktober 2018 av LMH1 Lenke til kommentar
Malvado Skrevet 1. oktober 2018 Forfatter Del Skrevet 1. oktober 2018 Problemer med å forstå artikkelen? Dette er hver minnebrikke og kan hjelpe prisene da minnet er dyrt akkurat nå, vi kan derfor få større mengder minne per brikke mot at de tar opp mer plass. Lenke til kommentar
